[Geoserver-users] WFS GetFeature with a query limit
hello all,
i'm seeing different behavior in the response to a WFS GetFeature
request when i specify a query limit v/s when i don't but only with
WFS 1.1.0; i.e. 1.0.0 returns the same (correct) result in both
cases. i'm including the test case i used to demonstrate the issue.
the code uses the GeoTools libraries version 2.5.3 and communicates
with a GeoServer 1.6.4b.
my questions which i'd appreciate an answer or guidance from a
GeoServer developer are:
* is this a known issue or i'm doing the wrong thing? if it's the
  latter a push in the right direction is much appreciated.
* i thought of using the buffer-limit attribute with a WFS data
  store in the hope to limit the output and allow the client side
  code to close the store before getting _all_ the features this
  also does not seem to fix the issue. again is it a known issue
  or should i file a bug report.
* in the log/trace file with WFS 1.1 i see the following two
  statements:
    Supported filter: Filter.INCLUDE
    Unsupported filter: Filter.INCLUDE
  is it safe to ignore those statements?
here is the JUnit test case code:
// default package
import java.io.IOException;
import java.io.Serializable;
import java.util.Arrays;
import java.util.HashMap;
import java.util.List;
import java.util.Map;
import junit.framework.TestCase;
import org.geotools.data.DataStore;
import org.geotools.data.DataStoreFinder;
import org.geotools.data.DefaultQuery;
import org.geotools.data.FeatureSource;
import org.geotools.data.wfs.WFSDataStore;
import org.geotools.feature.FeatureCollection;
import org.geotools.feature.FeatureIterator;
import org.opengis.feature.simple.SimpleFeature;
import org.opengis.feature.simple.SimpleFeatureType;
import org.opengis.feature.type.AttributeDescriptor;
public class TestIncludeFilter extends TestCase {
   private static final String BASE_URL =
         "http://localhost:8080/geoserver/wfs?SERVICE=WFS&REQUEST=GetCapabilities";
   private static final String CAPABILITIES_1_0 = BASE_URL + "&VERSION=1.0.0";
   private static final String CAPABILITIES_1_1 = BASE_URL + "&VERSION=1.1.0";
   private static final String LAYER_NAME = "topp:states";
   private static final String ATTRIBUTE_NAMES = new String {
         "STATE_NAME", "STATE_FIPS", "SUB_REGION" };
   private static final int QUERY_LIMIT = 15;
   // default constructor
   public void testVersion1_0() throws IOException {
      // Step 1 - connection parameters
      final Map<String, Serializable> connectionParams =
            new HashMap<String, Serializable>();
      connectionParams.put(
            "WFSDataStoreFactory:GET_CAPABILITIES_URL", CAPABILITIES_1_0);
      _test(connectionParams, 0);
      _test(connectionParams, QUERY_LIMIT);
   public void testVersion1_1_POST() throws IOException {
            "WFSDataStoreFactory:GET_CAPABILITIES_URL", CAPABILITIES_1_1);
// connectionParams.put(
// "WFSDataStoreFactory:BUFFER_SIZE", 5);
      connectionParams.put("WFSDataStoreFactory:PROTOCOL", Boolean.TRUE);
   public void
   _test(final Map<String, Serializable> connectionParams, final int limit)
      // Step 2 - connection
      final WFSDataStore ds =
            (WFSDataStore) DataStoreFinder.getDataStore(connectionParams);
      assertNotNull("Data store MUST NOT be null", ds);
      // Step 3 - discovery
      final List<String> typeNames = Arrays.asList(ds.getTypeNames());
      assertNotNull("Type names MUST NOT be null", typeNames);
      assertFalse("Type names MUST NOT be empty", typeNames.isEmpty());
      assertTrue(
            "Type names MUST contain [" + LAYER_NAME + "]",
            typeNames.contains(LAYER_NAME));
      final SimpleFeatureType schema = ds.getSchema(LAYER_NAME);
      assertNotNull("Feature type (schema) MUST NOT be null", schema);
      final List<AttributeDescriptor> attributes =
            schema.getAttributeDescriptors();
      assertNotNull("Attributes list MUST NOT be null", attributes);
      assertTrue(
            "Attributes list MUST contain at least 3 elements",
            attributes.size() > 2);
      for (final String atName : ATTRIBUTE_NAMES)
         assertTrue(
               "Attribute named [" + atName + "] MUST be found",
               contains(attributes, atName));
      // Step 4 - query
      final int result = process(ds, limit);
      System.out.println("*** result = " + result);
      assertTrue("MUST be able to find at least one feature", result > 0);
   private boolean
