Although 'Support on the fly geometry simplification' has been turned off on the Store, there's still some kind of zoom-dependent generalisation going on for vector tiles. Can the amount of generalisation be adjusted for each zoom level? Is it the overSamplingFactor? Can this be adjusted somehow as well?
Thanks in advance for your suggestions!
Edward
Mapbox vector format is in integer-ized pixel coordinates, so doing more than that wouldn’t affect the output.
For the other formats (i.e. geojson), you can use the overSamplingFactor so it gets better resolution.
If you need to change these, you’re probably requesting tiles at the wrong resolution for what you’re drawing.
Dave
On Thu, Feb 2, 2017 at 1:17 PM, Edward Mac Gillavry <edward@anonymised.com> wrote:
Although ‘Support on the fly geometry simplification’ has been turned
off on the Store, there’s still some kind of zoom-dependent
Edward
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Hiya,
Thnx for your feedback. Indeed, we’re working with the Mapbox vector tile format. Will investigate further whether the client library is actually requesting the tiles at the wrong resolution. Buildings are losing their right angles and disappear altogether at smaller zoom levels.
Edward
On 03-02-17 00:31, Dave Blasby wrote:
Dave
On Thu, Feb 2, 2017 at 1:17 PM, Edward Mac Gillavry <edward@anonymised.com.8010…> wrote:
Edward
Geoserver-users@anonymised.comsourceforge.net
