[Geoserver-users] What does "Opaque" mean under Publishing > WMS Settings
In GeoServer 2.8 under "Edit Layer" > "Publishing" > "WMS Settings" there is
a tick box labled "Opaque". I can't find any documentation on this ans want
to clarify what this setting does.
View this message in context: http://osgeo-org.1560.x6.nabble.com/What-does-Opaque-mean-under-Publishing-WMS-Settings-tp5247039.html
is
It generates the same flag in the WMS capabilites output, which clients can
use to determine
that the layer is only suitable as a backdrop, but should not be used as an
overlay.
It's just informational though, the client can still ask to use that layer
as an overlay if it wants to
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
It is a way of signalling to clients that this layer is hard to see through and should be used as a baselayer. It maps directly to the opaque layer attribute in the GetCapabilities document (see table 6, p30 of the spec).
Ian
On 25 January 2016 at 08:49, Derek Watling <derek@anonymised.com> wrote:
In GeoServer 2.8 under “Edit Layer” > “Publishing” > “WMS Settings” there is
a tick box labled “Opaque”. I can’t find any documentation on this ans want
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
Geoserver-users mailing list
Ian Turton
