[Geoserver-users] WMS image broken in IE
Hello
I have a GeoServer instance acting as a WMS. About one time out of two
IE (7&8) fails to display the image, the problem occurs in OpenLayers
(pink image) and outside OpenLayers, i.e. by adding the WMS URL in
IE's address bar. I use ieHTTPHeaders in IE to watch the HTTP requests
and I always get "200 OK", even when IE fails to display the image.
If you want to reproduce the problem, try loading the following URL in
IE, and reload the page until it fails. In my case I get about one
failure out of two page reloads.
<http://drebretagne-geobretagne.demo-camptocamp.com/geoserver/wms?SERVICE=WMS&LAYERS=topp%3Acommunes_geofla&TRANSPARENT=true&VERSION=1.1.1&FORMAT=image%2Fpng&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A2154&BBOX=-97099.811756103,6680300.064638,600099.8117561,6919699.935362&WIDTH=1245&HEIGHT=427&gt;
Has anyone else got hit by this?
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine@anonymised.com
http://www.camptocamp.com
Eric Lemoine ha scritto:
Hello
I've tried with the following combinations:
- xp sp3, ie6
- xp sp3, ie7
They are two separate VirtualBox machines. Tried 20-30 times
in a row with each one, never got back a broken image.
Maybe it takes Vista?
I also tried running:
curl -o "c2c`date +%F_%T`.png" "http://drebretagne-geobretagne.demo-camptocamp.com/geoserver/wms?SERVICE=WMS&LAYERS=topp%3Acommunes_geofla&TRANSPARENT=true&VERSION=1.1.1&FORMAT=image%2Fpng&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A2154&BBOX=-97099.811756103,6680300.064638,600099.8117561,6919699.935362&WIDTH=1245&HEIGHT=427&quot;
a number of times on my linux box to see if the file returned
was any different but all seemed perfectly equal:
aaime@anonymised.com:/tmp/c2c$ ls -l
totale 3472
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:23.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:27.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:28.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:29.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:30.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:31.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:32.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:33.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:34.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:36.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:37.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:38.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:39.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:41.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:42.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:43.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:44.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:45.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:46.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:47.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:48.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:49.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:50.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:51.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:52.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:53.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:54.png
-rw-r--r-- 1 aaime aaime 124518 2009-09-09 14:49 c2c2009-09-09_14:49:55.png
Do you get anything in the GeoServer own logs ($DATA_DIR/logs/geoserver.log) in correspondance of the
corrupted images?
Andrea Aime
OpenGeo - http://opengeo.org
Hello
- xp sp3, ie6
- xp sp3, ie7
Thanks for trying Andrea.
XP here too. I just tried again and got a broken image at the third
attempt. Dunno why it works for you at this point.
totale 3472
corrupted images?
nothing in the logs, I guess it's a IE thing since the problem never
occurs in FF.
Eric Lemoine
I don't think this has much to do with GeoServer. Seems like there are a few issues that can cause PNG problems:
http://www.vistaheads.com/forums/microsoft-public-internetexplorer-general/339961-re-ie7-png-images-do-not-display.html#post1184907
-Arne
Eric Lemoine wrote:
Hello
Arne Kepp
Yeah, i didn't mean to say it had to do with GeoServer, I just wanted
to know if others on the list experienced this.
Thanks for the link. This is helping.
Eric Lemoine
