[Geoserver-users] upload GDAL/NITF via REST - file extension in REST API?
Hello List,
I am trying to get a NITF image into Geoserver via REST. I use the (almost) current Geoserver 2.2 with the appropriate GDAL plugin. I can see the option to add a new raster data source in the NITF format via the web interface and I can also add NITF images that way. However, I want to use the rest interface and I ran accross a problem there.
First I create a new coverage store:
curl -u admin:geoserver -v -XPOST -H 'Content-Type: application/xml' -d '<coverageStore><name>testCurl</name><workspace>my_wms</workspace><enabled>true</enabled></coverageStore>' http://localhost:8080/geoserver/rest/workspaces/my_wms/coveragestores
which indeed creates a new coverage store. When I look at it in the list of stores (sorry, don't know if this is the correct translation, I have the UI in German and it says "Datenquellen"), the icon in the front is a yellow "!" in a triangle and the type is written as "?". I assume that's correct at this point. When I store a GeoTiff in such a coverage store via REST, it works.
Now I try to upload the actual NITF file:
curl -u admin:geoserver -v -XPUT -H 'Content-type: image/nitf' --data-binary @image.nitf 'http://localhost:8080/geoserver/rest/workspaces/my_wms/coveragestores/testCurl/file.worldimage?configure=first\\&amp;coverageName=testCurl&#39;
This results in a 500 error:
* Trying 127.0.0.1... connected
* Server auth using Basic with user 'admin'
  > PUT /geoserver/rest/workspaces/my_wms/coveragestores/testCurl/file.worldimage?configure=first\&coverageName=testCurl HTTP/1.1
  > Authorization: Basic YWRtaW46Z2Vvc2VydmVy
  > User-Agent: curl/7.22.0 (x86_64-unknown-linux-gnu) libcurl/7.22.0 OpenSSL/1.0.0e zlib/1.2.5 c-ares/1.7.5 libidn/1.22 libssh2/1.2.9
  > Host: localhost:8080
  > Accept: */*
  > Content-type: image/nitf
  > Content-Length: 5336204
  > Expect: 100-continue
< HTTP/1.1 100 Continue
< HTTP/1.1 500 Internal Server Error
< Content-Type: text/plain
< Transfer-Encoding: chunked
< Server: Jetty(6.1.8)
* HTTP error before end of send, stop sending
* Closing connection #0
The geoserver log shows that this file is not supported as worldimage:
02 Nov 12:28:27 INFO [catalog.rest] - PUT file, mimetype: image/nitf
02 Nov 12:28:27 INFO [catalog.rest] - Using existing coverage store: testCurl
02 Nov 12:28:27 ERROR [geoserver.rest] - Error auto-configuring coverage:Unsupported file format
org.geoserver.rest.RestletException: java.lang.IllegalArgumentException: Unsupported file format
          at org.geoserver.catalog.rest.CoverageStoreFileResource.handlePut(CoverageStoreFileResource.java:227)
          at org.restlet.Finder.handle(Finder.java:298)
          at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:37)
          at org.restlet.Filter.doHandle(Filter.java:105)
          at org.restlet.Filter.handle(Filter.java:134)
          at org.restlet.Router.handle(Router.java:444)
          at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:204)
          at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
          at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:86)
          at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
          at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
          at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
          at org.springframework.web.servlet.FrameworkServlet.doPut(FrameworkServlet.java:800)
          at javax.servlet.http.HttpServlet.service(HttpServlet.java:730)
          at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
          at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
          at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
          at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
          at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
          at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
          at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
          at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
          at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
          at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
          at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
          at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
          at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
          at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
          at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
          at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
          at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
          at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
          at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:201)
          at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
          at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
          at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
          at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:97)
          at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
          at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
          at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
          at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
          at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
          at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
          at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
          at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
          at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
          at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
          at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
          at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
          at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
          at org.mortbay.jetty.Server.handle(Server.java:324)
          at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
          at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
          at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
          at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:205)
          at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
          at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
          at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.lang.IllegalArgumentException: Unsupported file format
          at org.geotools.gce.image.WorldImageFormat.getWorldExtension(WorldImageFormat.java:328)
          at org.geotools.gce.image.WorldImageReader.prepareWorldImageGridToWorldTransform(WorldImageReader.java:703)
          at org.geotools.gce.image.WorldImageReader.getHRInfo(WorldImageReader.java:316)
          at org.geotools.gce.image.WorldImageReader.<init>(WorldImageReader.java:264)
          at org.geotools.gce.image.WorldImageFormat.getReader(WorldImageFormat.java:345)
          at org.geotools.gce.image.WorldImageFormat.getReader(WorldImageFormat.java:162)
          at org.geotools.gce.image.WorldImageFormat.getReader(WorldImageFormat.java:56)
          at org.geoserver.catalog.rest.CoverageStoreFileResource.handlePut(CoverageStoreFileResource.java:117)
          ... 79 more
As the REST API reference only states the three file extensions geotiff, worldimage and imagemosaic and none of these work, I assume that there exists another extension definition for NITF files. Either that or maybe the mimetype is not set as expected by Geoserver. I peeked in the source code but so far couldn't find anything helpful. Can anyone point me in the right direction for uploading NITF files via rest?
