Hi Andrea,
No I am not doing any reprojection according to me.
I just had a closer look in my logs, and I just saw :
29 May 13:11:17 INFO [geoserver.wms] -
Request: getMap
Transparent = false
SldBody = null
ValidateSchema = false
Sld = null
StyleUrl = null
Width = 681
Height = 330
Crs = GEOGCS["WGS 84",
DATUM["World Geodetic System 1984",
SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
UNIT["degree", 0.017453292519943295],
AXIS["Geodetic longitude", EAST],
AXIS["Geodetic latitude", NORTH],
AUTHORITY["EPSG","4326"]]
Bbox = SRSEnvelope[-238.80086411973 : 238.91716479437, -115.66365614516 : 115.82966183084]
RemoteOwsType = null
RemoteOwsURL = null
Env = {}
Angle = 0.0
CQLFilter = null
Elevation =
FeatureId = null
StartIndex = null
ViewParams = null
StyleFormat = sld
TilesOrigin = null
Tiled = false
Palette = null
SRS = EPSG:4326
FeatureVersion = null
Styles = [StyleImpl[ name=NOAA-Wind]]
Layers = [org.geoserver.wms.MapLayerInfo@...7082...]
MaxFeatures = null
BgColor = java.awt.Color[r=255,g=255,b=255]
FormatOptions = {}
Exceptions = SE_XML
StyleBody = null
SldVersion = null
StyleVersion = null
Time =
Filter = null
Buffer = 0
Format = image/jpeg
Filters = null
BaseUrl = http://localhost:8080/geoserver/
RawKvp = {BBOX=-238.80086411973,-115.66365614516,238.91716479437,115.82966183084, VERSION=1.1.1, FORMAT=image/jpeg, SERVICE=WMS, HEIGHT=330, LAYERS=NOAA-Wind:dWind, REQUEST=GetMap, STYLES=NOAA-Wind, SRS=EPSG:4326, WIDTH=681}
Get = true
RequestCharset = UTF-8
Version = 1.1.1
Request = GetMap
29 May 13:13:20 ERROR [wicket.RequestCycle] - Filter Function problem for function toDegrees argument #0 - expected type double
java.lang.IllegalArgumentException: Filter Function problem for function toDegrees argument #0 - expected type double
at org.geotools.filter.function.math.FilterFunction_toDegrees.evaluate(FilterFunction_toDegrees.java:50)
at org.geotools.filter.expression.ExpressionAbstract.evaluate(ExpressionAbstract.java:65)
at org.geotools.renderer.style.SLDStyleFactory.evalToDouble(SLDStyleFactory.java:1535)
at org.geotools.renderer.style.SLDStyleFactory.createPointStyle(SLDStyleFactory.java:574)
at org.geotools.renderer.style.SLDStyleFactory.createTextStyle(SLDStyleFactory.java:832)
at org.geotools.renderer.style.SLDStyleFactory.createStyleInternal(SLDStyleFactory.java:377)
at org.geotools.renderer.style.SLDStyleFactory.createStyle(SLDStyleFactory.java:321)
at org.geoserver.wms.legendgraphic.BufferedImageLegendGraphicBuilder.buildLegendGraphic(BufferedImageLegendGraphicBuilder.java:400)
at org.geoserver.wms.web.data.AbstractStylePage$6$1.getData(AbstractStylePage.java:263)
at org.apache.wicket.markup.html.DynamicWebResource$ResourceState.getLength(DynamicWebResource.java:89)
at org.apache.wicket.markup.html.DynamicWebResource$1.length(DynamicWebResource.java:241)
at org.apache.wicket.request.target.resource.ResourceStreamRequestTarget.configure(ResourceStreamRequestTarget.java:241)
at org.apache.wicket.request.target.resource.ResourceStreamRequestTarget.respond(ResourceStreamRequestTarget.java:150)
at org.apache.wicket.request.AbstractRequestCycleProcessor.respond(AbstractRequestCycleProcessor.java:105)
at org.apache.wicket.RequestCycle.respond(RequestCycle.java:1267)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1334)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
Is it normal that there are more than 2 minutes between the two logs ?
