Hi Mark, hi list
I think I found a solution, which works for me, which I want to share.
I checked that GeoServer per default does not use the wanted SRS
definition for the EPSG code of my source SRS (EPSG:31468). This is OK,
since there are several definitions for this SRS. Overwriting the SRS
with the wanted parameters (as described here [1]) did not bring any
effect. The overwritten SRS definition was shown in GeoServer UI, but
the transformation returned still the old (unwanted) values. I verified
the transformation with the reprojection console of GeoServer [2], which
is very useful.
After a while I discovered that the "coordinate operations" in the
transformation process (can be shown in the reprojection console as
well) still use the old parameters. So I decided to overwrite the
"coordinate operations" as documented here [3].
So in m special case I had to change the TOWGS84 parameters for
EPSG:31468. As stated above it was necessary to set these TOWGS84
parameters within a custom "coordinate operations". To do this I added a
file epsg_operations.properties to geoserver_data/user_projections with
the following content (maybe useful as example):
31468,3857=CONCAT_MT[INVERSE_MT[PARAM_MT["Transverse_Mercator",\
PARAMETER["semi_major", 6377397.155],\
PARAMETER["semi_minor", 6356078.962818189],\
PARAMETER["central_meridian", 12.0],\
PARAMETER["latitude_of_origin", 0.0],\
PARAMETER["scale_factor", 1.0],\
PARAMETER["false_easting", 4500000.0],\
PARAMETER["false_northing", 0.0]]],\
PARAM_MT["Ellipsoid_To_Geocentric",\
PARAMETER["dim", 2],\
PARAMETER["semi_minor", 6356078.962818189]],\
PARAM_MT["Position Vector transformation (geog2D domain)",\
PARAMETER["dx", 598.1],\
PARAMETER["dy", 73.7],\
PARAMETER["dz", 418.2],\
PARAMETER["ex", 0.202],\
PARAMETER["ey", 0.045],\
PARAMETER["ez", -2.455],\
PARAMETER["ppm", 6.7]],\
PARAM_MT["Geocentric_To_Ellipsoid",\
PARAMETER["semi_major", 6378137.0],\
PARAMETER["semi_minor", 6356752.314245179]],\
PARAM_MT["Popular Visualisation Pseudo Mercator",\
PARAMETER["semi_minor", 6378137.0],\
PARAMETER["central_meridian", 0.0],\
PARAMETER["false_easting", 0.0],\
[1]
https://docs.geoserver.org/stable/en/user/configuration/crshandling/customcrs.html#override-an-official-epsg-code
[2]
https://docs.geoserver.org/stable/en/user/configuration/demos/index.html#demos-reprojectionconsole
[3]
https://docs.geoserver.org/stable/en/user/configuration/crshandling/coordtransforms.html#coordinate-operations
Chris
On 01.02.21 08:38, Christian Mayer wrote:
Hi Mark,
thanks for your answer and the hints with the NTv2. I'll give it a try
and report back here.
Thanks again
Chris
On 29.01.21 17:19, Mark Prins wrote:
On 29-01-2021 15:03, Christian Mayer wrote:
Hi list,
I have the following setup: A geometry table in a PostGIS DB with points
having the projection EPSG:31468 [1]. I am publishing the points as WFS
FeatureType and query them in EPSG:3857 [2] by setting srsName=EPSG:3857
in the WFS GetFeature request. The returned WFS points have a coordinate
shift (1-2 meters) compared to the points transformed directly in
PostGIS or with GDAL.
Here is an example:
Native point in EPSG:31468 --> 4355155.403, 5512583.018
Transformed point with GDAL or ST_Transform of PostGIS -->
1112006.22028666, 6400063.79411048
Transformed point as output of the GeoServer WFS request -->
1112005.8998, 6400065.9514
Has anyone an idea what is going wrong here?
There appear to be several well known transformation methods available
listed at http://epsg.io/31468, GeoServer may be using a less accurate
version than other products by default.
Do the SRS definitions in
GeoServer differ from those in PostGIS or GDAL?
debug logging may show which transformation method is used, it's not
my expertise but it looks like NTv2 should be used to get results
within 1m accuracy, so you may need to add a Grid Shift file to get
better results
see also:
-M
Geoserver-users mailing list
Please make sure you read the following two resources before posting
to this list:
- Earning your support instead of buying it, but Ian Turton:
http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines:
http://geoserver.org/comm/userlist-guidelines.html
If you want to request a feature or an improvement, also see this:
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.html
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
