I have read that Geoserver is quite strict with XML validation, and tries to check everything deeply.
De : Ian Turton [mailto:ijturton@…84…]
Envoyé : mercredi 15 mai 2019 15:01
À : DEGRÈVE Benoît
Cc : geoserver-users@lists.sourceforge.net
Objet : Re: [Geoserver-users] WFS cascade : impossible to publish a layer
Well the layers name is “Centres_et_postes_de_secours:Centres_et_postes_de_secours” so that’s correct. On my machine I get
Caused by: org.geotools.data.DataSourceException: No XSDElementDeclaration found for {https://dservices1.arcgis.com/B0HauZcvLgYIRu8z/arcgis/services/Centres_et_postes_de_secours/WFSServer}Centres_et_postes_de_secours
at org.geotools.data.wfs.internal.parsers.EmfAppSchemaParser.parseFeatureType(EmfAppSchemaParser.java:315)
at org.geotools.data.wfs.internal.parsers.EmfAppSchemaParser.parse(EmfAppSchemaParser.java:223)
at org.geotools.data.wfs.internal.DescribeFeatureTypeResponse.(DescribeFeatureTypeResponse.java:64)
at org.geotools.data.wfs.internal.parsers.DescribeFeatureTypeResponseFactory.createResponse(DescribeFeatureTypeResponseFactory.java:70)
at org.geotools.data.wfs.internal.WFSRequest.createResponse(WFSRequest.java:215)
at org.geotools.data.wfs.internal.WFSRequest.createResponse(WFSRequest.java:36)
at org.geotools.data.ows.AbstractOpenWebService.internalIssueRequest(AbstractOpenWebService.java:446)
at org.geotools.data.wfs.internal.WFSClient.internalIssueRequest(WFSClient.java:313)
at org.geotools.data.wfs.internal.WFSClient.issueRequest(WFSClient.java:374)
at org.geotools.data.wfs.WFSDataStore.getRemoteFeatureType(WFSDataStore.java:206)
at org.geotools.data.wfs.WFSDataStore.getRemoteSimpleFeatureType(WFSDataStore.java:262)
at org.geotools.data.wfs.WFSFeatureSource.buildFeatureType(WFSFeatureSource.java:364)
at org.geotools.data.store.ContentFeatureSource.getAbsoluteSchema(ContentFeatureSource.java:328)
… 135 more
as the root error. That looks like the request to get the DescribeFeatureType is not working - but https://dservices1.arcgis.com/B0HauZcvLgYIRu8z/arcgis/services/Centres_et_postes_de_secours/WFSServer?service=wfs&request=DescribeFeatureType&typeName=Centres_et_postes_de_secours:Centres_et_postes_de_secours does work for me in the browser.
Turning the logging level up gives:
2019-05-15 13:52:52,590 TRACE [org.geotools.data.wfs.requests] - Built GET request for DESCRIBE_FEATURETYPE: https://dservices1.arcgis.com/B0HauZcvLgYIRu8z/arcgis/services/Centres_et_postes_de_secours/WFSServer?NAMESPACE=xmlns%28Centres_et_postes_de_secours%3Dhttps%3A%2F%2Fdservices1.arcgis.com%2FB0HauZcvLgYIRu8z%2Farcgis%2Fservices%2FCentres_et_postes_de_secours%2FWFSServer%29&TYPENAME=Centres_et_postes_de_secours%3ACentres_et_postes_de_secours&REQUEST=DescribeFeatureType&VERSION=2.0.0&SERVICE=WFS
2019-05-15 13:52:52,590 TRACE [org.geotools.data.wfs.requests] - Sending DFT request to https://dservices1.arcgis.com/B0HauZcvLgYIRu8z/arcgis/services/Centres_et_postes_de_secours/WFSServer?NAMESPACE=xmlns%28Centres_et_postes_de_secours%3Dhttps%3A%2F%2Fdservices1.arcgis.com%2FB0HauZcvLgYIRu8z%2Farcgis%2Fservices%2FCentres_et_postes_de_secours%2FWFSServer%29&TYPENAME=Centres_et_postes_de_secours%3ACentres_et_postes_de_secours&REQUEST=DescribeFeatureType&VERSION=2.0.0&SERVICE=WFS
2019-05-15 13:52:52,590 TRACE [org.geotools.data.wfs] - Looking operation URI for DESCRIBE_FEATURETYPE/GET
2019-05-15 13:52:52,590 DEBUG [org.geotools.data.wfs] - Returning operation URI for DESCRIBE_FEATURETYPE/GET: https://dservices1.arcgis.com/B0HauZcvLgYIRu8z/arcgis/services/Centres_et_postes_de_secours/WFSServer?