   contains(final List<AttributeDescriptor> attributes, final String atName) {
      boolean result = false;
      for (final AttributeDescriptor attribute : attributes)
         if (attribute.getLocalName().equals(atName)) {
            result = true;
            break;
      return result;
   private int process(final DataStore dataStore, final int limit)
      final DefaultQuery q = new DefaultQuery(LAYER_NAME);
      q.setPropertyNames(ATTRIBUTE_NAMES);
      if (limit > 0) q.setMaxFeatures(QUERY_LIMIT);
      final FeatureSource<SimpleFeatureType, SimpleFeature> fs =
            dataStore.getFeatureSource(LAYER_NAME);
      final FeatureCollection<SimpleFeatureType, SimpleFeature> fc =
            fs.getFeatures(q);
      FeatureIterator<SimpleFeature> fit = null;
      int result = 0;
      try {
         for (fit = fc.features(); fit.hasNext():wink: {
            fit.next();
            result++;
      } finally {
         if (fit != null) fc.close(fit);
      System.out.println("*** INCLUDE filter, for "
            + ATTRIBUTE_NAMES.length + " attributes, with "
            + (limit == 0 ? "NO limit" : "a limit of (" + limit + ")")
            + ", found " + result + " feature(s)");
      return result;
TIA + cheers;
rsn
Hi Raif,
I ran the test case you supplied (thanks btw, it was nicely laid out :)) and was able to reproduce the problem.
This is an issue with the wfs 1.1 datastore in geotools. In particular line 367 of WFS_1_1_0_DataStore:
The code as written:
int maxFeatures = Math.min(maxFeaturesHardLimit.intValue(),
       query.getMaxFeatures());
However, maxFeaturesHardLimit == 0 means it is unset. Which means whenever the client does not set a hard limit, and specifies a query limit it will always be zero. A simple fix:
int maxFeatures = maxFeaturesHardLimit.intValue() > 0 ?
     Math.min(maxFeaturesHardLimit.intValue(), query.getMaxFeatures()) :
Feel free to open a jira issue in geotools for this. Gabriel, if you are ok with the fix I will happily commit.
-Justin
Raif S. Naffah wrote:
hello all,
  statements:
// default package
         "http://localhost:8080/geoserver/wfs?SERVICE=WFS&REQUEST=GetCapabilities&quot;;
   public void
      assertTrue(
      assertTrue(
         assertTrue(
      // Step 4 - query
   private boolean
            result = true;
            break;
      return result;
            fs.getFeatures(q);
      int result = 0;
      try {
            fit.next();
            result++;
      } finally {
      return result;
TIA + cheers;
rsn
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
-Strategies to boost innovation and cut costs with open source participation
-Receive a $600 discount off the registration fee with the source code: SFAD
http://p.sf.net/sfu/XcvMzF8H
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
hello Justin,
thank you muchly for your prompt reply! i'll open a JIRA issue just to
be able to track the version of gt/geoserver which will contain the
fix.
On Thu, 19 Feb 2009 03:53:40 pm Justin Deoliveira wrote:
Hi Raif,
-Justin
> hello all,
> issue. the code uses the GeoTools libraries version 2.5.3 and
> communicates with a GeoServer 1.6.4b.
> statements:
> // default package
>ities"; private static final String CAPABILITIES_1_0 = BASE_URL +
> "&VERSION=1.0.0"; private static final String CAPABILITIES_1_1 =
> BASE_URL + "&VERSION=1.1.0"; private static final String LAYER_NAME
> = "topp:states"; private static final String ATTRIBUTE_NAMES =
> new String { "STATE_NAME", "STATE_FIPS", "SUB_REGION" };
> CAPABILITIES_1_0); _test(connectionParams, 0);
> CAPABILITIES_1_1); // connectionParams.put(
> Boolean.TRUE); _test(connectionParams, 0);
> public void
> int limit) throws IOException {
> (WFSDataStore)
> DataStoreFinder.getDataStore(connectionParams); assertNotNull("Data
> Arrays.asList(ds.getTypeNames()); assertNotNull("Type names MUST
> NOT be null", typeNames); assertFalse("Type names MUST NOT be
> empty", typeNames.isEmpty()); assertTrue(
> schema); final List<AttributeDescriptor> attributes =
> attributes); assertTrue(
> assertTrue(
> // Step 4 - query
> result > 0); }
> private boolean
> String atName) { boolean result = false;
> result = true;
> break;
> return result;
> = fs.getFeatures(q);
> int result = 0;
> try {
> fit.next();
> result++;
> } finally {
> ")") + ", found " + result + " feature(s)");
> return result;
cheers;
rsn
On Thu, 19 Feb 2009 04:04:03 pm Raif S. Naffah wrote:
hello Justin,
to be able to track the version of gt/geoserver which will contain
the fix.
