[Geoserver-users] WCS (1.1.1) reprojection parameters?
List:
Having "gifted" myself a copy of GeoServer for Christmas, I've been doing some WCS experimentation with the "nurc:Pk50095" coverage that comes in the sample dataset.
I successfully added the EPSG:4326 to the list of supported projections of this coverage. Thus, using the WCS 1.1.1 standard, I was able to request a subset of the image using EPSG:4326 coordinates:
http://localhost:8080/geoserver/wcs?
request=GetCoverage&
version=1.1.1&
identifier=nurc:Pk50095&
SERVICE=wcs&
FORMAT=image/geotiff&
BOUNDINGBOX=46.75,13.05,46.85,13.25,urn:ogc:def:crs:EPSG::4326
The resulting GeoTIFF is in the native projection of the coverage (EPSG:32633)--as expected.
My experiments ground to a halt when trying to figure out how to get my requested image back in the EPSG:4326 projection. Digging into the OGC documentation (OGC -7-067r5), in Table 28 I see that if I make a request for a projection other than a coverage's native projection, I see a number of promising parameters--
GridBaseCRS
GridType
GridCS
But no luck in figuring out the magic combination.
Any pointers on what I need to get my requested coverage back in the 4326 projection would be greatly appreciated.
Brian
Hi Brian,
After adding EPSG:4326 to the set of accepted projections and appending "&gridbasecrs=EPSG:4326" to the request you specified below what i get back appears to be a reprojected coverage.
I compared to result to a manual reprojection with gdalwarp and the two appear to line up (although the result from gdalwarp appears to be flattened somewhat).
Feel free to attach or post a screen shot of what you are getting back from the server.
-Justin
Brian Timoney wrote:
List:
version=1.1.1&
SERVICE=wcs&
GridBaseCRS
GridType
GridCS
Brian
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin:
You're suggestion worked like a charm--
http://localhost:8080/geoserver/wcs?request=GetCoverage&version=1.1.1&
SERVICE=wcs&
BOUNDINGBOX=46.75,13.05,46.85,13.25,urn:ogc:def:crs:EPSG::4326&
It's always heartening when problems have simpler answers than you originally imagined.
Brian
Justin Deoliveira wrote:
Hi Brian,
-Justin
List:
version=1.1.1&
SERVICE=wcs&
GridBaseCRS
GridType
GridCS
Brian
The Timoney Group
518 17th Street Suite 1000
Denver, CO 80202
Ph: (303) 929-3722
Fax: (303) 571-4304
www.thetimoneygroup.com