2019-05-15 13:52:52,714 DEBUG [org.geotools.xml] - looking up schema for http://www.opengis.net/gml
2019-05-15 13:52:52,714 DEBUG [org.geotools.xml] - schema location: jar:file:/var/lib/tomcat8/webapps/geoserver-2.14/WEB-INF/lib/gt-xsd-gml3-20.0.jar!/org/geotools/gml3/gml.xsd
2019-05-15 13:52:52,714 DEBUG [org.geotools.xml] - looking up schema for http://www.w3.org/2001/XMLSchema
2019-05-15 13:52:52,715 DEBUG [org.geotools.xml] - schema location: jar:file:/var/lib/tomcat8/webapps/geoserver-2.14/WEB-INF/lib/gt-xsd-core-20.0.jar!/org/geotools/xs/XMLSchema.xsd
2019-05-15 13:52:52,715 DEBUG [org.geotools.xml] - looking up schema for https://dservices1.arcgis.com/B0HauZcvLgYIRu8z/arcgis/services/Centres_et_postes_de_secours/WFSServer
2019-05-15 13:52:52,715 DEBUG [org.geotools.xml] - schema location: file:/tmp/tomcat8-tomcat8-tmp/Centres_et_postes_de_secours1278202874594256203.xsd
2019-05-15 13:52:52,715 DEBUG [org.geotools.xml] - building schema for schema: https://dservices1.arcgis.com/B0HauZcvLgYIRu8z/arcgis/services/Centres_et_postes_de_secours/WFSServer
2019-05-15 13:52:52,717 DEBUG [org.geotools.xml] - Could not locate schema for: http://schemas.opengis.net/gml/3.2.1/gml.xsd.
2019-05-15 13:52:52,956 DEBUG [org.geotools.xml] - Could not resolve schema location: dynamicFeature.xsd to physical location.
2019-05-15 13:52:52,956 DEBUG [org.geotools.xml] - Could not locate schema for: dynamicFeature.xsd.
2019-05-15 13:52:52,957 DEBUG [org.geotools.xml] - Could not resolve schema location: topology.xsd to physical location.
2019-05-15 13:52:52,957 DEBUG [org.geotools.xml] - Could not locate schema for: topology.xsd.
2019-05-15 13:52:52,957 DEBUG [org.geotools.xml] - Could not resolve schema location: coverage.xsd to physical location.
2019-05-15 13:52:52,957 DEBUG [org.geotools.xml] - Could not locate schema for: coverage.xsd.
2019-05-15 13:52:52,957 DEBUG [org.geotools.xml] - Could not resolve schema location: coordinateReferenceSystems.xsd to physical location.
2019-05-15 13:52:52,957 DEBUG [org.geotools.xml] - Could not locate schema for: coordinateReferenceSystems.xsd.
2019-05-15 13:52:52,957 DEBUG [org.geotools.xml] - Could not resolve schema location: observation.xsd to physical location.
2019-05-15 13:52:52,957 DEBUG [org.geotools.xml] - Could not locate schema for: observation.xsd.
2019-05-15 13:52:52,958 DEBUG [org.geotools.xml] - Could not resolve schema location: temporalReferenceSystems.xsd to physical location.
