I have verbose logging on geoserver whilst configuring it to get it in shape for production.
There are logging messages i don’t understand and if i should be worried about them.
I get a lot Found Java environment variable: ‘xx’ to be unset. In particular for PROXY_BASE_URL but also found for several other.
But in my docker-compose (see snipper bellow) it is defined and appear to be working. Is something broken? I cannot tell by the logg.
services:
geoserver:
image: docker.osgeo.org/geoserver:2.25.0
environment:
EXTRA_GEOSERVER_OPTS=“-DGEOSERVER_CSRF_WHITELIST=mydomain.no,mydomain2com”
PROXY_BASE_URL=https://mydomain.com/geoserver
GEOSERVER_CSRF_DISABLED=true
I noticed that EXTRA_GEOSERVER_OPTS="-DGEOSERVER_CSRF_WHITELIST is not working. mydomain are still not going through. The only reason it works at the moment is because I disabled CSRF altogether. Is there a reason why Whitelist would not work. I have tried adding just one domain as well. If CSRF is enabled i get a 400 error.
