[Geoserver-users] WFS-t and ARC_SDE
Hi.
I'm a new Geoserver user and I try to use WFS-T to
insert a point into a feature class into my Oracle
datadase using ArcSDE.
I've created a WFS-Transactional.xml like this:
  <wfs:Transaction
xmlns:wfs="http://www.opengis.net/wfs&quot;&gt;
  <wfs:Insert>
  <topp:SDE_TEST.TESTPUNKTER
xmlns:topp="http://www.openplans.org/topp&quot;&gt;
      <topp:the_geom>
        <gml:MultiPoint
xmlns:gml="http://www.opengis.net/gml&quot;
srsName="epsg:4326">
          <gml:pointMember>
            <gml:Point>
              <gml:coordinates decimal="." cs="," ts="
">149.344775,-41.744855</gml:coordinates>
            </gml:Point>
          </gml:pointMember>
        </gml:MultiPoint>
      </topp:the_geom>
       <topp:OBJECTID>11</topp:OBJECTID>
      <topp:CITY_NAME/>
      <topp:ADMIN_NAME>Takk</topp:ADMIN_NAME>
      <topp:CNTRY_NAME>tusen</topp:CNTRY_NAME>
      <topp:STATUS>Bare bull</topp:STATUS>
      <topp:POP_CLASS/>
</topp:SDE_TEST.TESTPUNKTER></wfs:Insert></wfs:Transaction>
But when I try to use the Demo Request at
http://lokalhost:8080/geoserver/demoRequestSubmit.do
I end up with the following message:
org.xml.sax.SAXException: Could not find attributeType
named the_geomin featureType DefaultFeatureType
[name=SDE_TEST.TESTPUNKTER ,
namespace=http://www.opengis.net/gml , abstract=false
, types=(DefaultAttributeType [name=OBJECTID ,
type=class java.lang.Integer , nillable=true, min=1,
max=1],DefaultAttributeType [name=CITY_NAME ,
type=class java.lang.String , nillable=true, min=1,
max=1],DefaultAttributeType [name=ADMIN_NAME ,
max=1],DefaultAttributeType [name=CNTRY_NAME ,
max=1],DefaultAttributeType [name=STATUS , type=class
max=1],DefaultAttributeType [name=POP_CLASS ,
max=1],DefaultAttributeType [name=SHAPE , type=class
com.vividsolutions.jts.geom.MultiPoint ,
nillable=true, min=1, max=1],)]
What is wrong??
Anyone got a hint for me??
-Lars
What's the name of your oracle field containing geometry? "the_geom" or is
it something else like "shape" ?
Dave
-----Original Message-----
From: geoserver-users-admin@lists.sourceforge.net [mailto:geoserver-users-
admin@lists.sourceforge.net] On Behalf Of Lars Oust
Sent: Tuesday, January 03, 2006 7:43 AM
Subject: [Geoserver-users] WFS-t and ARC_SDE
Hi.
  <wfs:Transaction
  <wfs:Insert>
      <topp:the_geom>
        <gml:MultiPoint
          <gml:pointMember>
            <gml:Point>
            </gml:Point>
          </gml:pointMember>
        </gml:MultiPoint>
      </topp:the_geom>
      <topp:CITY_NAME/>
      <topp:POP_CLASS/>
What is wrong??
-Lars
This SF.net email is sponsored by: Splunk Inc. Do you grep through log
files
for problems? Stop! Download the new AJAX search engine that makes
searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
http://ads.osdn.com/?ad_id=7637&alloc_id=16865&op=click
Geoserver-users mailing list
My Oravel SDE feature class si created from the example shapefile, tasmania_cities.shp, following the Geoserver 1.3 installation.
My Oracle fiels containing geometry is named “SHAPE”. I could name it different, like GEO??.
The Shapfile has a column named FID. In Oracle and SDE this same column is named OBJECTID??
-Lars
David Neufeld david.neufeld@anonymised.com skrev:
What’s the name of your oracle field containing geometry? “the_geom” or is
it something else like “shape” ?
Dave
Hi.
I’m a new Geoserver user and I try to use WFS-T to
I’ve created a WFS-Transactional.xml like this:
What is wrong??
-Lars
files
What David is getting at is that in your insert request, you called the
geometry 'the_geom'. This is how the examples are, but the reason is
because that's what the featureType's geometry is called. Since your
geometry is called shape, on your insert request it needs to look like:
      <topp:SHAPE>
        <gml:MultiPoint
          <gml:pointMember>
            <gml:Point>
            </gml:Point>
          </gml:pointMember>
        </gml:MultiPoint>
      </topp:SHAPE>
It should also go last, as that's what the error is telling you, the
order of the attributes and what they should be called. SHAPE is the
geometry one, and comes after POP_CLASS.
best regards,
Chris
Quoting Lars Oust <laonijos@anonymised.com>:
  My Oracle fiels containing geometry is named "SHAPE". I could name
  -Lars
"the_geom" or is
Dave
> Hi.
> > " cs="," decimal=".">149.344775,-41.744855
> 11
> Takk
> tusen
> Bare bull
> What is wrong??
> -Lars
log
> files
SPLUNK!
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
This mail sent through IMP: https://webmail.limegroup.com/
