On Fri, Oct 3, 2014 at 9:12 AM, Ville Karppinen <ville.karppinen@anonymised.com>
wrote:
Grazie mille Simone and Andrea for you answer.
I would still like to clarify a couple of things about 16-bit geotiffs.
We have observed that in a previous version of geoserver (2.3.4) 16-bit
source geotiffs were provided as 16-bit from the geoserver. So, it seems
that the functionality has changed somewhere before our current version of
2.5.2. We have probably just missed some release notes about this.
Hum.. no, as far as I know the original functionality you're referring to
was there by accident, and I guess that also by accident it got removed.
However, this also means that it may be also easy to get it back, and this
time cover it with some tests, so that it does not regress (turning it
from an accident to a feature).
Our system is based on the assumption that style "raster" means the
original data is served as unaltered. Is there any way to get 16-bit
geotiffs (preferably without palette) by using WMS or is WCS the only way
to go? For example, could we define a style (SLD) which would effectively
force 16-bit geotiff output?
The only supported way right now is WCS (to the extent of my knowledge)
GeoSolutions for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
