[Geoserver-users] When i crop coverage which is the result of gs:BarnesSurface with WPS chain in sld. It's throw a Error
Hi:
The sld is below:
<?xml version="1.0" encoding="GBK"?>
Barnes surface
Barnes Surface A style that produces a Barnes surface using a RenderingTransformation data valueAttr o3_8h scale 300000 convergence 0.2 passes 3 minObservations 1 maxObservationDistance 300000 pixelsPerCell 10 queryBuffer 1100000 outputBBOX wms_bbox outputWidth wms_width outputHeight wms_height geom 1
The error info:
2016-01-02 16:56:13,321 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/BpGeo/wms]
2016-01-02 16:56:13,321 DEBUG [ows.OWSHandlerMapping] - Mapping [/BpGeo/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher@…7390…] and 1 interceptor
2016-01-02 16:56:13,325 DEBUG [config.impl] - Could not locate service of type interface org.geoserver.wms.WMSInfo in workspace WorkspaceInfoImpl[BpGeo], available services were [CSWInfoImpl[CSW], WCSInfoImpl[WCS], WFSInfoImpl[WFS], WMSInfoImpl[WMS], WPSInfoImpl[WPS]]
2016-01-02 16:56:13,325 INFO [geoserver.wms] -
Request: getServiceInfo
2016-01-02 16:56:13,326 DEBUG [geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
2016-01-02 16:56:13,326 DEBUG [geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2016-01-02 16:56:13,328 DEBUG [geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2016-01-02 16:56:13,328 DEBUG [geoserver.ows] - establishing crop style for BpGeo:Barnes surface map
2016-01-02 16:56:13,331 DEBUG [config.impl] - Could not locate service of type interface org.geoserver.wms.WMSInfo in workspace WorkspaceInfoImpl[BpGeo], available services were [CSWInfoImpl[CSW], WCSInfoImpl[WCS], WFSInfoImpl[WFS], WMSInfoImpl[WMS], WPSInfoImpl[WPS]]
2016-01-02 16:56:13,332 DEBUG [config.impl] - Could not locate service of type interface org.geoserver.wms.WMSInfo in workspace WorkspaceInfoImpl[BpGeo], available services were [CSWInfoImpl[CSW], WCSInfoImpl[WCS], WFSInfoImpl[WFS], WMSInfoImpl[WMS], WPSInfoImpl[WPS]]
2016-01-02 16:56:13,332 DEBUG [geoserver.wms] - setting up map
2016-01-02 16:56:13,332 DEBUG [geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
2016-01-02 16:56:13,332 DEBUG [geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2016-01-02 16:56:13,333 DEBUG [geotools.jdbc] - CREATE CONNECTION
2016-01-02 16:56:13,337 DEBUG [geotools.jdbc] - CLOSE CONNECTION
2016-01-02 16:56:13,338 DEBUG [wms.map] - setting up 768x662 image
2016-01-02 16:56:13,339 DEBUG [config.impl] - Could not locate service of type interface org.geoserver.wms.WMSInfo in workspace WorkspaceInfoImpl[BpGeo], available services were [CSWInfoImpl[CSW], WCSInfoImpl[WCS], WFSInfoImpl[WFS], WMSInfoImpl[WMS], WPSInfoImpl[WPS]]
2016-01-02 16:56:13,395 DEBUG [config.impl] - Could not locate service of type interface org.geoserver.wms.WMSInfo in workspace WorkspaceInfoImpl[BpGeo], available services were [CSWInfoImpl[CSW], WCSInfoImpl[WCS], WFSInfoImpl[WFS], WMSInfoImpl[WMS], WPSInfoImpl[WPS]]
2016-01-02 16:56:13,396 DEBUG [config.impl] - Could not locate service of type interface org.geoserver.wms.WMSInfo in workspace WorkspaceInfoImpl[BpGeo], available services were [CSWInfoImpl[CSW], WCSInfoImpl[WCS], WFSInfoImpl[WFS], WMSInfoImpl[WMS], WPSInfoImpl[WPS]]
2016-01-02 16:56:13,405 TRACE [geotools.factory] - ENTRY (GeometryFactory, JTS_GEOMETRY_FACTORY)
2016-01-02 16:56:13,406 TRACE [geotools.factory] - RETURN (GeometryFactory, JTS_GEOMETRY_FACTORY): found implementation GeometryFactory.
2016-01-02 16:56:13,415 TRACE [geotools.factory] - ENTRY (GeometryFactory, JTS_GEOMETRY_FACTORY)
2016-01-02 16:56:13,415 TRACE [geotools.factory] - RETURN (GeometryFactory, JTS_GEOMETRY_FACTORY): found implementation GeometryFactory.
