[Geoserver-users] WMS layer in Google Earth failed
I just started to learn how to setup goeserver in my workstation and publish WMS layers, I can successfully see the WMS layer map in ArcGIS Desktop, ArcGIS Pro and Global Mapper. Please see example from ArcGIS Desktop
But in Google Earth, I keep getting “WMS Capability fetch failed” message. Does anyone know why and how I can fix it?
Daniel
Daniel,
try with the complete GetCapabilities URL.
In your case :
http://2014-0301:8080/geoserver/MEMS/ows?request=GetCapabilities&service=WMS
Try to see if anything comes up with this url in a browser.
Hope this helps.
Envoyé à partir d’Outlook
De : Daniel Yu <dyu@anonymised.com.11085…>
Envoyé : 23 septembre 2021 14:25
À : geoserver-users@lists.sourceforge.net geoserver-users@anonymised.coms.sourceforge.net
Objet : [Geoserver-users] WMS layer in Google Earth failed
Daniel
Hi Olivier,
Yes, I got below and still error in Google Earth.
Daniel
Sent: September 23, 2021 1:10 PM
To: Daniel Yu dyu@anonymised.com; geoserver-users@anonymised.comorge.net
Subject: Re: WMS layer in Google Earth failed
CAUTION: This email originated from outside of MEMS. Do not click links or open attachments unless you know the content is safe.
Daniel,
In your case :
Hope this helps.
De : Daniel Yu <dyu@anonymised.com>
À : geoserver-users@lists.sourceforge.net <geoserver-users@lists.sourceforge.net>
Daniel
in getcapabilities you should have something like…
image/png
application/atom+xml
application/json;type=utfgrid
application/pdf
application/rss+xml
application/vnd.google-earth.kml+xml
application/vnd.google-earth.kml+xml;mode=networklink
see this
https://docs.geoserver.org/latest/en/user/services/wms/googleearth/quickstart.html#direct-access-to-kml
and in google earth try with network link
http://2014-0301:8080/geoserver/wms/kml?layers=MEMS:AER_WELLS_BH
Daniel Yu <dyu@anonymised.com> escreveu no dia quinta, 23/09/2021 à(s) 20:27:
www.vfonsecaz.pt
Hi Vitor,
Thanks for this.
I can use network link but still need to use IP address.
question.
  • Use network link it actually shows layer in vector format?
  • I found my layer symbol disappear when I zoon in. you know why?
Before zoom in
After zoom in
My style (SLD)
<?xml version="1.0" encoding="ISO-8859-1"?>
<StyledLayerDescriptor version=“1.0.0”
xsi:schemaLocation=http://www.opengis.net/sld StyledLayerDescriptor.xsd
xmlns=http://www.opengis.net/sld
xmlns:ogc=http://www.opengis.net/ogc
xmlns:xlink=http://www.w3.org/1999/xlink
xmlns:xsi=http://www.w3.org/2001/XMLSchema-instance>
Point as graphic
GeoServer SLD Cook Book: Point as graphic
<OnlineResource
xlink:type=“simple”
xlink:href=“well_centre3.png” />
image/png
32
ogc:PropertyNameUWI</ogc:PropertyName>
Arial
12
normal
bold
0.5
-1.5
0
5
#000000
Sent: September 24, 2021 2:45 AM
To: Daniel Yu <dyu@…11085…>
Cc: Olivier Gagnon <mcnolii@…95…>; geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] WMS layer in Google Earth failed
**image/png
**application/atom+xml
**application/json;type=utfgrid
**application/pdf
**application/rss+xml
____application/vnd.google-earth.kml+xml
____application/vnd.google-earth.kml+xml;mode=networklink
see this
Daniel Yu <dyu@…11085…> escreveu no dia quinta, 23/09/2021 à(s) 20:27:
Hi Olivier,
Daniel
To: Daniel Yu <dyu@…11085…>; geoserver-users@lists.sourceforge.net
Daniel,
In your case :
Hope this helps.
De : Daniel Yu <dyu@…11085…>
Daniel
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
www.vfonsecaz.pt
Consider adding the complete URL information: SERVICE=WMS&REQUEST=GETCAPABILITIES&ZVERSION=1.3.0
I expect the other projects filled in these details for you.
Jody Garnett
Yes network link can be vector format as long as you use a wfs url with output format kml (application%2Fvnd.google-earth.kml%2Bxml)
e.g.
http://<geoserver_url>/ows?SERVICE=WFS&Request=GetFeature&VERSION=1.3.0&TYPENAME=workspace:layer_namet&outputFormat=application%2Fvnd.google-earth.kml%2Bxml
Daniel Yu <dyu@anonymised.com> escreveu no dia sexta, 24/09/2021 à(s) 15:34:
www.vfonsecaz.pt
