Hum, just did a quick test with:
http://gs-stable.geo-solutions.it/geoserver/gs/ows?service=WFS&version=2.0.0&request=GetFeature&typeName=gs%3Any_landmarks&srsName=EPSG:26917&outputFormat=SHAPE-ZIP
The prj returned contains:
PROJCS[“NAD83 / UTM zone 17N”, GEOGCS[“NAD83”, DATUM[“North American Datum 1983”, SPHEROID[“GRS 1980”, 6378137.0, 298.257222101, AUTHORITY[“EPSG”,“7019”]], TOWGS84[0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0], AUTHORITY[“EPSG”,“6269”]], PRIMEM[“Greenwich”, 0.0, AUTHORITY[“EPSG”,“8901”]], UNIT[“degree”, 0.017453292519943295], AXIS[“Geodetic longitude”, EAST], AXIS[“Geodetic latitude”, NORTH], AUTHORITY[“EPSG”,“4269”]], PROJECTION[“Transverse_Mercator”, AUTHORITY[“EPSG”,“9807”]], PARAMETER[“central_meridian”, -81.0], PARAMETER[“latitude_of_origin”, 0.0], PARAMETER[“scale_factor”, 0.9996], PARAMETER[“false_easting”, 500000.0], PARAMETER[“false_northing”, 0.0], UNIT[“m”, 1.0], AXIS[“Easting”, EAST], AXIS[“Northing”, NORTH], AUTHORITY[“EPSG”,“26917”]]
which seems valid.
When opening the shapefile with qgis 3.8 I don’t get an “unkonwn crs” message, but get a bizzarre dialog asking me to
choose the datum shift options… when the WKT is explict about which set to use already:
So odd behavior, but apparently not the same one.
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
