Hello dear sir,
As is known, the GML format responseXML of WFS cannot return the fields
which have NULL value.But I need the fileds name, how to do it? For example
,if I have two fileds(name,and cname) in the PostGIS Talbe,and published the
table to the geoserver, and I can visit it via WFS. The 'cname' filed is not
defined NOT NULL. So when I parse the result GML using firstChild.NodeValue,
it has error. Because if any record of the Table has a null value in the
'cname' filed, the reponseXML of WFS would not return
'<gml:cname>null</gml:cname>', but nothing. I know I can solve this problem
via checking the length of the 'cname' node.But it is a awkward and
unpractical way, if there are several dozens of fileds.
So, I want to consult that can WFS of GeoServer return the filed name,if
the value of the filed is NULL? Like '<gml:cname>null</gml:cname>',and how
to do it? Thank you very much!
View this message in context: http://www.nabble.com/Why-the--WFS--does-not-return-the-NULL-value-field--tp25306238p25306238.html
Kevin Yang ha scritto:
Hello dear sir,
Parse the DescribeFeatureType response for the same feature type. That contains all of the fields and it's how a WFS
client is supposed to learn about the structure of the GetFeature response.
Andrea Aime
OpenGeo - http://opengeo.org
Hello dear sir,
which have NULL value.But I need the fileds name, how to do it?Parse the DescribeFeatureType response for the same feature type. That contains all of the fields and it's how a WFS
It should also be noted that this behavior is mandated by the WFS spec specification. GML and WFS explicitly avoid the use of "xs:nil" which would allow for the inclusion of elements with null values.
Justin Deoliveira
