[Geoserver-users] wfs gerefature propertyName problem
I'm trying to download .csv file using GetFeature request (request below).
Two attributes are specified in propertyName option, but I'm still getting
two more columns (FID and unitID) in the .csv file. Is there some way to get
rid of them?
http://<%= GeoServer %>:<%= GeoServerPort
%>/geoserver/IF/ows?service=WFS&version=1.0.0&request=GetFeature&typeName=<%=
Layer %>&bbox=" + ext +
"&propertyName=name,value&outputFormat=csv&viewparams=<%= ViewParams %>
Thanks!
View this message in context: http://osgeo-org.1560.x6.nabble.com/wfs-gerefature-propertyName-problem-tp5055307.html
I tested against a public available GeoServer instance (which is version 2.3.1) from OpenGeo with the following URL
http://demo.opengeo.org/geoserver/topp/wfs?outputFormat=csv&propertyName=STATE
and POST :
<wfs:GetFeature service=“WFS” version=“1.0.0”
xmlns:topp=“http://www.openplans.org/topp
xmlns:wfs=“http://www.opengis.net/wfs
xmlns:ogc=“http://www.opengis.net/ogc
xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance
xsi:schemaLocation=“http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.1.0/wfs.xsd”>
<wfs:Query typeName=“topp:tasmania_state_boundaries” >
ogc:Filter
<ogc:FeatureId fid=“tasmania_state_boundaries.1”/>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
and can confirm that more properties than the requested are in the resulting csv response. Seems to me that the propertyName property doesn’t work for CSV ouputFormat correctly (maybe unused in this case). Could you raise a bug report in JIRA?
Thanks a lot
2013/5/23 HerrFlick <tomas.mattern@anonymised.com>
I’m trying to download .csv file using GetFeature request (request below).
Two attributes are specified in propertyName option, but I’m still getting
rid of them?
Thanks!
Try New Relic Now & We’ll Send You this Cool Shirt
New Relic is the only SaaS-based application performance monitoring service
that delivers powerful full stack analytics. Optimize and monitor your
browser, app, & servers with just a few lines of code. Try New Relic
and get this awesome Nerd Life shirt! http://p.sf.net/sfu/newrelic_d2d_may
Geoserver-users mailing list
On Fri, May 24, 2013 at 9:53 AM, Frank Gasdorf
and POST :
<wfs:GetFeature service="WFS" version="1.0.0"
  xmlns:topp="http://www.openplans.org/topp&quot;
  xmlns:wfs="http://www.opengis.net/wfs&quot;
  xmlns:ogc="http://www.opengis.net/ogc&quot;
  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
  xsi:schemaLocation="http://www.opengis.net/wfs
                      http://schemas.opengis.net/wfs/1.1.0/wfs.xsd&quot;&gt;
  <wfs:Query typeName="topp:tasmania_state_boundaries" >
    <ogc:Filter>
       <ogc:FeatureId fid="tasmania_state_boundaries.1"/>
    </ogc:Filter>
    </wfs:Query>
</wfs:GetFeature>
resulting csv response. Seems to me that the propertyName property doesn't
Please wait a second. Can you confirm that the extra properties returned
have minOccurs = 1 in the
DescribeFeatureType output?
If they do, it's working as required, mandatory properties in the schema
cannot be stripped out of
the output, it's by WFS spec.
GeoServer reflects the mandatory properties from the database structure
normally, so a way to
make them optional is to mark the columns as nullable.
We presently don't have a way to configure it otherwise from the GUI, but
if memory serves me
right this can be done by writing some schemas by hand:
http://docs.geoserver.org/stable/en/user/services/wfs/schemamapping.html
GeoServer training in Milan, 6th & 7th June 2013! Visit
http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Andrea, you are right, the used feature type has all minOccurs values set to “1” whereas nillable is set to “true”. Later confuses me a bit because mandatory properties which can be null? Or what does it mean if the property nillable is set tu true?
Used request : http://demo.opengeo.org/geoserver/topp/wfs?request=DescribeFeatureType&typeName=topp:tasmania_state_boundaries
2013/5/24 Andrea Aime <andrea.aime@anonymised.com>
and POST :
ogc:Filter
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
Please wait a second. Can you confirm that the extra properties returned have minOccurs = 1 in the
If they do, it’s working as required, mandatory properties in the schema cannot be stripped out of
the output, it’s by WFS spec.
