[Geoserver-users] WFS/Slaved
Hello,
The definitions of old WFS features sources is not converted into the new definitions of
WFS features.
All the other definitions is converted correctly but WFS sources. The error that appears is
no Plugin defined. Conversion from 2.4 tot 2.8 version.
Eric
Eric Smets                                    [eric.smets@anonymised.com](mailto:eric.smets@anonymised.com)
FKS bvba - Formal and Knowledge Systems       [http://www.fks.be](http://www.fks.be/)/
Schampbergstraat 32                           Tel:  ++32-(0)11-21 49 11
B-3511 Hasselt                                Fax:  ++32-(0)11-22 04 19
On Thu, Oct 22, 2015 at 4:33 PM, Eric Smets <eric.smets@anonymised.com> wrote:
Hello,
definitions of
WFS features.
My guess is that the wfs-ng datastore has not been setup as a fallback
for the old wfs store it replaced.
If that's the case we have a backwards compatibility breakage, you should
probably
open a bug report at:
https://osgeo-org.atlassian.net/projects/GEOS/summary
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