2016-01-02 16:56:13,416 TRACE [geotools.factory] - ENTRY (GeometryFactory, JTS_GEOMETRY_FACTORY)
2016-01-02 16:56:13,416 TRACE [geotools.factory] - RETURN (GeometryFactory, JTS_GEOMETRY_FACTORY): found implementation GeometryFactory.
2016-01-02 16:56:13,420 DEBUG [geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
2016-01-02 16:56:13,420 DEBUG [geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2016-01-02 16:56:13,422 DEBUG [process.factory] - Failed to locate the field 0.3 in class class org.geotools.process.vector.BarnesSurfaceProcess
2016-01-02 16:56:13,422 DEBUG [process.factory] - Failed to locate the field 0.3 in class class java.lang.Double
2016-01-02 16:56:13,422 DEBUG [geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
2016-01-02 16:56:13,422 DEBUG [geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2016-01-02 16:56:13,422 DEBUG [process.factory] - Failed to locate the field 2 in class class org.geotools.process.vector.BarnesSurfaceProcess
2016-01-02 16:56:13,422 DEBUG [process.factory] - Failed to locate the field 2 in class class java.lang.Integer
2016-01-02 16:56:13,422 DEBUG [process.factory] - Failed to locate the field 0 in class class org.geotools.process.vector.BarnesSurfaceProcess
2016-01-02 16:56:13,422 DEBUG [process.factory] - Failed to locate the field 0 in class class java.lang.Double
2016-01-02 16:56:13,422 DEBUG [process.factory] - Failed to locate the field -999 in class class org.geotools.process.vector.BarnesSurfaceProcess
2016-01-02 16:56:13,422 DEBUG [process.factory] - Failed to locate the field -999 in class class java.lang.Double
2016-01-02 16:56:13,423 DEBUG [geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2016-01-02 16:56:13,423 DEBUG [process.factory] - Failed to locate the field 1 in class class org.geotools.process.vector.BarnesSurfaceProcess
2016-01-02 16:56:13,423 DEBUG [process.factory] - Failed to locate the field 1 in class class java.lang.Integer
2016-01-02 16:56:13,423 DEBUG [geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
2016-01-02 16:56:13,438 TRACE [geotools.factory] - ENTRY (GeometryFactory, JTS_GEOMETRY_FACTORY)
2016-01-02 16:56:13,438 TRACE [geotools.factory] - RETURN (GeometryFactory, JTS_GEOMETRY_FACTORY): found implementation GeometryFactory.
2016-01-02 16:56:13,446 TRACE [geotools.factory] - ENTRY (GeometryFactory, JTS_GEOMETRY_FACTORY)
2016-01-02 16:56:13,446 TRACE [geotools.factory] - RETURN (GeometryFactory, JTS_GEOMETRY_FACTORY): found implementation GeometryFactory.
2016-01-02 16:56:13,447 TRACE [geotools.factory] - ENTRY (GeometryFactory, JTS_GEOMETRY_FACTORY)
2016-01-02 16:56:13,447 TRACE [geotools.factory] - RETURN (GeometryFactory, JTS_GEOMETRY_FACTORY): found implementation GeometryFactory.
2016-01-02 16:56:13,448 TRACE [geotools.factory] - ENTRY (GeometryFactory, JTS_GEOMETRY_FACTORY)
2016-01-02 16:56:13,448 TRACE [geotools.factory] - RETURN (GeometryFactory, JTS_GEOMETRY_FACTORY): found implementation GeometryFactory.
