[Geoserver-users] WMS and Google Maps API v3
I am trying to load wms layers on top of google maps, but I am having problems, where just the google maps appears and no layers. I am using Geoserver 2.0.2. Does any one have any full example scripts I can look at to see where I am going wrong?
Steve
________________________________________________________________________
Please consider the environment before printing this e-mail
MVA Consultancy Limited is a limited liability Company registered in England and Wales, registration number: 3383212, registered address: First Floor, Dukes Court, Duke Street, Woking, Surrey, GU21 5BH, United Kingdom.
The information transmitted in this e-mail and any attached files is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. Any opinions expressed in the e-mail are those of the individual and not necessarily the Company. Any review, retransmission, dissemination or other use of or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited. If you received this in error you should not copy it,
disclose its contents to anyone else or take any action based on it, please contact the sender and delete the material from any computer.
On Fri, Aug 20, 2010 at 8:16 AM, Steven Reid <streid@anonymised.com> wrote:
Sounds like a client problem - you'll probably get a better answer
where ever users of the client you are using hang out.
If I'm wrong and this is a GeoServer problem then you need to make
your question clearer - what exactly goes wrong with your WMS request?
What errors show up in the GeoServer log
($GEOSERVER_DATA_DIR/logs/geoserver.log)? etc.
Ian
Ian Turton
