[Geoserver-users] White lines in GWC 900913, latest nightly build
Good Morning.
I’ve run into a problem using GeoServer gwc in 900913 with imagery. Here is the setup:
  • Latest nightly build GeoServer (note, it also occurs in 1.7.3)
  • Imagery stored as GeoTiff in 4326.
  • Using Mosaic imaging
All works perfectly using gwc 4326, but when viewing in 900913, get white lines at gwc tile borders.
For a quick view, go here and zoom in once:
http://ogi.state.ok.us:8080/geoserver/gwc/demo/ogi:Test_1?srs=EPSG:900913
To reproduce on your own machine:
  • Download these sample files:
  • http://ogi.state.ok.us/ogi/Downloads/gwctest.zip
  • Unzip
  • Create a mosaic coverage - set OutputTransparentColor: 0 to make it show up better (white instead of black line)
  • Go to the gwc demo page in GeoServer
  • Click on the EPSG:900913 link
  • Zoom in once (or more)
  • Zoom in some more (3x), and the white lines get even worse, in both horizontal as well as vertical.
    Note that it is not at the borders of the sample images as these are square, and the join is in the center. Instead, the white line is at the join of the gwc tile.
Thanks for looking into this!
Roger
Ciao Roger,
are you able to isolate a single request from GWC to GeoServer so that we can:
1> check if this is geoserver's fault
2> if 1 applies, fix the problem.
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Sun, Jun 28, 2009 at 10:03 AM, Roger Bedell<sylvanascent@anonymised.com> wrote:
Good Morning.
I've run into a problem using GeoServer gwc in 900913 with imagery. Here is
the setup:
- Latest nightly build GeoServer (note, it also occurs in 1.7.3)
- Imagery stored as GeoTiff in 4326.
- Using Mosaic imaging
Unzip
gwc tile.
Roger
Geoserver-users mailing list
Simone,
I believe you can reproduce it easily using the steps and data I gave you
already, on your own server. Should only take you a couple of minutes.
It is a critical problem for us, so many thanks for any help you can provide.
Roger
From: "Simone Giannecchini" <simone.giannecchini@anonymised.com>
Sent: Sunday, June 28, 2009 10:13 PM
To: "Roger Bedell" <roger@anonymised.com>
Cc: <geoserver-users@lists.sourceforge.net>
Subject: Re: [Geoserver-users] White lines in GWC 900913, latest nightly build
Ciao Roger,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Good Morning.
the setup:
Unzip
gwc tile.
Roger
i remember i had the same issue using biliniear or cubic
interpolation method. using nearest neighbour "solved" the problem...
maybe this helps you, cheers
On Mon, Jun 29, 2009 at 1:56 PM, Roger Bedell<sylvanascent@anonymised.com> wrote:
Simone,
provide.
Roger
build
Ciao Roger,
can:
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
wrote:
Good Morning.
is
the setup:
Unzip
up
square,
the
gwc tile.
Roger
Ivan Grcic
Ivan,
Thanks a million, that does seem to "fix" it. However our client really wants interpolation, to avoid pixelation when zoomed in, as well as generally better results at all zoom levels.
However, this fix gives us a little breathing room, as the white lines were much worse than pixelation.
Simone, this should give you a little more information on where this is occurring.
Roger
Sent: Monday, June 29, 2009 3:08 PM
Simone,
provide.
Roger
build
Ciao Roger,
can:
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
wrote:
Good Morning.
is
the setup:
Unzip
up
square,
the
gwc tile.
Roger
Ivan Grcic
Ciao Roger,
I have been able to reproduce it on my workstation and to identify the cause.
Am I right when I say that this problem was already present in 1.7.3 and before?
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
On Mon, Jun 29, 2009 at 3:27 PM, Roger Bedell<sylvanascent@anonymised.com> wrote:
Ivan,
occurring.
Roger
build
wrote:
Simone,
provide.
Roger
build
Ciao Roger,
we
can:
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
wrote:
Good Morning.
Here
is
the setup:
white
Unzip
show
up
square,
of
the
gwc tile.
Roger
Ivan Grcic
Ciao Simone,
Great to hear. At least in 1.7.3, yes.
Roger
Sent: Thursday, July 02, 2009 3:38 PM
Ciao Roger,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Ivan,
occurring.
Roger
build
wrote:
Simone,
provide.
Roger
build
Ciao Roger,
we
can:
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
wrote:
Good Morning.
Here
is
the setup:
white
Unzip
show
up
square,
of
the
gwc tile.
Roger
Ivan Grcic
K, well for the records this is a problem I was already trying to fix
in a non intrusive way, I did not expect it to pop up this way.
The lines appear because you are mixing bilinear interpolation with
reprojection, it is a border effect that comes from the fact that the
raster data gets extended with a value of 0.
I'll open up a jira for this but I have to say that it is not going to
be easy to fix.
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
On Thu, Jul 2, 2009 at 4:07 PM, Roger Bedell<sylvanascent@anonymised.com> wrote:
Ciao Simone,
Roger
build
Ciao Roger,
cause.
before?
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
wrote:
Ivan,
were
occurring.
Roger
build
wrote:
Simone,
you
provide.
Roger
nightly
build
Ciao Roger,
we
can:
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
wrote:
Good Morning.
Here
is
the setup:
white
Unzip
show
up
square,
of
the
gwc tile.
Roger
Ivan Grcic
In the latest GWC a "gutter" function was introduced, a buffer around each image that gets sliced away.
That would probably fix this, as long as you don't have labels that get cut off.
-Arne
Simone Giannecchini wrote:
Ciao Roger,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Ivan,
occurring.
Roger
build
wrote:
Simone,
provide.
Roger
build
Ciao Roger,
we
can:
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
wrote:
Good Morning.
Here
is
the setup:
white
Unzip
show
up
square,
of
the
gwc tile.
Roger
Ivan Grcic
Arne and Simone,
I'm just following up on this. Is this gutter thing available in the 1.7.6 release of GWC, and if so, how do you use it? I'd like to see if it solves this issue.
Roger
Sent: Friday, July 03, 2009 2:30 PM
To: "Simone Giannecchini" <simone.giannecchini@anonymised.com>
Cc: "Roger Bedell" <roger@anonymised.com>; <geoserver-users@lists.sourceforge.net>
cut off.
-Arne
Ciao Roger,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Ivan,
occurring.
Roger
build
wrote:
Simone,
provide.
Roger
build
Ciao Roger,
we
can:
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
wrote:
Good Morning.
Here
is
the setup:
white
Unzip
show
up
square,
of
the
gwc tile.
Roger
Ivan Grcic
Yes, should be.
You'll have to define a custom layer, I recommend using a new name to make debugging easier. Get the default configuration file (see [1]), put it into <GEOSERVER_DATA_DIR>/gwc/
Modify one of those layers to suit your needs, then add
<gutter>{pixel width}</gutter>
(see the bottom of [2] for the exact order of the elements) and restart GeoServer to pick it up.
-Arne
1: http://geowebcache.org/trac/wiki/configuration
2: http://geowebcache.org/schema/docs/1.1.5/http___geowebcache.org_schema_1.1.5/complexType/wmsLayer.html
Roger Bedell wrote:
Arne and Simone,
Roger
cut off.
-Arne
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
