On Fri, Jul 29, 2011 at 10:21 AM, Rahkonen Jukka
<Jukka.Rahkonen@anonymised.com> wrote:
Andrea Aime wrote:
On Fri, Jul 29, 2011 at 8:17 AM, Rahkonen Jukka
> Hi,
> Thanks. So I'll pretend I've never read the 1.1.0 standard
and, bona fide, continue to suppose that BBOX behaves like it
does with version 1.0.0.
As usual I have strong opinions
However, if someone really wants that flag and has tight control over
the clients accessing the WFS, and those work the
way the standard was written... well, why not?
It just seems a rather narrow use case
I can see from our server logs that there are some real world clients sending WFS 1.0.0 requests with GET and BBOX as KVP but nobody has been hitting our server by using the combination of WFS 1.1.0 + http GET + BBOX. I believe it would be a really bad idea to make such a client because obviously the BBOX coordinates should still be reversed with some srsNames when using WFS 1.1.0 and nobody could ever make that work with all the projections and against all the different WFS server marks. Thus this is more a theoretical issue and mainly makes mad people like me who are making some hand written requests to be sent through a browser. The http requests with KVP are rather a lot easier to read in tutorials than those with url-encoded filters. At least for me, just compare
&BBOX=3307900,6909392,3541041,7085366
with something like
FILTER=%3Cogc%3AFilter+xmlns%3Aogc%3D%22http%3A%2F%2Fwww.opengis.net%2Fogc%22+xmlns%3Agml%3D%22http%3A%2F%2Fwww.opengis.net%2Fgml%22%3E%3Cogc%3ABBOX%3E%3Cogc%3APropertyName%3Eway%3C%2Fogc%3APropertyName%3E%3Cgml%3AEnvelope%3E%3Cgml%3AlowerCorner%3E232956.28352295642+6611434.046334767%3C%2Fgml%3AlowerCorner%3E%3Cgml%3AupperCorner%3E358186.6317651436+6766767.843673633%3C%2Fgml%3AupperCorner%3E%3C%2Fgml%3AEnvelope%3E%3C%2Fogc%3ABBOX%3E%3C%2Fogc%3AFilter%3E
He he, yep, OGC xml filters are painful.
The easy way out is, I guess, to add the fifth parameter, the crs, to
your requests, and forget
the 4 values version ever existed.
And yeah, I agree that making a protocol were the clients needs a full
fledged EPSG database
to determine the proper axis order has been a mistake on OGC part, it
basically killed away
fully atomated light clients, requiring to hand configure each
instance of them for the limited
set of EPSG codes that one needs (and which has to be foreseen in advance).
Or they could resurrect the coordinate transformation service, but
with an extra showing all
available codes and details of them such as the axis order, projection
and the like: a light
client could then consult it to get the required information.
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
