[Geoserver-users] urn:ogc:def:query:OGC-WFS::GetFeatureById
Dear list
I have a service providing harmonized data.
The service works, only the storedquery urn:ogc:def:query:OGC-WFS::GetFeatureById throws an error
I get the first record to find an ID
https://inspire.informatievlaanderen.be/overdrachtdiensten/hy-n/wfs?VERSION=2.0.0&SERVICE=WFS&REQUEST=GetFeature&typeNames=hy-n%3AWatercourseLink&count=1
GetFeature/FeatureID works ok
https://inspire.informatievlaanderen.be/overdrachtdiensten/hy-n/wfs?VERSION=2.0.0&SERVICE=WFS&REQUEST=GetFeature&typeNames=hy-n%3AWatercourseLink&FeatureID=vha_waterloopsegment_100000
The stored query throws an error: Could not find feature with specified id
https://inspire.informatievlaanderen.be/overdrachtdiensten/hy-n/wfs?SERVICE=WFS&REQUEST=GetFeature&VERSION=2.0.0&storedquery_id=urn%3Aogc%3Adef%3Aquery%3AOGC-WFS%3A%3AGetFeatureById&outputformat=application%2Fgml%2Bxml%3B%20version%3D3.2&id=vha_waterloopsegment_100000&typename=hy-n%3AWatercourseLink
I use Geoserver 2.15
Data is stored in sqlserver
I use the AppSchema extension (And I paste the definition below)
Is there something wrong in this definition. The storedquery works all right in my other services, that don’t use the app schema extension.
For example
https://geoservices.beta.informatievlaanderen.be/overdrachtdiensten/Adressen/wfs?service=WFS&REQUEST=GetFeature&STOREDQUERY_ID=urn:ogc:def:query:OGC-WFS::GetFeatureById&ID=Adrespos.1000320856&typename=Adressen:Adrespos&outputformat=GML2
I examined the log files, but I couldn’t find anyting more than “Could not find feature with specified id” (GEOTOOLS_DEVELOPER_LOGGING)
Thanks
Bart
http://inspire.ec.europa.eu/schemas/hy-n/4.0/HydroNetwork.xsd
dataStore
WatercourseLink
hy-n:WatercourseLink
nns:beginLifespanVersion
nns:centrelineGeometry
strConcat(‘centrelineGeometry.’, getId())
SHAPE
nns:fictitious
fictitious
hy-n:flowDirection
xlink:href
flowDirection_href
gml_id
gml:identifier
gml_identifier
codeSpace
gml_codespace
nns:inNetwork
nilReason
inNetwork
xsi:nil
if_then_else(isNull(inNetwork), Expression.NIL, ‘true’)
nns:inspireId/base:Identifier/base:localId
inspireId_localId
nns:inspireId/base:Identifier/base:namespace
inspireId_namespace
hy-n:length
length
xsi:nil
if_then_else(isNull(length), ‘true’, Expression.NIL)
uom
length_uom
nns:inspireId/base:Identifier/base:versionId
inspireId_versionId
Hi Bart,
I am pretty sure this is a known, un-fixed issue when using complex features served from Geoserver + AppSchema, due to the fact that gml:id isn’t getting resolved. I believe this is regardless of the underlying DB: we were working on PG + PostGIS, but should replicate on SQL Server.
With my previous team, we tried to figure out a way to fix the broken Stored Query, however we couldn’t achieve a clear resolution, and I am unsure if this was addressed.
Sorin RUSU
GIS
Pe marți, 16 aprilie 2019, 19:46:14 EEST, Verbeeck Bart (AIV) bart.verbeeck@anonymised.com a scris:
Dear list
For example
Thanks
Bart
dataStore
WatercourseLink
SHAPE
nns:fictitious
fictitious
hy-n:flowDirection
xlink:href
flowDirection_href
gml_id
gml:identifier
gml_identifier
codeSpace
gml_codespace
nns:inNetwork
nilReason
inNetwork
xsi:nil
inspireId_localId
inspireId_namespace
hy-n:length
length
xsi:nil
uom
length_uom
inspireId_versionId
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
I did a quick check, there are a couple of issues open related to GetFeatureById but none of them
returns the same error message:
https://osgeo-org.atlassian.net/browse/GEOS-8734
https://osgeo-org.atlassian.net/browse/GEOS-6233
It would be useful to have a ticket for this case as well, with a self-contained package (data, config, request) that
helps reproduce the problem
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I know that this is an old issue, but there seem to be other issues with urn:ogc:def:query:OGC-WFS::GetFeatureById in our cofiguration.
I am using 2.25.4 now, and the data is stored in sql server.
I get the “Could not find feature with specified id” error in two cases i think I foud out:
  • if the sql view layer refers to a sql view and not a table
  • or if the layer has a name that exists in more than 1 workspace.
GetFeature/FeatureID works ok, but the stored quey doesnt find the feature.
Anyone any idea?
