[Geoserver-users] windows service - gdal
Any ideas?
Sent: Tuesday, July 05, 2011 9:23 PM
To: ‘geoserver-users@anonymised.comge.net’
Subject: windows service - gdal
Dear All,
I installed geoserver and used it to view ECW photos, everything works fine when I run geoserver manually, however, when I run it as a windows service ECW photos cause the following exception (other layers show up):
2011-07-05 05:54:22,933 ERROR [geoserver.global] -
  • GEOSERVER_DATA_DIR: D:\gis_data\data_dir
2011-07-05 05:54:23,668 WARN [referencing.factory] - Axis elements found in a wkt definition, the force longitude first axis order hint might not be respected:
PROJCS[“WGS84 / Simple Mercator”, GEOGCS[“WGS 84”, DATUM[“WGS_1984”, SPHEROID[“WGS_1984”, 6378137.0, 298.257223563]], PRIMEM[“Greenwich”, 0.0], UNIT[“degree”, 0.017453292519943295]], PROJECTION[“Mercator_1SP_Google”], PARAMETER[“latitude_of_origin”, 0.0], PARAMETER[“central_meridian”, 0.0], PARAMETER[“scale_factor”, 1.0], PARAMETER[“false_easting”, 0.0], PARAMETER[“false_northing”, 0.0], UNIT[“m”, 1.0], AXIS[“x”, EAST], AXIS[“y”, NORTH], AUTHORITY[“EPSG”,“54004”]]
2011-07-05 05:54:31,668 ERROR [config.XMLConfiguration] - Configuration file cannot be read or does not exist!
2011-07-05 05:54:31,668 ERROR [layer.TileLayerDispatcher] - Configuration D:\Servers\GeoServer\webapps\geoserver..\resources contained no layers.
2011-07-05 05:54:31,668 ERROR [layer.TileLayerDispatcher] - Error reading service information from D:\Servers\GeoServer\webapps\geoserver..\resources: Error parsing file D:\Servers\GeoServer\webapps\geoserver..\resources\geowebcache.xml
2011-07-05 06:12:38,760 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/vnd.google-earth.kmz xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2011-07-05 06:12:38,760 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/vnd.google-earth.kmz’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2011-07-05 06:12:38,760 WARN [geoserver.web] - Unable to find property: ‘format.wms.kmz’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2011-07-05 06:12:38,760 WARN [geoserver.web] - Unable to find property: ‘format.wms.openlayers’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2011-07-05 06:12:38,760 WARN [geoserver.web] - Unable to find property: ‘format.wms.text/html’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2011-07-05 06:12:38,760 WARN [geoserver.web] - Unable to find property: ‘format.wms.atom’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2011-07-05 06:12:38,760 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/atom xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2011-07-05 06:12:38,760 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2011-07-05 06:12:38,760 WARN [geoserver.web] - Unable to find property: ‘format.wms.image/svg’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2011-07-05 06:12:38,760 WARN [geoserver.web] - Unable to find property: ‘format.wms.image/svg xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2011-07-05 06:12:53,963 ERROR [geoserver.ows] -
java.lang.NullPointerException
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:937)
at org.geoserver.catalog.impl.CoverageInfoImpl.getGridCoverageReader(CoverageInfoImpl.java:162)
at org.geoserver.wms.MapLayerInfo.getCoverageReader(MapLayerInfo.java:332)
at org.geoserver.wms.GetMap.run(GetMap.java:299)
at org.geoserver.wms.GetMap.run(GetMap.java:107)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:352)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:90)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:33)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:51)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy26.getMap(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:630)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:234)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
at org.springframework.security.ui.basicauth.BasicProcessingFilter.doFilterHttp(BasicProcessingFilter.java:174)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
any idea?
Thanks
Hi Ali,
did you tried this suggestion?
http://docs.geoserver.org/latest/en/user/data/gdal.html#note-on-running-geoserver-as-a-service-on-windows
Note sure whether this is related to your issue. Please, let us know.
Best Regards,
Daniele
On Wed, Jul 6, 2011 at 8:52 AM, Ali Taha <ali.taha@anonymised.com> wrote:
Any ideas?
To: ‘geoserver-users@lists.sourceforge.net’
Dear All,
any idea?
Thanks
All of the data generated in your IT infrastructure is seriously valuable.
Why? It contains a definitive record of application performance, security
threats, fraudulent activity, and more. Splunk takes this data and makes
sense of it. IT sense. And common sense.
http://p.sf.net/sfu/splunk-d2d-c2
Geoserver-users mailing list
Ing. Daniele Romagnoli
Software Engineer
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://it.linkedin.com/in/danieleromagnoli
Dear Daniele,
Thank you very much, it worked,
Thanks
From: dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com] On Behalf Of Daniele Romagnoli
Sent: Friday, July 08, 2011 7:35 PM
To: Ali Taha
Subject: Re: [Geoserver-users] windows service - gdal
Hi Ali,
Best Regards,
Daniele
On Wed, Jul 6, 2011 at 8:52 AM, Ali Taha <ali.taha@anonymised.com3924…> wrote:
Any ideas?
To: ‘geoserver-users@anonymised.comeforge.net’
Dear All,
any idea?
Thanks
Software Engineer
