If you sent a GetFeatureInfo-request to a layer that have a column with the
date-format in a PostGisDatabase, Geoserver sometimes add a time to the
date. This is a problem when it is changed into UTC-time and the date is
changed which happens with json.
I made a few tests for this, GeoJson (this also stands for GML 3.1 and GML 3.2) have the correct default behavior,
i.e. they take into account the timezone when encoding a date \ time attribute.
The following formats: text/html, text/plain, text/xml and application/vnd.ogc.gml (GML2), don’t have any special
treatment for date \ times and simply do a to string regardless of the timezone or time format. In my opinion this
is a bug and deserves a JIRA ticket (maybe one already exists).
For the well behaved formats (GeoJson, GML 31 and GML 32) it is possible to control if GeoServer will or will not
take into account the the time zone when encoding date \ time attributes using this Java property:
-Dorg.geotools.localDateTimeHandling=true
This will make GeoServer stop converting the data \ time to UTC-time, which should give you the results you are expecting.
Nuno Oliveira
On 09/29/2017 02:09 PM, perre wrote:
Hi
INFO_FORMAT result
text/html 2017-06-01 00:00
text/plain 2017-06-01
text/xml 2017-06-01
application/vnd.ogc.gml 2017-06-01
application/json 2017-05-31Z
Postgis (date) 2017-06-01
Sent from: [http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html](http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html)
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: [http://www.ianturton.com/talks/foss4g.html#/](http://www.ianturton.com/talks/foss4g.html#/)
- The GeoServer user list posting guidelines: [http://geoserver.org/comm/userlist-guidelines.html](http://geoserver.org/comm/userlist-guidelines.html)
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
Nuno Oliveira
GeoServer Professional Services from the experts! Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
On Tue, Oct 3, 2017 at 10:31 AM, Nuno Oliveira <
Yep... would be nice to have that as a config flag in the UI (as opposed to
a system variable).
And yes, it's hard for many to come to terms to it, but dates do have a
timezone too, as I'm writing now
it's Tuesday here and in most of the world, but in Honolulu, it's still
Monday.
For international tenders there is even a special timezone used for
deadlines known as AOE (Anywhere
On Earth), when a date is chosen to be the deadline for presenting an
offer, it's often associated to AOE
to avoid the confusion of just stating a date:
