Ah yeah, very nasty issue.
I was thinking to actually fix it in GeoServer 2.0.
The main problem I’m facing with this change is that it will
invalidate
all existing SLD that do not specify a line width or those that
do specify a line width less than 1.5 pixels, since the line will
be drawn almost twice as thick when the patch is made.
So as you can see I’m facing a backwards compatibility issue.The same goes with the other issue we’ve found during that test,
that is, fonts sized in points instead of pixels. If I find a way
to get fonts sized in pixels, all font sizes will be invalidate
as well, because points are smaller than pixels.Another option I could look into would be to provide, for the
moment, an option to setup in web.xml, something like
ENABLE_NATURAL_STROKE_SIZE=true and ENABLE_FONT_SIZE_PIXELS=true…Suggestions?
From my point of view (as a happy user who doesn’t like the thin lines ;)) I would appreciate a “web.xml”-solution as with the new labeller.
regards
Stefan
Andrea–
Andrea Aime
OpenGeo - http://opengeo.org