2019-05-15 13:52:52,958 DEBUG [org.geotools.xml] - Could not locate schema for: temporalReferenceSystems.xsd.
2019-05-15 13:52:52,958 DEBUG [org.geotools.xml] - Could not resolve schema location: deprecatedTypes.xsd to physical location.
2019-05-15 13:52:52,958 DEBUG [org.geotools.xml] - Could not locate schema for: deprecatedTypes.xsd.
2019-05-15 13:52:52,959 DEBUG [org.geotools.xml] - looking up schema for http://www.w3.org/2001/SMIL20/Language
2019-05-15 13:52:52,959 DEBUG [org.geotools.xml] - schema location: jar:file:/var/lib/tomcat8/webapps/geoserver-2.14/WEB-INF/lib/gt-xsd-gml3-20.0.jar!/org/geotools/gml3/smil/smil20-language.xsd
2019-05-15 13:52:52,959 DEBUG [org.geotools.xml] - looking up schema for http://www.w3.org/1999/xlink
2019-05-15 13:52:52,959 DEBUG [org.geotools.xml] - schema location: jar:file:/var/lib/tomcat8/webapps/geoserver-2.14/WEB-INF/lib/gt-xsd-core-20.0.jar!/org/geotools/xlink/xlinks.xsd
2019-05-15 13:52:52,959 DEBUG [org.geotools.xml] - schema location: jar:file:/var/lib/tomcat8/webapps/geoserver-2.14/WEB-INF/lib/gt-xsd-gml3-20.0.jar!/org/geotools/gml3/smil/smil20.xsd
2019-05-15 13:52:52,960 ERROR [org.geotools.data.ows] - Failed to execute request https://dservices1.arcgis.com/B0HauZcvLgYIRu8z/arcgis/services/Centres_et_postes_de_secours/WFSServer?NAMESPACE=xmlns%28Centres_et_postes_de_secours%3Dhttps%3A%2F%2Fdservices1.arcgis.com%2FB0HauZcvLgYIRu8z%2Farcgis%2Fservices%2FCentres_et_postes_de_secours%2FWFSServer%29&TYPENAME=Centres_et_postes_de_secours%3ACentres_et_postes_de_secours&REQUEST=DescribeFeatureType&VERSION=2.0.0&SERVICE=WFS
So it seems as though the XSD file returned is invalid but I’m not sure why
(All the above were with the arcgis strategy)
Ian
On Wed, 15 May 2019 at 13:19, DEGRÈVE Benoît <b.degreve@…9849…> wrote:
My configuration :
Apache Tomcat/8.5.14 (Debian)
Geoserver 2.14.0
WFS capabilities URL : https://dservices1.arcgis.com/B0HauZcvLgYIRu8z/arcgis/services/Centres_et_postes_de_secours/WFSServer?service=wfs&request=getcapabilities
I try to cascade and publish a WFS layer but I always get the same error, even after playing with the store parameters (WFS versions, protocol strategy, etc…)
Via browser : no problem
Via QGIS (3.6 Noosa) : no problem. And, first saved as a shapefile and then exported in PostgreSQL, I can add it in Geoserver as a PostGIS store and previsualize it.
REM : just befor publishing the layer, the layer name is a bit weird : « Centres_et_postes_de_secours_Centres_et_postes_de_secours », as if the name were doubled with a namespace prefix (the typename to use in a GetFeature with a simple URL in the browser is « Centres_et_postes_de_secours :Centres_et_postes_de_secours » and the XML response is OK with all the features)
I suspect an issue with the layer name containing underscores, maybe…
Any idea ?