GeoServer reflects the mandatory properties from the database structure normally, so a way to
We presently don’t have a way to configure it otherwise from the GUI, but if memory serves me
GeoServer training in Milan, 6th & 7th June 2013! Visit http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, May 24, 2013 at 10:19 AM, Frank Gasdorf <fgdrf@anonymised.com
to "1" whereas nillable is set to "true". Later confuses me a bit because
Used request :
No no, it means that all properties are optional
I had another look at your request, and it's ill formed: you cannot do a
POST request but do property selection in the url,
mixing the two styles for output format works just by accident.
This one if properly setup, and works as expected:
http://demo.opengeo.org/geoserver/topp/wfs?request=GetFeature&version=1.1.0&service=wfs&typeName=topp:tasmania_state_boundaries&propertyName=STATE&outputFormat=csv
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks! I guess your hint about minOccurs should help to solve the problem. I had a second look at the DescribeFeatureType output and all values set to “0” (and maxOccurs is set to “1”) - sorry for this confusion and the clarification for POST request format itself.
  • Frank
2013/5/24 Andrea Aime <andrea.aime@anonymised.com107…>
On Fri, May 24, 2013 at 10:19 AM, Frank Gasdorf <fgdrf@anonymised.com> wrote:
I had another look at your request, and it’s ill formed: you cannot do a POST request but do property selection in the url,
Ing. Andrea Aime
@geowolf
Technical Lead
BTW, I was wondering about the request URL, first I tried without service=WFS and got an exception that doesn’t say anything about the missing required parameter (http://demo.opengeo.org/geoserver/topp/wfs?request=GetFeature&version=1.0.0&outputFormat=csv&propertyName=STATE&typeName=topp:tasmania_state_boundaries):
<?xml version="1.0" ?>
<ServiceExceptionReport
version=“1.2.0”
xmlns=“http://www.opengis.net/ogc
xsi:schemaLocation=“http://www.opengis.net/ogc http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd”>
java.lang.ClassCastException: java.lang.String cannot be cast to java.util.Collection
I expected to get a response like this:
version=“1.2.0”
Could not determine geoserver request from http request …
Any idea?
2013/5/24 Frank Gasdorf <fgdrf@anonymised.com>
  • Frank
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, May 24, 2013 at 10:44 AM, Frank Gasdorf <fgdrf@anonymised.com
service=WFS and got an exception that doesn't say anything about the
   version="1.2.0"
    xmlns="http://www.opengis.net/ogc&quot;
   xsi:schemaLocation="http://www.opengis.net/ogc
http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd&quot;&gt;
    <ServiceException>
</ServiceException>
</ServiceExceptionReport>
The request was actually determined, but the wrong kvp parser was picked up
because the service was resolved
too late.
I've tried to solve this with this patch
http://jira.codehaus.org/browse/GEOS-4221, but unfortunately did not manage
to commit it back then.
There are a few of these around in GeoServer and GeoTools, where the patch
did not manage to get committed
when it was made, and then was sort of forgotten because it takes more time
than we have to refresh it to the current code.
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks you both for your replies and hints.
OK, when minOccurs is set tu 0 and Nillable to true, it works fine for my
attributes. But there is still the FID column (as well as in your example
with Tasmania). Is it obligatory?
Tomas
View this message in context: http://osgeo-org.1560.x6.nabble.com/wfs-gerefature-propertyName-problem-tp5055307p5055486.html
OK, when minOccurs is set tu 0 and Nillable to true, it works fine for my attributes. But there is still the FID column (as well as in your example with Tasmania). Is it obligatory?
Tomas
View this message in context: Re: wfs gerefature propertyName problem
On Fri, May 24, 2013 at 11:01 AM, HerrFlick <tomas.mattern@anonymised.com> wrote:
Yes, it cannot be removed, most formats have the notion of an identifier
and the
code doing the property selection is shared.
I guess one could roll a vendor option specific for CSV that allows to drop
it...
it would require some coding.
Ing. Andrea Aime
@geowolf
Technical Lead