done: http://jira.codehaus.org/browse/GEOT-2345
> Hi Raif,
> out
> -Justin
> > hello all,
> > with WFS 1.1.0; i.e. 1.0.0 returns the same (correct) result in
> > both cases. i'm including the test case i used to demonstrate
> > the issue. the code uses the GeoTools libraries version 2.5.3 and
> > the latter a push in the right direction is much appreciated.
> > statements:
> > // default package
> >il ities"; private static final String CAPABILITIES_1_0 = BASE_URL
> > + "&VERSION=1.0.0"; private static final String CAPABILITIES_1_1
> > = BASE_URL + "&VERSION=1.1.0"; private static final String
> > LAYER_NAME = "topp:states"; private static final String
> > ATTRIBUTE_NAMES = new String { "STATE_NAME", "STATE_FIPS",
> > "SUB_REGION" }; private static final int QUERY_LIMIT = 15;
> > public void
> > (WFSDataStore)
> > assertTrue(
> > // Step 4 - query
> > result > 0); }
> > private boolean
> > result = true;
> > break;
> > return result;
> > fc = fs.getFeatures(q);
> > int result = 0;
> > try {
> > fit.next();
> > result++;
> > } finally {
> > return result;
cheers;
rsn
cheers;
rsn
oops,
the fix sounds alright, feel free to apply at your convenience
Gabriel
On Thursday 19 February 2009 02:53:40 Justin Deoliveira wrote:
Hi Raif,
-Justin
hello all,
i’m seeing different behavior in the response to a WFS GetFeature
request when i specify a query limit v/s when i don’t but only with
cases. i’m including the test case i used to demonstrate the issue.
my questions which i’d appreciate an answer or guidance from a
  • is this a known issue or i’m doing the wrong thing? if it’s the
  • i thought of using the buffer-limit attribute with a WFS data
code to close the store before getting all the features this
  • in the log/trace file with WFS 1.1 i see the following two
statements:
// default package
“http://localhost:8080/geoserver/wfs?SERVICE=WFS&REQUEST=GetCapabilities”
“&VERSION=1.0.0”; private static final String CAPABILITIES_1_1 = BASE_URL
  • “&VERSION=1.1.0”; private static final String LAYER_NAME =
“topp:states”;
“STATE_NAME”, “STATE_FIPS”, “SUB_REGION” };
“WFSDataStoreFactory:GET_CAPABILITIES_URL”,
// “WFSDataStoreFactory:BUFFER_SIZE”, 5);
connectionParams.put(“WFSDataStoreFactory:PROTOCOL”, Boolean.TRUE);
public void
(WFSDataStore)
DataStoreFinder.getDataStore(connectionParams); assertNotNull("Data store
final List typeNames = Arrays.asList(ds.getTypeNames());
assertNotNull(“Type names MUST NOT be null”, typeNames);
assertFalse(“Type names MUST NOT be empty”, typeNames.isEmpty());
assertTrue(
“Type names MUST contain [” + LAYER_NAME + “]”,
assertNotNull(“Feature type (schema) MUST NOT be null”, schema);
final List attributes =
assertNotNull(“Attributes list MUST NOT be null”, attributes);
assertTrue(
“Attributes list MUST contain at least 3 elements”,
assertTrue(
“Attribute named [” + atName + “] MUST be found”,
// Step 4 - query
assertTrue(“MUST be able to find at least one feature”, result >
0); }
private boolean
contains(final List attributes, final String
result = true;
break;
return result;
fs.getFeatures(q);
FeatureIterator fit = null;
int result = 0;
try {
fit.next();
result++;
} finally {
  • ATTRIBUTE_NAMES.length + " attributes, with "
  • (limit == 0 ? “NO limit” : “a limit of (” + limit + “)”)
  • “, found " + result + " feature(s)”);
return result;
TIA + cheers;
rsn
----- Open Source Business Conference (OSBC), March 24-25, 2009, San
Francisco, CA -OSBC tackles the biggest issue in open source: Open
Sourcing the Enterprise -Strategies to boost innovation and cut costs
with open source participation -Receive a $600 discount off the
registration fee with the source code: SFAD http://p.sf.net/sfu/XcvMzF8H
Gabriel Roldan
OpenGeo - http://www.opengeo.org
