[Geoserver-users] WCS porting on trunk done!
The porting is done, GeoServer 1.5.x is ready to go!
We are still finishing some stress tests, but all seems ok.
Some notes:
  • The project is based on GeoTools 2.3.x branch (actually 2.3.0-rc1-SNAPSHOT) [http://svn.geotools.org/geotools/branches/2.3.x]
  • In order to compile and run it correctly you need Java 1.5.x, JAI 1.1.4+ and ImageIO 1.1+
  • When start the Web Container (jatty, Tomcat, …) use the following JVM arguments to have better performances:
    -Xms256M -Xmx512M -Dorg.geotools.referencing.forceXY=true
  • The map producers have been replaced with others that use enhanced JAI and ImageIO functions. We are conducting tests on image sizes and setting better compression/quality parameters and at this moment we have smaller and coolest images than the previous release (we will post the test results soon).
Eng. Alessio Fabiani
Vice President/CTO GeoSolutions
Glad to hear the merge is done. Good work guys!
Couple of questions/comments:
Did we plan on having to use Java 1.5? Is it definitely required? I thought we were going to stick with 1.4 for a while, but I could be wrong.
Could you update the developers guide to reflect the JVM arguments that should be passed in? I think only the part on setting up Eclipse will need changing.
I'm glad to hear that everything went well and I know many people are looking forward to using WCS.
Brent Owens
(The Open Planning Project)
Some notes:
- The project is based on GeoTools 2.3.x branch (actually 2.3.0-rc1-SNAPSHOT) [http://svn.geotools.org/geotools/branches/2.3.x\]
- In order to compile and run it correctly you need Java 1.5.x, JAI 1.1.4+ and ImageIO 1.1+
- When start the Web Container (jatty, Tomcat, ...) use the following JVM arguments to have better performances:
- The map producers have been replaced with others that use enhanced JAI and ImageIO functions. We are conducting tests on image sizes and setting better compression/quality parameters and at this moment we have smaller and coolest images than the previous release (we will post the test results soon).
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
This is definitely the opposite of what I've heard. We planned to stay on 1.4 for a while.
What do we need 1.5 for?
In fact I just tried to build trunk with 1.4 and it builds fine. Don't know if it works thought, haven't tried
to really use it.
We will have to include some WCS examples in the sample requests page.
Alex
> on 1.4 for a while.
to really use it.
Now a question from a users point of view:
If I want to continue following, testing and using the geoserver wcs developments, what should I check out from subversion instead of 1.4.x-wcs-merge? 1.4.x? 1.5.x? Where will wcs development take place? Will trunk keep being based on geotools-2.3.0-snapshot, or switch to geotools-trunk (=2.4.0-snapshot)?
Sorry, but it's a bit hard to follow with all these branches being swooped in my face by the winds of change...
Vincent.
Some notes:
Geoserver-users mailing list
Hi Vincent,
you are right.
For all WCS users, follow the GeoServer trunk (GeoServer 1.5.x) and GeoTools 2.3.x branch (which actually is GeoTools 2.3.0-rc1-SNAPSHOT).
Sorry, but it’s a bit hard to follow with all these branches being
swooped in my face by the winds of change…
Vincent.
Some notes:
    2.3.0-rc1-SNAPSHOT) [ http://svn.geotools.org/geotools/branches/2.3.x]
http://www.geo-solutions.it <http://www.geo-solutions.it >
Nice!
A couple notes on things we need to get to 1.5.0...
These requirements are a bit much. At the very least we need a WFS and WMS that can run on Java 1.4. I'm fine if the WCS requires 1.5, but it would be really nice if it could do 1.4, so that we don't have to disable it by default (I suppose we could do an auto check and enable it if it's 1.5).
Same goes for JAI and ImageIO. We _can_not_ require these for everyone. We used to do this, and it was a nightmare, adoption shot up when these weren't required. I'm all for encouraging people to install them, but we need a default that works fine without them. Ideally include the jars, but if the installed version is there be able to use it. Less ideally have people remove the jars when they install the native ones.
We can also make it so the windows installer puts the windows native ones by default, which may help as well.
Is it ok to set forceXY for all cases? Like should we set this in GeoServer by default? I'm pretty sure you can set system properties from within java on start up.
