I understood I can not change (non-admin) users password via GeoServer RESTful api!, but I can change users password via users.xml . Therefore, I am going to know,
How I can do that?
could you please inform me about GeoServer password encoder and its parameters (such as round time number), I need for generate correct password in programming languages such as python3 or nodejs?
I guess this line might be helpful despite it is using the native java libraries https://github.com/olivierdalang/SPCgeonode/blob/master/_service_geoserver/docker-entrypoint.sh#L59. However, you might choice to call it as a container CLI from a GeoServer docker image in a python environment. It should work.
Hope it helps
Francesco
Il giorno 24 mar 2022, alle ore 17:03, Navid taheri <navidtaheri@anonymised.com> ha scritto:
How I can do that?
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