Geoserver error :
Caused by: org.geotools.data.DataSourceException: No XSDElementDeclaration found for {https://dservices1.arcgis.com/B0HauZcvLgYIRu8z/arcgis/services/Centres_et_postes_de_secours/WFSServer}Centres_et_postes_de_secours at org.geotools.data.wfs.internal.parsers.EmfAppSchemaParser.parseFeatureType(EmfAppSchemaParser.java:315) at org.geotools.data.wfs.internal.parsers.EmfAppSchemaParser.parse(EmfAppSchemaParser.java:223) at org.geotools.data.wfs.internal.DescribeFeatureTypeResponse.(DescribeFeatureTypeResponse.java:64) at org.geotools.data.wfs.internal.parsers.DescribeFeatureTypeResponseFactory.createResponse(DescribeFeatureTypeResponseFactory.java:70) at org.geotools.data.wfs.internal.WFSRequest.createResponse(WFSRequest.java:215) at org.geotools.data.wfs.internal.WFSRequest.createResponse(WFSRequest.java:36) at org.geotools.data.ows.AbstractOpenWebService.internalIssueRequest(AbstractOpenWebService.java:446) at org.geotools.data.wfs.internal.WFSClient.internalIssueRequest(WFSClient.java:313) at org.geotools.data.wfs.internal.WFSClient.issueRequest(WFSClient.java:374) at org.geotools.data.wfs.WFSDataStore.getRemoteFeatureType(WFSDataStore.java:206) at org.geotools.data.wfs.WFSDataStore.getRemoteSimpleFeatureType(WFSDataStore.java:262) at org.geotools.data.wfs.WFSFeatureSource.buildFeatureType(WFSFeatureSource.java:361) at org.geotools.data.store.ContentFeatureSource.getAbsoluteSchema(ContentFeatureSource.java:328) … 135 more
Geoserver log (VERBOSE mode, and, well, what I think is the most relevant of the problem…) :
2019-05-15 13:17:13,426 TRACE [data.wfs] - Looking operation URI for DESCRIBE_FEATURETYPE/GET
2019-05-15 13:17:13,426 DEBUG [data.wfs] - Returning operation URI for DESCRIBE_FEATURETYPE/GET: https://dservices1.arcgis.com/B0HauZcvLgYIRu8z/arcgis/services/Centres_et_postes_de_secours/WFSServer?
2019-05-15 13:17:13,426 TRACE [wfs.requests] - Built GET request for DESCRIBE_FEATURETYPE: https://dservices1.arcgis.com/B0HauZcvLgYIRu8z/arcgis/services/Centres_et_postes_de_secours/WFSServer?NAMESPACE=xmlns%28Centres_et_postes_de_secours%3Dhttps%3A%2F%2Fdservices1.arcgis.com%2FB0HauZcvLgYIRu8z%2Farcgis%2Fservices%2FCentres_et_postes_de_secours%2FWFSServer%29&TYPENAME=Centres_et_postes_de_secours%3ACentres_et_postes_de_secours&REQUEST=DescribeFeatureType&VERSION=2.0.0&SERVICE=WFS
2019-05-15 13:17:13,688 DEBUG [geotools.xml] - looking up schema for http://www.opengis.net/gml
2019-05-15 13:17:13,688 DEBUG [geotools.xml] - schema location: jar:file:/var/lib/tomcat8/webapps/geoserver/WEB-INF/lib/gt-xsd-gml3-20.0.jar!/org/geotools/gml3/gml.xsd
2019-05-15 13:17:13,688 DEBUG [geotools.xml] - looking up schema for http://www.w3.org/2001/XMLSchema
2019-05-15 13:17:13,688 DEBUG [geotools.xml] - schema location: jar:file:/var/lib/tomcat8/webapps/geoserver/WEB-INF/lib/gt-xsd-core-20.0.jar!/org/geotools/xs/XMLSchema.xsd
2019-05-15 13:17:13,688 DEBUG [geotools.xml] - looking up schema for https://dservices1.arcgis.com/B0HauZcvLgYIRu8z/arcgis/services/Centres_et_postes_de_secours/WFSServer
2019-05-15 13:17:13,688 DEBUG [geotools.xml] - schema location: file:/tmp/tomcat8-tomcat8-tmp/Centres_et_postes_de_secours5178680691756999280.xsd
2019-05-15 13:17:13,688 DEBUG [geotools.xml] - building schema for schema: https://dservices1.arcgis.com/B0HauZcvLgYIRu8z/arcgis/services/Centres_et_postes_de_secours/WFSServer
2019-05-15 13:17:13,693 DEBUG [geotools.xml] - Could not locate schema for: http://schemas.opengis.net/gml/3.2.1/gml.xsd.
