[Geoserver-users] WMS long urls (GetMap)
Hi everyone! I have an issue that I’m struggling to resolve and I’m hoping someone may be able to assist or guide me.
I am trying to use the GetMap feature from the WMS service (which works). However it seems when I add a cql_filter to the url, I get an error message that the request is invalid. If I remove some other get fields within the url (layers in particular - which shortens the url), then I get a response.
It seems that when the url is over 200+ characters, I get the issue. My question is, can I somehow get geoserver to accept longer URLs? I cannot use POST because my implementation uses Mapbox which calls a url and not post variables.
Any help would be appreciated, thank you!
Perhaps you can find some help in this post : https://stackoverflow.com/questions/1289585/what-is-apaches-maximum-url-length.
Do you use Tomcat to host Geoserver?
Alexandre
Alexandre Gacon
If you have a lot of layers listed could you aggregate them into a layer grouping?
https://docs.geoserver.org/latest/en/user/data/webadmin/layergroups.html
This could give a single layer name instead of lots.
Matthew Snape
Associate
RPS | Consulting UK & Ireland
T +44 1235 821 888
E snapem@…10313…
Sent: 18 June 2020 15:01
Subject: [Geoserver-users] WMS long urls (GetMap)
CAUTION: This email originated from outside of RPS.
You could switch to a POST request and then URL length ceases to be an issue.
Ian
Ian Turton
Hi everyone, thank you for such quick responses!
So in terms of if I’m using Tomcat to serve Geoserver, I’m not certain - I am using a standard install so I thought this used the built-in webserver - which I assume is Java?
Secondly, while joining two layers together might help a bit to keep the url length down - it won’t be a permanent solution for me because of the dynamism required by the cql_filter (this would vary in length)
Thirdly, unfortunately I cannot use POST because I’m integrating it into Mapbox which seems to want a url (no post options as far as I can tell).
Thank you so much for all your responses so far, if there is any other suggestion I’d really appreciate it - for example a way to perhaps alter the webserver to handle longer urls?
Ian
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Ian Turton
What a lot of restrictions to work with.
The built-in application server is called jetty, and it does offer some control over the URL length supported: https://stackoverflow.com/questions/19549163/set-maximum-url-length-in-jetty
Beyond that you are reaching the limits of what URLs can do due to a limitation of the mapbox api.
Crazy ideas to try next
  1. If you are just filtering content, make a parameterized sql view that takes the parameters you need to control, and hope you can stay under the limit (as parameters are smaller than cql expression)
  2. You may do this for any content if you make a paramertized style
Jody Garnett
Is there a missing zero there? The practical maximum URL length is around 2000, see also:
https://stackoverflow.com/questions/29458445/what-is-a-safe-maximum-length-a-segment-in-a-url-path-should-be/33733386
https://www.abramillar.com/2018/02/12/urls-maximum-length-long-best/#:~:text=What%20Is%20the%20Maximum%20Length,able%20to%20load%20your%20page.
Even a simple map preview URL generated by GeoServer goes beyond 200, I picked one at random for a single layer
it was 240 chars.
If you’re hitting the 2000 chars limit, either find a way to make URLs shorter, or better yet, switch to a base library that is not limited to GET, such as OpenLayers.
Another possible option would be to add a custom proxy in between, you give it “filters” and get back an identifier for each of them, then add just the id in the request,
and as the request goes through the proxy, it will expand the full filter (since the hard limit is normally found in the browser, using a server side trick like this one would dodge it).
Come to think of it, the GeoServer community module called “parameter extractor” does some of that, and has a REST API to create new mappings… but you’ll have to access it
with administrative credentials, which might be a significant limit for you. See:
https://docs.geoserver.org/stable/en/user/community/params-extractor/index.html
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