That's great. Some users really like small image sizes, indeed we had bigger sizes for 1.3. So if we can get that as small as possible and still look very good that's great news.
best regards,
Chris
--------------------------------------------------------- !DSPAM:1003,4535f407159101362196140!
Chris Holmes
http://topp.openplans.org
I am not sure about the Java 5 requirement--just yesterday I compiled
the wcs-1.4.x merge branch with java 1.4, it seemed to be working just
fine.
Alex
Nice!
if it's 1.5).
> test results soon).
best regards,
Chris
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Chris Holmes
  • Java 1.5 is not a requirement, but things work much better using this.
  • We can even restore the old map producers which don’t require JAI/ImageIO, but GeoServer 1.5.x code like GeoTools 2.3.x are thought to highly improve performances and quality by using those two libraries. Maybe we can write a good installation guide for less expert users. We should speak about this at meeting I think.
  • With latest changes org.geotools.referencing.forceXY option should not be a requirement, but again it depends on Geotools and the Axis order issue, so I suggest to use this option for a while, not forever.
On 10/18/06, Alexander Petkov <greenkov@anonymised.com> wrote:
I am not sure about the Java 5 requirement–just yesterday I compiled
fine.
Alex
Nice!
A couple notes on things we need to get to 1.5.0…
    WMS that can run on Java 1.4. I’m fine if the WCS requires 1.5, but it
    would be really nice if it could do 1.4, so that we don’t have to
    if it’s 1.5 ).
Same goes for JAI and ImageIO. We can_not require these for everyone.
these weren’t required. I’m all for encouraging people to install them,
    GeoServer by default? I’m pretty sure you can set system properties
    test results soon).
    That’s great. Some users really like small image sizes, indeed we had
    still look very good that’s great news.
best regards,
Chris
Chris Holmes
- Java 1.5 is not a requirement, but things work much better using this.
Ok, then let's document as such. Not required, but recommended for WCS.
- We can even restore the old map producers which don't require JAI/ImageIO, but GeoServer 1.5.x code like GeoTools 2.3.x are thought to highly improve performances and quality by using those two libraries. Maybe we can write a good installation guide for less expert users. We should speak about this at meeting I think.
Will the new map producers work with the jar versions of jai/imageio? Or are they too slow with the jars? It could be good to keep both producers around, just rename the old ones so you use something else to request them. Installation guides are definitely essential, but we for sure need to have something that works out of the box, and then they can upgrade if they want more performance.
- With latest changes org.geotools.referencing.forceXY option should not be a requirement, but again it depends on Geotools and the Axis order issue, so I suggest to use this option for a while, not forever.
Cool.
Chris
On 10/18/06, *Alexander Petkov* <greenkov@anonymised.com <mailto:greenkov@anonymised.com>> wrote:
    fine.
    Alex
    <mailto:cholmes@anonymised.com>> wrote:
     > Alessio Fabiani wrote:
     > > The porting is done, GeoServer 1.5.x is ready to go!
     > Nice!
     > A couple notes on things we need to get to 1.5.0...
     > > - In order to compile and run it correctly you need Java 1.5.x, JAI
     > > 1.1.4+ and ImageIO 1.1+
     > These requirements are a bit much. At the very least we need a
    WFS and
     > WMS that can run on Java 1.4. I'm fine if the WCS requires 1.5,
    but it
     > would be really nice if it could do 1.4, so that we don't have to
     > disable it by default (I suppose we could do an auto check and
    enable it
     > if it's 1.5 ).
     > Same goes for JAI and ImageIO. We _can_not_ require these for
    everyone.
     > We used to do this, and it was a nightmare, adoption shot up when
     > these weren't required. I'm all for encouraging people to
    install them,
     > but we need a default that works fine without them. Ideally
    include the
     > jars, but if the installed version is there be able to use it. Less
     > ideally have people remove the jars when they install the native
    ones.
     > We can also make it so the windows installer puts the windows native
     > ones by default, which may help as well.
     > > - When start the Web Container (jatty, Tomcat, ...) use the
    following
     > > JVM arguments to have better performances:
     > > -Xms256M -Xmx512M -Dorg.geotools.referencing.forceXY=true
     > Is it ok to set forceXY for all cases? Like should we set this in
     > GeoServer by default? I'm pretty sure you can set system properties
     > from within java on start up.
