[Geoserver-users] WMS address
As I said i am a novice fumbling towards my modest goal of publishing some shapefiles on a WMS.
My layers are in place and I can see them using OpenLayers via Layer preview but I am struggling to find the service from my other software (which supports WMS) and I am not sure what address to use. The address in OpenLayers is…
myPcServername:portNo/geoserver/wms?service=WMS&version=1.1.0&request=GetMap&layers=J02-New&styles=&bbox=-244588.376,6176682.56,1198377.782,7691252.968&width=487&height=512&srs=EPSG:23031&format=application/openlayers
The application I am using trims this address and looks for the service at…
http:// myPcServername:portNo /geoserver/wms?f=json
but claims that there was no response.
I couldn’t find a lot of information about this anywhere – any idea what I am doing wrong?
I gave my Workspace a namespace URI of http:// myPcServername:portNo /MarksTest, is that how it is supposed to be used?
Should that then be part of the WMS address?
Does the fact that OpenLayers can preview my file mean that the WMS is up and running correctly?
Med vennlig hilsen / Kind regards
Mark Hall
Mark Hall
Thanks Jukka but I don’t really understand. For the sake of simplicity lets say I want to be able to look at my shapefiles in Google earth.
In google earth I can add some publicly available WMS as a new layer – everything works fine.
I have a geoserver set up with my shapefiles and they display fine in OpenLayers via the Layer preview options. I now want to set up my WMS such that I can display the same shapefile in google earth. I naively thought that that was how they were served up to OpenLayers but just using the same address returns a message that the server isn’t responding. Where do I start? Any (simple) examples I can read / follow?
Mark Hall
From: Rahkonen Jukka [mailto:Jukka.Rahkonen@anonymised.com]
Sent: 25 November 2011 13:19
To: Mark Hall; ‘geoserver-users@lists.sourceforge.net’
Subject: Re: WMS address
The address to give for WMS clients like QGis, Kosmo GIS, OpenJUMP, gvSIG, MapInfo, ArcGIS etc. is
http://server:port/geoserver/wms?
Clients are adding the rest. If you want to read the capabilities with a browser you must add some parameters yourself.
http://demo.opengeo.org/geoserver/wms?service=wms&version=1.1.1&request=getCapabilities
Your browser does not necessarily show the response because of an odd MIME type used in WMS 1.1.1. That’s normal and you can just save the result on disk and open with a text editor. Try then the same with your own server.
-Jukka Rahkonen-
Mark Hall
Notice: This message and any attachments are solely intended for the addressees and are confidential.
If you receive this message in error, please delete it and immediately notify the sender. Any uses not in accordance with its purpose, any dissemination or disclosure, either whole or partial, is prohibited except formal approval. The internet cannot guarantee the integrity of this message. VNG Norge AS will therefore not be liable for the message if modified. Thank you.
Can you start by making sure that routers, firewalls etc are configured
so you can in fact reach the geoserver instance on that port? If you are
looking at the packets in firebug, and seeing no response, then it
suggests your web server configuration is not working.
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
