[Geoserver-users] UserDefinedSymbolization tag
Does GeoServer support the UserDefinedSymbolization tag, which I think
allows users to create customized symbols other than the standard
xxxSymbolisation available?
Lee Wai See
ST Electronics (Info-Software Systems) Pte Ltd
[This e-mail is confidential and may be priviledged. If you are not the
intended recipient, please kindly notify us immediately and delete the message
from your system; please do not copy or use it for any purpose, nor disclose
its contents to any other person. Thank you.]
---ST Electronics Group---
Yes, it does. It's reported in the capabilities document.
<UserDefinedSymbolization SupportSLD="1" UserLayer="1" UserStyle="1" RemoteWFS="0"/>
You use an SLD document to define user symbolization. Since GeoServer uses SLD's natively, it is quite easy for us to support remote user defined symbolization. The one thing we don't yet support is RemoteWFS. Which actually wouldn't be that hard at all for us to support, but no one's written the code to do it yet.
Note that the tag doesn't let you make customized symbols other than defined in SLD. But SLD is pretty extensive, has a number of well known symbols, and then also supports external graphics, so you can just create an image and use that as a symbol.
best regards,
Chris
Lee Wai See wrote:
Does GeoServer support the *UserDefinedSymbolization* tag, which I think allows users to create customized symbols other than the standard xxxSymbolisation available?
Lee Wai See
!DSPAM:1003,44bdab9f288351995013331!
opinions on IT & business topics through brief surveys -- and earn cash
Geoserver-users mailing list
Chris Holmes
The Open Planning Project
http://topp.openplans.org
