The windows service will not start in the latest stable build. I get an error in the log like this in the wrapper.log:
STATUS | wrapper | 2010/04/23 09:00:41 | --> Wrapper Started as Service
STATUS | wrapper | 2010/04/23 09:00:41 | Java Service Wrapper Community Edition 3.3.3
STATUS | wrapper | 2010/04/23 09:00:41 | Copyright (C) 1999-2009 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2010/04/23 09:00:41 | http://wrapper.tanukisoftware.org
STATUS | wrapper | 2010/04/23 09:00:41 | Launching a JVM...
FATAL | wrapper | 2010/04/23 09:00:41 | Unable to execute Java command. The system cannot find the file specified. (0x2)
FATAL | wrapper | 2010/04/23 09:00:41 | "%JAVA_HOME%\bin\java" -Djetty.home=. -DGEOSERVER_DATA_DIR="C:\Program Files\GeoServer 2.0.1\data_dir" -Xms16m -Xmx128m -Djava.library.path="bin/wrapper/lib" -classpath "bin/wrapper/lib/wrapper.jar;start.jar;lib/ant-1.6.4.jar;lib/ant-optional-1.5.1.jar;lib/commons-el-1.0.jar;lib/commons-logging-1.0.jar;lib/jasper-compiler-5.5.15.jar;lib/jasper-compiler-jdt-5.5.15.jar;lib/jasper-runtime-5.5.15.jar;lib/jetty-6.1.8.jar;lib/jetty-util-6.1.8.jar;lib/jsp-api-2.0.jar;lib/log4j-1.2.14.jar;lib/servlet-api-2.5-6.1.8.jar;lib/slf4j-simple-1.0.1.jar;lib/xercesImpl-2.6.2.jar;lib/xmlParserAPIs-2.6.2.jar" -Dwrapper.key="VuL3VWeZ4aWe2Efn" -Dwrapper.port=32000 -Dwrapper.jvm.port.min=31000 -Dwrapper.jvm.port.max=31999 -Dwrapper.pid=4676 -Dwrapper.version="3.3.3" -Dwrapper.native_library="wrapper" -Dwrapper.service="TRUE" -Dwrapper.cpu.timeout="10" -Dwrapper.jvmid=1 org.tanukisoftware.wrapper.WrapperSimpleApp
org.mortbay.start.Main etc/jetty.xml
FATAL | wrapper | 2010/04/23 09:00:41 | Critical error: wait for JVM process failed
The bin/startup.bat does work however.
Regards
--Don
donvollmer@anonymised.com