     > > - The map producers have been replaced with others that use
    enhanced JAI
     > > and ImageIO functions. We are conducting tests on image sizes and
     > > setting better compression/quality parameters and at this
    moment we have
     > > smaller and coolest images than the previous release (we will
    post the
     > > test results soon).
     > That's great. Some users really like small image sizes, indeed
    we had
     > bigger sizes for 1.3. So if we can get that as small as possible and
     > still look very good that's great news.
     > best regards,
     > Chris
     > > Eng. Alessio Fabiani
     > > Vice President/CTO GeoSolutions
     > > http://www.geo-solutions.it
    <http://www.geo-solutions.it>>
     > > Using Tomcat but need to do more? Need to support web services,
    security?
     > > Get stuff done quickly with pre-integrated technology to make
    your job easier
     > > Download IBM WebSphere Application Server v.1.0.1 based on
    Apache Geronimo
    <http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642&gt;
     > > !DSPAM:1003,4535f407159101362196140!
     > > _______________________________________________
     > > Geoserver-devel mailing list
     > > Geoserver-devel@lists.sourceforge.net
    <mailto:Geoserver-devel@lists.sourceforge.net>
     > > https://lists.sourceforge.net/lists/listinfo/geoserver-devel
     > Chris Holmes
     > The Open Planning Project
     > http://topp.openplans.org
    security?
    your job easier
     > Download IBM WebSphere Application Server v.1.0.1 based on Apache
    Geronimo
    security?
    job easier
    Geronimo
--------------------------------------------------------- !DSPAM:1003,453647ec208722223018498!
Chris Holmes
To my surprise I notice that some of my ows4 work has made its way to
trunk? In particular the community modules web2, and wfs2.
Alessio: Have you been syncing up 1.4.x_wcs_branch with trunk and 1.5.x?
-Justin
Cool.
Chris
just
    fine.
    Alex
     > Nice!
1.5.x, JAI
    WFS and
    but it
    enable it
     > if it's 1.5 ).
    everyone.
when
    install them,
    include the
Less
    ones.
native
    following
properties
    enhanced JAI
and
    moment we have
    post the
    we had
possible and
     > best regards,
     > Chris
    security?
    your job easier
    Apache Geronimo
     > Chris Holmes
    security?
    your job easier
    Geronimo
    security?
    job easier
    Geronimo
easier
Geronimo
!DSPAM:1004,45364df2212381116498154!
Justin Deoliveira
jdeolive@anonymised.com
The map producers don’t require native acceleration, so the JAI/ImageIO jars are enough to let them work perfectly.
Moreover in the UI there are some options that let the user explicity saying to the producers if use or not native acceleration and soon several quality/compression params for some image formats too.
    Ok, then let’s document as such. Not required, but recommended for WCS.
    Cool.
Chris
fine.
Alex
Nice!
    WFS and
    but it
    enable it
    if it’s 1.5 ).
everyone.
install them,
include the
ones.
    following
    enhanced JAI
    moment we have
    post the
    test results soon).
    we had
best regards,
Chris
http://www.geo-solutions.it < http://www.geo-solutions.it
security?
your job easier
Apache Geronimo
<http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642 >
mailto:[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
Chris Holmes
security?
your job easier
Geronimo
<http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642>
security?
job easier
Geronimo
< http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642>
Chris Holmes
Hi Justin …
On 10/18/06, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Alessio: Have you been syncing up 1.4.x_wcs_branch with trunk and 1.5.x ?
…yes!
-Justin
    Cool.
Chris
On 10/18/06, Alexander Petkov < greenkov@anonymised.com
just
fine.
Alex
Nice!
    1.5.x, JAI
    WFS and
    but it
    enable it
    if it’s 1.5 ).
everyone.
when
install them,
include the
Less
ones.
native
    following
    -Xms256M -Xmx512M - Dorg.geotools.referencing.forceXY=true
    properties
    enhanced JAI
    and
    moment we have
    post the
    test results soon).
    we had
    possible and
best regards,
Chris
< http://www.geo-solutions.it>>
security?
your job easier
Apache Geronimo
Chris Holmes
security?
your job easier
Geronimo
security?
job easier
Geronimo
easier
Geronimo
Justin Deoliveira
Ok, I am probably going to remove some stuff then, like the community
modules sine they wont compile on trunk. Most of the other stuff hasn't
changed though so no big deal.
