Did you set up a 'featureType' as well?
After the data store, do Configure -> Data -> FeatureType -> New
and you should see it available from a drop down list.
We want to make this easier in the future, as for shapefiles in particular there shouldn't need to be two places. And be sure to hit 'submit' and 'apply' after each, and 'save' to persist to disk.
Also, did you manage to find: http://docs.codehaus.org/display/GEOSDOC/User+Tutorial+Shapefile ?
It should walk you through.
best regards,
Chris
Ryan Ollerenshaw wrote:
Sorry to be posting to the list so soon but i can not find any good documentation on how to set up a WMS using GeoServer. I have added my data to GeoServe using the admin tool
Configure -> Data -> Stores -> New
Then i provided the path to my shapefile, and from what i can see from the documentation that is all that you need to do. Bus when i go to:
http://neuron:8085/geoserver/wms?bbox=-130,24,-66,50&request=GetMap&layers=themis&width=800&height=400&srs=EPSG:4326&Format=image/gif
i get an exception:
<ServiceExceptionReport version=" 1.1.1">
<ServiceException code="LayerNotDefined">
java.util.NoSuchElementException: Could not locate FeatureTypeConfig 'themis'
</ServiceException>
</ServiceExceptionReport>
any ideas on what i could be missing?
!DSPAM:1003,44d0eaaf320911410093335!
opinions on IT & business topics through brief surveys -- and earn cash
Geoserver-users mailing list
Chris Holmes
The Open Planning Project
http://topp.openplans.org
