Dear All,
I’d like to know what should be the (physical) specification of a Web Map Server to server around 20 users simultaneously with good performance.
Anyone please give me advice.
What should be the specification of a Map Server to deliver the maps with good performance If the users increase to 50?
Thank you very much in advance
Best Regards
Mr. Khun San Aung, GIS Analyst
Web http://themimu.info/
Hello,
in my opinion this needs more specification what you are planning.
For example:
-What kind of data do you want to deliver? Postgis? Raster data? Shape files?
-How many data do you have? 1000 entries? 1.000.000 ?
-How complex is your styling?
-What kind of service do you need? Really wms? Or can you serve tiled maps?
-If you can serve tiled maps how dynamic is your data? Can you preseed the tiles?
-You are talking about 20 Users who are simultaneously using the service. Are they really using it simultaneously in the same seconds? Or do you have 20 users overall?
I would expect that a small server mit max. 4 CPU-cores and 16 GB memory with some fast HDDs or better SSD would be fast enough. But this is really a rule of thumb estimating which can vary enormous to bigger or smaller servers.
Stefan
Sent: Friday, March 22, 2013 4:30 AM
Subject: [bulk]: [Geoserver-users] What Should Be the Specification of a Map Server to Serve Around 20 Users Simultaneously
Dear All,
Best Regards
Hi Khun,
There’s no really good answer as it depends on where the data is coming from, what you’re doing with it etc. But for such a lower number of users, I suspect pretty much any old piece of kit will work (well, apart from a 486
This may be of interest:
http://gis.stackexchange.com/questions/27536/recommended-server-specs-for-geoserver
Jonathan
On 22 March 2013 03:30, KhunSanAung <khunsanaung.gis@anonymised.com4…> wrote:
Dear All,
Best Regards
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_mar
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