-Justin
Hi Justin ...
On 10/18/06, *Justin Deoliveira* <jdeolive@anonymised.com
<mailto:jdeolive@anonymised.com>> wrote:
    1.5.x ?
...yes!
    -Justin
    >> - Java 1.5 is not a requirement, but things work much better
    using this.
    > Ok, then let's document as such. Not required, but recommended
    for WCS.
    >> - We can even restore the old map producers which don't require
    >> JAI/ImageIO, but GeoServer 1.5.x code like GeoTools 2.3.x are thought
    >> to highly improve performances and quality by using those two
    >> libraries. Maybe we can write a good installation guide for less
    >> expert users. We should speak about this at meeting I think.
    > Will the new map producers work with the jar versions of
    jai/imageio? Or
    > are they too slow with the jars? It could be good to keep both
    > producers around, just rename the old ones so you use something
    else to
    > request them. Installation guides are definitely essential, but
    we for
    > sure need to have something that works out of the box, and then
    they can
    > upgrade if they want more performance.
    >> - With latest changes org.geotools.referencing.forceXY option should
    >> not be a requirement, but again it depends on Geotools and the Axis
    >> order issue, so I suggest to use this option for a while, not
    forever.
    > Cool.
    > Chris
    >> On 10/18/06, *Alexander Petkov* < greenkov@anonymised.com
    >> <mailto:greenkov@anonymised.com>> wrote:
    >> I am not sure about the Java 5 requirement--just yesterday I
    compiled
    >> the wcs-1.4.x merge branch with java 1.4, it seemed to be working
    >> just
    >> fine.
    >> Alex
    >> On 10/18/06, Chris Holmes < cholmes@anonymised.com
    >> <mailto:cholmes@anonymised.com
    <mailto:cholmes@anonymised.com>>> wrote:
    >> > Alessio Fabiani wrote:
    >> > > The porting is done, GeoServer 1.5.x is ready to go!
    >> > Nice!
    >> > A couple notes on things we need to get to 1.5.0...
    >> > > - In order to compile and run it correctly you need Java
    >> 1.5.x, JAI
    >> > > 1.1.4+ and ImageIO 1.1+
    >> > These requirements are a bit much. At the very least we
    need a
    >> WFS and
    >> > WMS that can run on Java 1.4. I'm fine if the WCS
    requires 1.5,
    >> but it
    >> > would be really nice if it could do 1.4, so that we don't
    have to
    >> > disable it by default (I suppose we could do an auto check and
    >> enable it
    >> > if it's 1.5 ).
    >> > Same goes for JAI and ImageIO. We _can_not_ require these
    for
    >> everyone.
    >> > We used to do this, and it was a nightmare, adoption shot up
    >> when
    >> > these weren't required. I'm all for encouraging people to
    >> install them,
    >> > but we need a default that works fine without them. Ideally
    >> include the
    >> > jars, but if the installed version is there be able to use it.
    >> Less
    >> > ideally have people remove the jars when they install the
    native
    >> ones.
    >> > We can also make it so the windows installer puts the windows
    >> native
    >> > ones by default, which may help as well.
    >> > > - When start the Web Container (jatty, Tomcat, ...) use the
    >> following
    >> > > JVM arguments to have better performances:
    >> > > -Xms256M -Xmx512M - Dorg.geotools.referencing.forceXY=true
    >> > Is it ok to set forceXY for all cases? Like should we set
    this in
    >> > GeoServer by default? I'm pretty sure you can set system
    >> properties
    >> > from within java on start up.
    >> > > - The map producers have been replaced with others that use
    >> enhanced JAI
    >> > > and ImageIO functions. We are conducting tests on image
    sizes
    >> and
    >> > > setting better compression/quality parameters and at this
    >> moment we have
    >> > > smaller and coolest images than the previous release (we
    will
    >> post the
    >> > > test results soon).
    >> > That's great. Some users really like small image sizes,
    indeed
    >> we had
    >> > bigger sizes for 1.3. So if we can get that as small as
    >> possible and
    >> > still look very good that's great news.
