[Geoserver-users] What hardware requirements I need ???
Hi, when I am testing my maps with google maps, all are run fine, but when I
am testing my maps with only openlayers, my maps does not run fast neither
are deploys correctly.
I´m guess that is doing for my hardware... then What hardware requirements I
need ???
View this message in context: http://www.nabble.com/What-hardware-requirements-I-need-----tf4793314.html#a13712455
need ???
I cannot give you an estimate, since I don't know what your use case is (type of map, data sizes, time requirements, your connection bandwith)... first of all, have you tried using scale based rules so that your data does not display all at once when fairly zoomed out?
Have you tried simplifying your styling? What about testing out
GeoServer 1.6.0beta4 or trying to follow the directions
reported at http://docs.codehaus.org/display/GEOSDOC/5+GeoServer+in+Production+Environment?
If your map is static and you plan to use OpenLayers, have you tried
using TileCache?
I would try all the above before trying to throw more powerful hardware
at the problem.
