[Geoserver-users] Uppercase featureTypes with Postgis database
In our development environment we want to use postgis as our db opposed to oracle spatial in testing/production.
For the oracle db we have a data-dir setup with uppercase names for our feature types.
When using this data-dir and only changing the datastore in the catalog.xml I get several errors like:
org.geotools.data.SchemaNotFoundException: Feature type could not be found for
I traced it down to the DataBaseMetaData class methods like getTableName and getColumns where in the postgres case a lowercase typname must be provided to make it work.
Is there a possibility to use the same data-dir (and thus not having to rewrite all featuretype/info.xml’s to use a lowercase name (including changing the openlayers javascript)
I have already checked out a copy of geoserver and geotools sourcecode so if changes need to be made I can do that if pointed in the right direction (where to change and how to prevent mashing up other db configurations)
Kris Geusebroek
Consultant
cid:image001.jpg@anonymised.com
Email: kgeusebroek@anonymised.com
Tel: +31 (0)35 538 1921
Fax: +31 (0)35 538 1922
Mobile: +31 (0)6 30 697 223
http://www.xebia.com
Utrechtseweg 49
1213 TL Hilversum
The Netherlands
Xebia Blog ! http://blog.xebia.com/
Xebia Podcast! http://podcast.xebia.com/
Kris Geusebroek ha scritto:
org.geotools.data.SchemaNotFoundException: Feature type could not be found for <typeName>
Hmmm.... even if you fixed the table name lookup in the metadata you'd
end up with different names for attributes (they would be lower case,
again), and this would change the GML output, and make SLD using
attribute names non portable between the two installations.
As far as I know Postgres is case preserving, and defaults to lowercase
if no one specified otherwise. In order to have the same case as Oracle
you just have to create your table forcefully specifying a uppercase
convention, that is, something like:
create table "MYTABLE" (
   "ID" serial,
   "NAME" varchar(200),
and then it should work (my guess, never actually tried).
GeoServer actively relies on this case preserving setup to pass
the CITE tests, where OGC requires one to have types and attributes
with camel cased names (e.g., "GenericEntity").
Andrea Aime
OpenGeo - http://opengeo.org
Yep,
Postgres has case sensivity. Just recently bang my head against a wall with that. See e.g.:
http://codesnippets.joyent.com/posts/show/1701
The worst thing IMO, when migrating data with different databases, is to mix lower and upper case in names. For example:
http://webhelp.esri.com/arcgisserver/9.3/dotNet/index.htm#geodatabases/insta
l-1427030965.htm
"Be aware that although PostgreSQL allows you to store mixed case or all
uppercase database or user names, these cannot be used with ArcSDE
geodatabases."
- mika -
Andrea Aime kirjoitti:
   "ID" serial,
Hi Andrea,
Creating those tables with quotes surrounding the tableName and column
Names did the trick.
Thanks a lot
-----Original Message-----
Sent: Wednesday, January 28, 2009 9:18 AM
To: Kris Geusebroek
Subject: Re: [Geoserver-users] Uppercase featureTypes with Postgis
database
opposed
our
feature types.
getTableName
to
rewrite all featuretype/info.xml's to use a lowercase name (including
sourcecode
configurations)
   "ID" serial,
Andrea Aime