    >> > best regards,
    >> > Chris
    >> > > Eng. Alessio Fabiani
    >> > > Vice President/CTO GeoSolutions
    >> > > http://www.geo-solutions.it
    >> < http://www.geo-solutions.it>>
    >> > > Using Tomcat but need to do more? Need to support web
    services,
    >> security?
    >> > > Get stuff done quickly with pre-integrated technology to
    make
    >> your job easier
    >> > > Download IBM WebSphere Application Server v.1.0.1 based on
    >> Apache Geronimo
    <http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642&gt;&gt;
    >> > > _______________________________________________
    >> > > Geoserver-devel mailing list
    >> > > Geoserver-devel@lists.sourceforge.net
    >> <mailto:Geoserver-devel@lists.sourceforge.net
    <mailto:Geoserver-devel@lists.sourceforge.net>>
    >> > > https://lists.sourceforge.net/lists/listinfo/geoserver-devel
    >> > Chris Holmes
    >> > The Open Planning Project
    >> > http://topp.openplans.org
    >> > Using Tomcat but need to do more? Need to support web
    services,
    >> security?
    >> > Get stuff done quickly with pre-integrated technology to make
    >> your job easier
    >> > Download IBM WebSphere Application Server v.1.0.1 based on
    Apache
    >> Geronimo
    >> > _______________________________________________
    >> > Geoserver-devel mailing list
    >> > Geoserver-devel@lists.sourceforge.net
    >> > https://lists.sourceforge.net/lists/listinfo/geoserver-devel
    >> Using Tomcat but need to do more? Need to support web services,
    >> security?
    >> Get stuff done quickly with pre-integrated technology to make
    your
    >> job easier
    >> Download IBM WebSphere Application Server v.1.0.1 based on Apache
    >> Geronimo
    >> _______________________________________________
    >> Geoserver-devel mailing list
    >> Geoserver-devel@lists.sourceforge.net
    >> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
    <https://lists.sourceforge.net/lists/listinfo/geoserver-devel&gt;
    >> Eng. Alessio Fabiani
    >> Vice President/CTO GeoSolutions
    >> http://www.geo-solutions.it
    >> !DSPAM:1003,453647ec208722223018498!
    security?
    your job
    >> easier
    >> Geronimo
    security?
    > Get stuff done quickly with pre-integrated technology to make your
    job easier
    Geronimo
    > !DSPAM:1004,45364df2212381116498154!
    Justin Deoliveira
    jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>
    security?
    job easier
    Geronimo
!DSPAM:1004,453729989271804284693!
Justin Deoliveira
We should perhaps delete all the old WCS branches at this point? So that they don't confuse users? (of course they will remain within svn, just not visible at current revisions).
Also did we get the check out docs updated? On the main WCS page? To point at trunk?
One last thing, let's try to keep questions to one of the two mail lists. If it's a question about development (at this point that'd probably be anything but the simplest WCS questions, since it's not yet at beta1), about actually changing code and whatnot, it should go to devel. Most threads started by committers should go to devel, unless it's specifically to get feedback from users. If it's a user question then send it to the list. It's good to update users on big things, like when a merge is completed, but they don't need the moment to moment updates.
Chris
Hi Vincent,
you are right.
On 10/20/06, *Vincent Schut* <schut@anonymised.com <mailto:schut@anonymised.com>> wrote:
    Vincent.
     > We are still finishing some stress tests, but all seems ok.
     > Some notes:
     > - The project is based on GeoTools 2.3.x branch (actually
     > 2.3.0-rc1-SNAPSHOT) [
    following
     > - The map producers have been replaced with others that use enhanced
     > JAI and ImageIO functions. We are conducting tests on image sizes
    and
     > setting better compression/quality parameters and at this moment we
     > have smaller and coolest images than the previous release (we will
     > post the test results soon).
    security?
    your job easier
    Geronimo
     > Geoserver-users mailing list
     > Geoserver-users@lists.sourceforge.net
    <mailto:Geoserver-users@lists.sourceforge.net>
     > https://lists.sourceforge.net/lists/listinfo/geoserver-users
--------------------------------------------------------- !DSPAM:1003,4538a52335101116498154!
Chris Holmes
