I followed all the steps in the tutorial to create a time series of images,
according to the tutorial:
https://docs.geoserver.org/latest/en/user/tutorials/imagemosaic_timeseries/imagemosaic_timeseries.html
<https://docs.geoserver.org/latest/en/user/tutorials/imagemosaic_timeseries/imagemosaic_timeseries.html>
I can do it by generating the shapefile, but when I do it with
data.properties to connect to Postgis, the following error occurs:
/Could not list layers for this store, an error occurred retrieving them:
Failed to create reader from file:data/mosaico and hints Hints: REPOSITORY =
org.geoserver.catalog.CatalogRepository@anonymised.com EXECUTOR_SERVICE =
java.util.concurrent.ThreadPoolExecutor@anonymised.com[Running, pool size = 0,
active threads = 0, queued tasks = 0, completed tasks = 0] System defaults:
GRID_COVERAGE_FACTORY = GridCoverageFactory TILE_ENCODING = null
FEATURE_FACTORY = org.geotools.feature.LenientFeatureFactoryImpl@anonymised.com
FORCE_AXIS_ORDER_HONORING = http FORCE_LONGITUDE_FIRST_AXIS_ORDER = true
FILTER_FACTORY = FilterFactoryImpl LENIENT_DATUM_SHIFT = true
COMPARISON_TOLERANCE = 1.0E-8 STYLE_FACTORY = StyleFactoryImpl/
Can someone help me, please ?
Wesley
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html
We need the rest of the log trace.
On 10/11/20, wmezine <wesleymezine@anonymised.com> wrote:
Wesley
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this
list:
- Earning your support instead of buying it, but Ian Turton:
http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines:
http://geoserver.org/comm/userlist-guidelines.html
If you want to request a feature or an improvement, also see this:
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
In my experience it’s more than likely permissions on the folder and/or the datastore.properties file since it is still trying to write the shapefile. This to me says it’s not reading the datastore.properties.
Bryan
Thanks and have a blessed day!
Bryan Kilgore
Good Morning,
I am sending attached the log files and the files used to create the mosaic image.
Wesley
Em sáb., 17 de out. de 2020 às 16:47, Alexander Petkov <greenkov@anonymised.com> escreveu:
FEATURE_FACTORY = org.geotools.feature.LenientFeatureFactoryImpl@anonymised.com10568…
Wesley
list:
geoserver.log (3.77 MB)
datastore.properties (304 Bytes)
indexer.properties (244 Bytes)
snow_20091201.tif (26.1 KB)
snow_20091101.tif (27.1 KB)
snow_20091001.tif (28.1 KB)
timeregex.properties (14 Bytes)
The problem is evident right here:
Caused by: org.postgresql.util.PSQLException: FATAL: password authentication failed for user “wandersen”
at org.postgresql.core.v3.ConnectionFactoryImpl.doAuthentication(ConnectionFactoryImpl.java:514)
at org.postgresql.core.v3.ConnectionFactoryImpl.tryConnect(ConnectionFactoryImpl.java:141)
at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:192)
at org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:49)
at org.postgresql.jdbc.PgConnection.(PgConnection.java:195)
at org.postgresql.Driver.makeConnection(Driver.java:454)
at org.postgresql.Driver.connect(Driver.java:256)
The password in datastore.properties needs to be corrected
On Mon, Oct 19, 2020 at 5:05 AM wesley mezine <wesleymezine@anonymised.com.84…> wrote:
Good Morning,
Wesley
Wesley
list:
The administrator can you remove my attachments, please ?
Em seg, 19 de out de 2020 16:42, Alexander Petkov <greenkov@anonymised.com> escreveu:
On Mon, Oct 19, 2020 at 5:05 AM wesley mezine <wesleymezine@anonymised.com> wrote:
Good Morning,
Wesley
Wesley
list:
the attachments are not visible from the SF archive, as far as I can tell:
https://sourceforge.net/p/geoserver/mailman/message/37131947/
(it if was, I could not do anything about it, believe only a direct request to SF would help removing the attachments)
That said, it would not help much, this list has almost 800 subscribers, they all received
the config files. Best to stop using the credentials in question as soon as possible.
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