Thanks in advance for any responses.
Kind regards,
Daniel Haferkorn
Dipl.-Inform. (FH) Daniel Haferkorn
Fraunhofer Institut für Optronik, Systemtechnik und Bildauswertung IOSB
Abteilung Interoperabilität und Assistenzsysteme IAS
Fraunhoferstraße 1, 76131 Karlsruhe, Germany
Telefon +49 721 6091-431
mailto:daniel.haferkorn@anonymised.com
http://www.iosb.fraunhofer.de
Hello Daniel,
it seems the stores currently supported by Rest are only GeoTIFF, ImageMosaic and World Image files (Images like [PNG, JPEG, TIF] + WorldFile + PRJ) :
http://docs.geoserver.org/stable/en/user/restconfig/rest-config-api.html#coverage-stores (see the extension table).
The NITF dataset is managed by a different format (the GDAL based one) which I don’t think is currently supported by REST.
Hope this helps.
Daniele
On Tue, Nov 6, 2012 at 10:15 AM, Daniel Haferkorn <Daniel.Haferkorn@anonymised.com> wrote:
Hello List,
curl -u admin:geoserver -v -XPOST -H ‘Content-Type: application/xml’ -d
‘testCurlmy_wmstrue’
of stores (sorry, don’t know if this is the correct translation, I have
the UI in German and it says “Datenquellen”), the icon in the front is a
yellow “!” in a triangle and the type is written as “?”. I assume that’s
via REST, it works.
curl -u admin:geoserver -v -XPUT -H ‘Content-type: image/nitf’
–data-binary @image.nitf
http://localhost:8080/geoserver/rest/workspaces/my_wms/coveragestores/testCurl/file.worldimage?configure=first&coverageName=testCurl
  • Trying 127.0.0.1… connected
  • Server auth using Basic with user ‘admin’
PUT
HTTP/1.1
Accept: /
  • HTTP error before end of send, stop sending
  • Closing connection #0
testCurl
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.geotools.gce.image.WorldImageReader.(WorldImageReader.java:264)
at
at
at
at
… 79 more
code but so far couldn’t find anything helpful. Can anyone point me in
Kind regards,
Daniel Haferkorn
mailto:daniel.haferkorn@anonymised.com472…
LogMeIn Central: Instant, anywhere, Remote PC access and management.
Stay in control, update software, and manage PCs from one command center
Diagnose problems and improve visibility into emerging IT issues
Automate, monitor and manage. Do more in less time with Central
http://p.sf.net/sfu/logmein12331_d2d
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
Hello Daniel,
Hope this helps.
It would be a good improvement though. Rather than hardcode file extensions to formats we could do it more dynamically by looking up all available coverage formats.
Hello List,
via REST, it works.
PUT
HTTP/1.1
Accept: /
testCurl
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
… 79 more
Kind regards,
Daniel Haferkorn
On Mon, Nov 12, 2012 at 6:23 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
On Mon, Nov 12, 2012 at 2:26 AM, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Hello Daniel,
Hope this helps.
Indeed, the problem I see is that Format has no way to tell you about a file extension, mostly
because file extensions are not used at all, normally we open the file and check the headers
to recognize a file, not look at its name.
One thing format has it’s “name”, but you would not get an extension, more something
like “GeoTIFF”, “DTED”, “ERDASImg” and so on (I don’t believe there is
any requirement not to have spaces in the name, although the practice seems
to be no spaces).
Another issue is being able to tell apart file formats from service based readers,
such as SDE, Oracle, PostGIS and so on.
One final glitch might be dealing with single file formats vs multifile formats.
Hmm… lots of fun it seems…
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Thanks to the three of you for your responses. Indeed I was quite confused about the extension table in the documentation and thought, or should I say hoped, that the GDAL plugin would also extend the list of allowed extensions for the REST service. As this doesn't seem to be the case and I can't currently invest into adding such a functionality (although I would love to), I guess my only option now is to convert the NITF files to GeoTIFF prior to using the REST service.
Again, thanks for the clarifications!
Kind regards,
Daniel Haferkorn
Am 12.11.2012 18:34, schrieb Andrea Aime:
On Mon, Nov 12, 2012 at 6:23 PM, Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>> wrote:
    <mailto:daniele.romagnoli@anonymised.com>> wrote:
        Hello Daniel,
        based one) which I don't think is currently supported by REST.
        Hope this helps.
One thing format has it's "name", but you would not get an extension, more something
like "GeoTIFF", "DTED", "ERDASImg" and so on (I don't believe there is
to be no spaces).
Hmm... lots of fun it seems...
Ing. Andrea Aime
@geowolf
Technical Lead