Regarding the error, not sure to understand why. If correctly understand the style definition :
<Rotation>
<ogc:Function name="toDegrees">
<ogc:Function name="atan2">
<ogc:PropertyName>Band2</ogc:PropertyName>
<ogc:PropertyName>Band1</ogc:PropertyName>
</ogc:Function>
</ogc:Function>
</Rotation>
It would mean than the output of atan2 cannot be an input of toDegrees ?
As far as I look into my input file, everything looks OK regarding the values (between -35 and 96 for U, and between -59 and 61 for V).
De : andrea.aime@...84... [mailto:andrea.aime@…84…] De la part de Andrea Aime
Envoyé : vendredi 29 mai 2015 14:05
À : VILLARD, Pierre
Cc : geoserver-users@lists.sourceforge.net
Objet : Re: [Geoserver-users] Wind arrows
Hi PIerre,
question, are you reprojecting the raster data in the process?
In other words, is your request coordinate reference system different than the data one?
We have had reports that something is not working in those cases, and the output remains
blank, but haven't had time to look into it so far.
On Fri, May 29, 2015 at 1:28 PM, VILLARD, Pierre <pierre.villard@...5083...> wrote:
Hello,
I am not sure if I should use this mailing list to ask this question... correct me if I am wrong.
I have a geoTiff file containing U and V wind components in two separate bands and I am trying to display it on geoserver with arrows. I am on geoserver 2.6.2 and I am following the indications here : http://geoserver.geo-solutions.it/edu/fr/wps/rendering_tx.html
I have added the following style :
<StyledLayerDescriptor version="1\.0\.0"
xmlns="http://www.opengis.net/sld" xmlns:gml="http://www.opengis.net/gml"
xmlns:ogc="http://www.opengis.net/ogc" xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/sld \./StyledLayerDescriptor\.xsd">
<NamedLayer>
<Name>contour\_lines</Name>
<UserStyle>
<FeatureTypeStyle>
<Transformation>
<ogc:Function name="gs:RasterAsPointCollection">
<ogc:Function name="parameter">
<ogc:Literal>data</ogc:Literal>
</ogc:Function>
</ogc:Function>
</Transformation>
<Rule>
<TextSymbolizer>
<Label><\!\[CDATA\[ \]\]></Label> <\!\-\- fake label \-\->
<Graphic>
<Mark>
<WellKnownName>shape://carrow</WellKnownName>
<Fill>
<CssParameter name="fill">\#000000</CssParameter>
</Fill>
</Mark>
<Size>
<ogc:Mul>
<ogc:Function name="sqrt">
<ogc:Add>
<ogc:Mul>
</ogc:Mul>
<ogc:Mul>
</ogc:Mul>
</ogc:Add>
</ogc:Function>
<ogc:Literal>200</ogc:Literal>
</ogc:Mul>
</Size>
<Rotation>
</ogc:Function>
</ogc:Function>
</Rotation>
</Graphic>
<Priority>
<ogc:Add>
<ogc:Mul>
</ogc:Mul>
<ogc:Mul>
</ogc:Mul>
</ogc:Add>
</Priority>
</TextSymbolizer>
</Rule>
</FeatureTypeStyle>
</UserStyle>
</NamedLayer>
</StyledLayerDescriptor>
And when I added my layer, I renamed the two bands in Band1 and Band2 and selected the style.
But when previewing the layer, it stays desperately blank without any error message.
Do you have any idea where I should look for to solve this issue ?
Thanks !
Pierre.
This message contains information that may be privileged or confidential and is the property of the Capgemini Group. It is intended only for the person to whom it is addressed. If you are not the intended recipient, you are not authorized to read, print, retain, copy, disseminate, distribute, or use this message or any part thereof. If you receive this message in error, please notify the sender immediately and delete all copies of this message.
Geoserver-users mailing list
Meet us at the INSPIRE Conference in Lisbon 25-29 May 2015! Visit http://goo.gl/WHKDXT for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
