[Geoserver-users] Where are GeoWebCache dirs??
Hello,
I am reading and trying to configure GeoWebCache on GeoServer 1.7.2 but I cannot find any of the folders that are referenced.
Where is /gwc ? I can run http://localhost:8080/geoserver/gwc/demo (works fine) but where is the folder “/gwc”? I cannot see it under the geoserver_data_dir or any other place on my server. I need to edit web.xml but that must be in the gwc folder?
I am running Tomcat on OS X Server 10.5.
/asle
Hi Asle. GWC acts as a service, so there isn't a /gwc folder in the same way that there isn't a /wms folder.
Most of the configuration for GWC is done in the standard GeoServer web.xml, I believe.
See also:
http://geoserver.org/display/GEOSDOC/5.+GWC+-+GeoWebCache
Mike Pumphrey
OpenGeo - http://opengeo.org
Asle Benoni wrote:
Hello,
Where is */gwc* ? I can run http://localhost:8080/geoserver/gwc/demo (works fine) but where is the folder "/gwc"? I cannot see it under the geoserver_data_dir or any other place on my server. I need to edit web.xml but that must be in the gwc folder?
/asle
Apps built with the Adobe(R) Flex(R) framework and Flex Builder(TM) are
powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
easily build your RIAs with Flex Builder, the Eclipse(TM)based development
software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
Geoserver-users mailing list
Thanks for your reply Mike,
So the web.xml to edit is the one inside …/webapps/geoserver/ ?
I still don´t get how to have GeoWebCache fetch files from a wms server. Any good tutorial?
/asle
2009/3/19 Mike Pumphrey <mike@anonymised.com>
Hi Asle. GWC acts as a service, so there isn’t a /gwc folder in the same way that there isn’t a /wms folder.
See also:
http://geoserver.org/display/GEOSDOC/5.+GWC±+GeoWebCache
Mike Pumphrey
Asle Benoni wrote:
Hello,
/asle
Apps built with the Adobe(R) Flex(R) framework and Flex Builder™ are
easily build your RIAs with Flex Builder, the Eclipse™based development
Hi Asle. I think you'd want the standalone version of GeoWebCache [1] then, not the version that ships with GeoServer. With the plugin, it assumes that you want to use GeoServer's WMS. With the standalone version, you can easily configure it for any WMS [2].
[1] http://sourceforge.net/project/showfiles.php?group_id=215120
[2] http://geowebcache.org/trac/wiki/configuration
Mike Pumphrey
So the web.xml to edit is the one inside .../webapps/geoserver/ ?
/asle
2009/3/19 Mike Pumphrey <mike@anonymised.com <mailto:mike@anonymised.com>>
    web.xml, I believe.
    See also:
    Mike Pumphrey
    Asle Benoni wrote:
        Hello,
        /asle
        Builder(TM) are
        Quickly and
        development
        <mailto:Geoserver-users@lists.sourceforge.net>
