[Geoserver-users] Wms getmap-when layers num more than 2, fault occurs.
Hello, I met a problem when i use wms to get map. As there are multiple layers in server, when i create URL, i give layers three or more values, then server return “indexoutofboundsexception: Index:2, size:2 index:2,size:2”. Then i just give layers two values, like this"layers=SM:road,SM:poi", the result is good as a png picture.
So, i wanna ask two questions here: How can i use wms to get multi-layer map? Is the fault above result from wms limitation?
Any help is appreciated, thanks a lot!
发自我的 Windows Phone
are you also specifying other parameters such as styles or cql_filter in the wms getmap request? These usually requires that the number of values match the ones used in layers.
You are probably adding a new layer, without supplying the needed values for one of those. Could you share the complete url with 3 layers you are using?
Thanks
Mauro
2014-09-24 8:38 GMT+02:00 邓冲 <buynowdays@anonymised.com>:
发自我的 Windows Phone
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Geoserver-users mailing list
