[Geoserver-users] Upgrade Path
Good morning,
We currently run Geoserver 2.10 in AWS with a Postgres 11.22 engine providing DB service. Last month AWS started charging a support fee for out-of-date DB engine versions, so we are looking at upgrading.
If I simply upgrade the engine to 14.10, (not even to the latest, just to limit engine upgrade issues), and the POSTGIS plugin as appropriate, should this work? Or do I need to proceed with a full uninstall / install as stated in this doc: https://docs.geoserver.org/main/en/user/installation/upgrade.html ?
Thanks for any help you can provide.
Sean Sweeney, BCmpH
Data Integration Specialist
Phone: 613-549-1232, ext. 1544
Toll-Free: 1-800-267-7875
Fax: 613-549-7896
sean.sweeney@anonymised.com
KFL&A Public Health
221 Portsmouth Avenue
Kingston, Ontario K7M 1V5
www.kflaph.ca
Connect with us on Facebook | Twitter | YouTube
A black and white logo Description automatically generated
KFL&A Public Health is situated on the traditional territories of the Anishinaabe and Haudenosaunee.
This e-mail may contain privileged and confidential information intended only for the individual or entity named in the message. If the reader of this message is not the intended recipient, or the agent responsible to deliver it to the intended recipient, you are hereby notified that any review, dissemination, distribution or copying of this communication is prohibited. If this communication was received in error, please notify us by reply e-mail and delete the original message.
Le présent message peut contenir des renseignements confidentiels réservés à l’usage exclusif du destinataire ou de l’organisme y figurant. Par conséquent, si vous n’êtes pas le destinataire de ce message ou la personne devant le lui remettre, nous vous avisons qu’il est strictement interdit de le passer en revue.
Sean,
GeoServer 2.10 is so old that I doubt anyone knows what would happen. I’d strongly recommend to upgrade to GeoSever 2.25 as soon as possible,
if nothing else, for the numerous security fixes that were applied in the 15 releases separating them…
And yes, I get that might take a while, and that you should do it carefully with good testing with the existing client apps, but really, you should schedule this activity.
For the database upgrade, can you just create a copy of the database, upgrade the copy, and point geoserver to it, to see if it works?
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Thank you for the input and those are good strategies on how to proceed.
After further talks we have discovered the system may not be as utilized as we were led to believe originally. After some review of network activity, we decided to switch it off to see what would be affected. So far no one has complained so we may not have to proceed with an upgrade and in fact just decommission the instance.
Thanks again for taking the time to respond!
Sent: Wednesday, May 29, 2024 6:13 AM
To: Sean Sweeney <Sean.Sweeney@…11996…>
Subject: Re: [Geoserver-users] Upgrade Path
CAUTION: This email originated from outside of the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe.
Sean,
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
On Tue, May 21, 2024 at 5:51 PM Sean Sweeney via Geoserver-users <geoserver-users@lists.sourceforge.net> wrote:
Good morning,
Sean Sweeney, BCmpH
Fax: 613-549-7896
sean.sweeney@…11996…
KFL&A Public Health
www.kflaph.ca
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
