[Geoserver-users] Websphere & Geoserver installation
I have installed Websphere 2.1.1.2 on my Ubuntu Linux machine. Also i downloaded geoserver-1.7.5-war .
I deployed this geoserver war in websphere. It is succesfully deployed. But when i am trying to start geoserver service.
It is giving me “Lifecycle operation failed”.
Also i am pasting server log details.
Help on this will be appreciated.
6214: 2009-07-29 16:14:35,182 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name ‘geoServerLoader’: org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name ‘wmsLoader’: Singleton bean creation not allowed while the singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
6215: 2009-07-29 16:14:35,212 ERROR [context.ContextLoader] - Context initialization failed
6364: 2009-07-29 16:14:35,218 ERROR [0].[/geoserver]] - Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
6513: 2009-07-29 16:14:35,222 ERROR [core.StandardContext] - Error listenerStart
6514: 2009-07-29 16:14:35,222 ERROR [core.StandardContext] - Context [/geoserver] startup failed due to previous errors
6515: 2009-07-29 16:14:35,227 ERROR [core.ContainerBase] - ContainerBase.addChild: start:
6592: 2009-07-29 16:14:35,231 WARN [tomcat.TomcatWebAppContext] - TomcatWebAppContext failed
6593: 2009-07-29 16:14:35,231 ERROR [runtime.GBeanInstanceState] - Error while starting; GBean is now in the FAILED state: abstractName=“default/geoserver/1248792566416/war?J2EEApplication=null,j2eeType=WebModule,name=default/geoserver/1248792566416/war”
6669: 2009-07-29 16:14:35,237 ERROR [configmanager.ConfigManagerPortlet] - Lifecycle operation failed
Best Regards,
kanhaiya kale (KK)
IndicTrans Technologies, Pune
http://kanhaiya.indictrans.in
I think you mean the Websphere Community Edition which has nothing to do with the Websphere commerical products.
Asfaik the community edition uses tomcat as a Servlet Engine. You can try to install tomcat and deploy geoserver and look if you get this error again. If you get it, search for resolving the problem with tomcat, there are many more tomcat users out there.
[UTF-8] Kanhaiya kale ( कન્હૈযা ਕਾளெ ) writes:
It is giving me "Lifecycle operation failed".
**6214: 2009-07-29 16:14:35,182 WARN [support.DisposableBeanAdapter] -
Invocation of destroy method failed on bean with name 'geoServerLoader':
creating bean with name 'wmsLoader': Singleton bean creation not allowed
bean from a BeanFactory in a destroy method implementation!)* *6215:
initialization failed* *6364: 2009-07-29 16:14:35,218 ERROR
instance of class
org.springframework.web.context.ContextLoaderListener* *6513:
2009-07-29 16:14:35,222 ERROR [core.StandardContext] - Error listenerStart*
*6514: 2009-07-29 16:14:35,222 ERROR [core.StandardContext] - Context
[/geoserver] startup failed due to previous errors* *6515: 2009-07-29
16:14:35,227 ERROR [core.ContainerBase] - ContainerBase.addChild: start: *
*6592: 2009-07-29 16:14:35,231 WARN [tomcat.TomcatWebAppContext] -
TomcatWebAppContext failed* *6593: 2009-07-29 16:14:35,231 ERROR
FAILED state:
abstractName="default/geoserver/1248792566416/war?J2EEApplication=null,j2eeType=WebModule,name=default/geoserver/1248792566416/war"
* *6669: 2009-07-29 16:14:35,237 ERROR
[configmanager.ConfigManagerPortlet] - Lifecycle operation failed *
Best Regards,
kanhaiya kale (KK)
Yes i am using Websphere community edition.
Geoserver with tomact is working great. i am using it from last month.
Now i want to make geoserver working on websphere.
On Wed, Jul 29, 2009 at 5:05 PM, Christian Müller <christian.mueller@anonymised.com> wrote:
6215:
instance of class
6513:
*6515: 2009-07-29
FAILED state:
  • *6669: 2009-07-29 16:14:35,237 ERROR
Best Regards,
kanhaiya kale (KK)
kanhaiya kale (KK)
1)
According to
http://www-01.ibm.com/software/webservers/appserv/community/features/?S_CMP= wspace
Tomcat V6.0.18 is used. Did you try with this version ?
2)
I assume, Websphere is working with an IBM java runtime. Have you ever tried to use the IBM java with your working tomcat deployment. Personally, I have some troubles using the ibm jdk, especially the java 6 version.
[UTF-8] Kanhaiya kale ( ....... .... ) writes:
But
listener
instance of class
listenerStart*
FAILED state:
Best Regards,
kanhaiya kale (KK)
kanhaiya kale (KK)
On Wed, Jul 29, 2009 at 6:14 PM, Christian Müller <christian.mueller@anonymised.com> wrote:
According to
Yes i am using this version only.
I downloaded the package of websphere which was containing ibm-java2-i386-sdk_5.0-10_i386 with it.
That means i used java of IBM only.
On Wed, Jul 29, 2009 at 5:05 PM, Christian Müller <christian.mueller@anonymised.com…
[UTF-8] Kanhaiya kale ( … … ) writes:
But
6215:
listener
instance of class
6513:
listenerStart
*6515: 2009-07-29
FAILED state:
    Best Regards,
    kanhaiya kale (KK)
kanhaiya kale (KK)
kanhaiya kale (KK)
What operating system do you use ?
wrote:
1)
According to
http://www-01.ibm.com/software/webservers/appserv/community/features/?S_CMP=wspace
2)
again.
many
But
a
listener
instance of class
listenerStart*
FAILED state:
Best Regards,
kanhaiya kale (KK)
kanhaiya kale (KK)
kanhaiya kale (KK)
Ubuntu Jaunty
On Wed, Jul 29, 2009 at 6:43 PM, Christian Müller <christian.mueller@anonymised.com> wrote:
On Wed, Jul 29, 2009 at 6:14 PM, Christian Müller <christian.mueller@anonymised.com…
wrote:
According to
again.
many
But
a
6215:
listener
instance of class
6513:
listenerStart
*6515: 2009-07-29
FAILED state:
    Best Regards,
    kanhaiya kale (KK)
kanhaiya kale (KK)
kanhaiya kale (KK)
kanhaiya kale (KK)
To be sure:
can you start your tomcat and execute a
ps -ef | grep java
afterwards stop tomcat and start websphere and again
ps -ef | grep java
You should see the full java path. What is it ?
Ubuntu Jaunty
wrote:
1)
According to
2)
Personally, I
do
try
again.
many
deployed.
But
'geoServerLoader':
Error
allowed
request
a
listener
instance of class
listenerStart*
2009-07-29
start:
the
FAILED state:
Best Regards,
kanhaiya kale (KK)
kanhaiya kale (KK)
kanhaiya kale (KK)
kanhaiya kale (KK)
