I have downloaded and installed GeoServer 2.1-RC1 which shipped with
RESTconfig. How can i check whether REST service is installed with GeoServer
or Not ?
I put this "http://localhost:8080/geoserver/rest" in my browser, but it
gives error! ... It means REST service is not installed as i understand. Or
is there any other method to check whether the service is installed or not ?
View this message in context: http://old.nabble.com/Using-REST-service-with-GeoServer-tp30912351p30912351.html
The easiest way is to visit /geoserver/rest/workspaces.xml. If in a browser you will get prompted for credentials, enter them and if you get a list of workspaces back then it should be installed.
or Not ?
I put this “http://localhost:8080/geoserver/rest” in my browser, but it
gives error! … It means REST service is not installed as i understand. Or
The ultimate all-in-one performance toolkit: Intel(R) Parallel Studio XE:
Pinpoint memory and threading errors before they happen.
Find and fix more than 250 security defects in the development cycle.
Locate bottlenecks in serial and parallel code that limit performance.
http://p.sf.net/sfu/intel-dev2devfeb
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
On Mon, Feb 14, 2011 at 9:37 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
So what if it asks for my credentials and then says 404 The requested
resource () is not available.?
Ian
Ian Turton
On further investigation it seems that I can't actually log in to my
latest install of GeoServer 2.1 (snapshot svn: 15294) - is there
somewhere other than sercurity/users.properties that a password could
be set?
or should I just move on to the latest nightly and see if that works?
Ian
Ian Turton
