[Geoserver-users] Using Geo server to reference external data stores.
Hello,
I want to be able to reference shape files that are stored in an external
directory without making an actual copy of the files using geo-server.
    I used the use case provided by in the
   Geo-server documentation for uploading a shape file and it works, however
tweaking produced errors.
Example given Below:
a) Use case for uploading shapefiles works
    [User@~/geoserver-2.0.2]$ curl -u admin:geoserver -v -XPUT -H
   'Content-type: application/zip' --data-binary
   @/home/User/shapefiles/test1.zip
http://localhost:9090/geoserver/rest/workspaces/tests/datastores/test1/file.shp
   * About to connect() to localhost port 9090 (#0)
   * Trying 127.0.0.1... connected
   * Connected to localhost (127.0.0.1) port 9090 (#0)
   * Server auth using Basic with user 'admin'
   > PUT /geoserver/rest/workspaces/tests/datastores/test1/file.shp HTTP/1.1
   > Authorization: Basic YWRtaW46Z2Vvc2VydmVy
   > User-Agent: curl/7.16.4 (i386-redhat-linux-gnu) libcurl/7.16.4
   OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.8
   > Host: localhost:9090
   > Accept: */*
   > Content-type: application/zip
   > Content-Length: 119693
- Ignored:
   > Expect: 100-continue
   < HTTP/1.1 100 Continue
   < HTTP/1.1 201 Created
   < Date: Fri, 01 Oct 2010 15:56:08 GMT
   < Server: Noelios-Restlet-Engine/1.0..8
   < Transfer-Encoding: chunked
   * Connection #0 to host localhost left intact
   * Closing connection #0
   If I use the following to reference the data externally I get an error.
Errors received when trying to reference the file(s) externally
'Content-type:
   application/zip' -d file:/home/User/shapefiles/test1.zip
http://localhost:9090/geoserver/rest/workspaces/tests/datastores/test1/external.shp
   > PUT /geoserver/rest/workspaces/tests/datastores/test1/external.shp
   HTTP/1.1
   > Accept: */*
   > Content-Length: 37
   < HTTP/1.1 400 Bad Request
   < Server: Jetty(6.1.8)
   Could not determine format. Try setting the Content-type
   header.[User@~/geoserver-2.0.2]$
   It seem to be a syntax error, However, I'm not able to figure out the
   errors.
   Any Help would be greatly appreciated.
   --Mckeane
View this message in context: http://old.nabble.com/Using-Geo-server-to-reference-external-data-stores.-tp29859302p29859302.html
GeoServer does not support the .external or .file notation for Shapefiles; only GeoTIFFs. However, if the Shapefiles are already on the server, you can POST an XML configuration to /rest/workspaces/default/datastores/ which references that file path and create a store that way. Issue a GET request for an existing Shapefile datastore for an example configuration.
Hope this helps.
David Winslow
OpenGeo - http://opengeo.org/
On Fri, Oct 1, 2010 at 3:15 PM, Mckeane <mckeane.thomas@anonymised.com> wrote:
Hello,
‘Content-type: application/zip’ --data-binary
  • About to connect() to localhost port 9090 (#0)
  • Trying 127.0.0.1… connected
  • Connected to localhost (127.0.0.1) port 9090 (#0)
  • Server auth using Basic with user ‘admin’
Accept: /
  • Ignored:
< Server: Noelios-Restlet-Engine/1.0…8
  • Connection #0 to host localhost left intact
  • Closing connection #0
‘Content-type:
application/zip’ -d file:/home/User/shapefiles/test1.zip
HTTP/1.1
Accept: /
Content-Length: 37
It seem to be a syntax error, However, I’m not able to figure out the
errors.
–Mckeane
Start uncovering the many advantages of virtual appliances
and start using them to simplify application deployment and
accelerate your shift to cloud computing.
http://p.sf.net/sfu/novell-sfdev2dev
Geoserver-users mailing list
Hi David,
“However, if the Shapefiles are already on the server, you can POST an XML configuration to /rest/workspaces/default/datastores/ which references that file path and create a store that way”
really?? Would you be so kind to send a XML-configuration example?
Best regards
Florian
David Winslow dwinslow@anonymised.com hat am 4. Oktober 2010 um 14:20 geschrieben:
Hope this helps.
David Winslow
Hello,
Accept: /
  • Ignored:
‘Content-type:
HTTP/1.1
Accept: /
Content-Length: 37
errors.
–Mckeane