2019-05-15 13:17:18,948 DEBUG [geotools.xml] - Could not resolve schema location: dynamicFeature.xsd to physical location.
2019-05-15 13:17:18,948 DEBUG [geotools.xml] - Could not locate schema for: dynamicFeature.xsd.
2019-05-15 13:17:18,949 DEBUG [geotools.xml] - Could not resolve schema location: topology.xsd to physical location.
2019-05-15 13:17:18,949 DEBUG [geotools.xml] - Could not locate schema for: topology.xsd.
2019-05-15 13:17:18,949 DEBUG [geotools.xml] - Could not resolve schema location: coverage.xsd to physical location.
2019-05-15 13:17:18,949 DEBUG [geotools.xml] - Could not locate schema for: coverage.xsd.
2019-05-15 13:17:18,949 DEBUG [geotools.xml] - Could not resolve schema location: coordinateReferenceSystems.xsd to physical location.
2019-05-15 13:17:18,949 DEBUG [geotools.xml] - Could not locate schema for: coordinateReferenceSystems.xsd.
2019-05-15 13:17:18,949 DEBUG [geotools.xml] - Could not resolve schema location: observation.xsd to physical location.
2019-05-15 13:17:18,949 DEBUG [geotools.xml] - Could not locate schema for: observation.xsd.
2019-05-15 13:17:18,949 DEBUG [geotools.xml] - Could not resolve schema location: temporalReferenceSystems.xsd to physical location.
2019-05-15 13:17:18,949 DEBUG [geotools.xml] - Could not locate schema for: temporalReferenceSystems.xsd.
2019-05-15 13:17:18,950 DEBUG [geotools.xml] - Could not resolve schema location: deprecatedTypes.xsd to physical location.
2019-05-15 13:17:18,950 DEBUG [geotools.xml] - Could not locate schema for: deprecatedTypes.xsd.
2019-05-15 13:17:18,951 DEBUG [geotools.xml] - looking up schema for http://www.w3.org/2001/SMIL20/Language
2019-05-15 13:17:18,951 DEBUG [geotools.xml] - schema location: jar:file:/var/lib/tomcat8/webapps/geoserver/WEB-INF/lib/gt-xsd-gml3-20.0.jar!/org/geotools/gml3/smil/smil20-language.xsd
2019-05-15 13:17:18,951 DEBUG [geotools.xml] - looking up schema for http://www.w3.org/1999/xlink
2019-05-15 13:17:18,951 DEBUG [geotools.xml] - schema location: jar:file:/var/lib/tomcat8/webapps/geoserver/WEB-INF/lib/gt-xsd-core-20.0.jar!/org/geotools/xlink/xlinks.xsd
2019-05-15 13:17:18,952 DEBUG [geotools.xml] - schema location: jar:file:/var/lib/tomcat8/webapps/geoserver/WEB-INF/lib/gt-xsd-gml3-20.0.jar!/org/geotools/gml3/smil/smil20.xsd
2019-05-15 13:17:18,952 ERROR [data.ows] - Failed to execute request https://dservices1.arcgis.com/B0HauZcvLgYIRu8z/arcgis/services/Centres_et_postes_de_secours/WFSServer?NAMESPACE=xmlns%28Centres_et_postes_de_secours%3Dhttps%3A%2F%2Fdservices1.arcgis.com%2FB0HauZcvLgYIRu8z%2Farcgis%2Fservices%2FCentres_et_postes_de_secours%2FWFSServer%29&TYPENAME=Centres_et_postes_de_secours%3ACentres_et_postes_de_secours&REQUEST=DescribeFeatureType&VERSION=2.0.0&SERVICE=WFS
Benoît
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Ian Turton