2016-01-02 16:56:13,448 DEBUG [geotools.jdbc] - CREATE CONNECTION
2016-01-02 16:56:13,490 DEBUG [geotools.filter] - exporting PropertyName
2016-01-02 16:56:13,491 DEBUG [geotools.filter] - exporting LiteralExpression
2016-01-02 16:56:13,491 DEBUG [geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
2016-01-02 16:56:13,491 DEBUG [geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2016-01-02 16:56:13,493 DEBUG [geotools.jdbc] - SELECT “gid”,“id”,“stationcode”,“stationname”,“station_lo”,“station_la”,“citycode”,“cityname”,“provincena”,“remarks”,“weather_st”,“weather__1”,“weather__2”,“weather__3”,“weather__4”,“distance”,“area”,“id_d1”,“id_d2”,“id_d3”,“地域”,encode(ST_AsEWKB(“geom”),‘base64’) as “geom”,“pm25”,“o3_8h” FROM (select s.*,p.o3_8h from station s left join t_sc_pollutant_v0020_hour p on p.stationcode=s.stationcode where p.monitordate= to_timestamp(‘2015-10-19 16:00:00’,‘YYYY-MM-DD HH24:MI:SS’)
) as “vtable” WHERE “geom” && ST_GeomFromText(‘POLYGON ((-∞ -∞, -∞ ∞, ∞ ∞, ∞ -∞, -∞ -∞))’, 3857)
2016-01-02 16:56:13,505 DEBUG [geotools.jdbc] - CLOSE CONNECTION
2016-01-02 16:56:13,505 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Error rendering coverage on the fast path
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:345)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:260)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:132)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:504)
at org.geoserver.wms.GetMap.run(GetMap.java:248)
at org.geoserver.wms.GetMap.run(GetMap.java:119)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:369)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:317)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:62)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:36)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:80)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at com.sun.proxy.$Proxy87.getMap(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:845)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:275)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:919)
at com.boundlessgeo.geoserver.AppDispatcher.doDispatch(AppDispatcher.java:67)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:851)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:953)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:844)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:829)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:654)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1320)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1291)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at com.boundlessgeo.geoserver.AppAuthFilter.doFilter(AppAuthFilter.java:111)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:118)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:84)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:192)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:160)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:343)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:260)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:443)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:137)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:532)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:227)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1044)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:372)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:189)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:978)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:255)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:154)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
at org.eclipse.jetty.server.Server.handle(Server.java:369)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:486)
at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:933)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:995)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:644)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:235)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:82)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:668)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:52)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.geoserver.platform.ServiceException: java.lang.RuntimeException: Failed to evaluate the process function, error is: java.lang.RuntimeException: java.io.IOException
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:1051)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:343)
… 120 more
Caused by: java.lang.RuntimeException: Failed to evaluate the process function, error is: java.lang.RuntimeException: java.io.IOException
at org.geotools.process.function.ProcessFunction.evaluate(ProcessFunction.java:155)
at org.geotools.process.function.ParameterFunction.evaluate(ParameterFunction.java:104)
at org.geotools.process.function.ParameterFunction.evaluate(ParameterFunction.java:120)
at org.geotools.process.function.ProcessFunction.evaluateInputs(ProcessFunction.java:174)
at org.geotools.process.function.ProcessFunction.evaluate(ProcessFunction.java:137)
at org.geotools.renderer.lite.RenderingTransformationHelper.applyRenderingTransformation(RenderingTransformationHelper.java:224)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:1005)
… 121 more
Caused by: org.geotools.process.ProcessException: java.lang.RuntimeException: java.io.IOException
at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.execute(AnnotationDrivenProcessFactory.java:565)
at org.geotools.process.function.ProcessFunction.evaluate(ProcessFunction.java:142)
… 127 more
Caused by: java.lang.RuntimeException: java.io.IOException
at org.geotools.data.store.ContentFeatureCollection.features(ContentFeatureCollection.java:167)
at org.geotools.process.vector.BarnesSurfaceProcess.extractPoints(BarnesSurfaceProcess.java:388)
at org.geotools.process.vector.BarnesSurfaceProcess.execute(BarnesSurfaceProcess.java:226)
at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.execute(AnnotationDrivenProcessFactory.java:549)
… 128 more
Caused by: java.io.IOException
at org.geotools.jdbc.JDBCFeatureSource.getReaderInternal(JDBCFeatureSource.java:642)
at org.geotools.data.store.ContentFeatureSource.getReader(ContentFeatureSource.java:612)
at org.geotools.data.store.ContentFeatureCollection.features(ContentFeatureCollection.java:164)
… 135 more
Caused by: java.sql.SQLException: org.postgresql.util.PSQLException: ERROR: parse error - invalid geometry
建议:“POLYGON ((-�” ← parse error at position 12 within geometry
at org.geotools.jdbc.JDBCFeatureReader.(JDBCFeatureReader.java:154)
at org.geotools.jdbc.JDBCFeatureSource.getReaderInternal(JDBCFeatureSource.java:612)
… 137 more
Caused by: org.postgresql.util.PSQLException: ERROR: parse error - invalid geometry
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2062)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1795)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:257)
at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:479)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:353)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeQuery(AbstractJdbc2Statement.java:252)
at org.apache.commons.dbcp.DelegatingStatement.executeQuery(DelegatingStatement.java:208)
at org.geotools.jdbc.JDBCFeatureReader.(JDBCFeatureReader.java:146)
… 138 more
