[Geoserver-users] WMS Response times Web Mercator vs WGS84
Hello users,
We were running some WMS performance tests against our image mosaic raster layers and found that performance was significantly slower (almost 40%) when our SRS was Web Mercator (EPSG:3857) compared to WGS84 (EPSG:4326).
Our source data is in NAD83 (2011) UTM. There are more transformation operations going from say EPSG:6341 to EPSG:3857 than EPSG:6341 to EPSG:4326, so I suspect that accounts for the slowness.
My question: is there any suggestions to reduce the response difference?
Thanks.
Lonnie
Most likely I’d say the only optimization is to transform your mosaic into the most-used SRS.
On Thu, Sep 21, 2017 at 12:34 PM, Lonnie Matsuno <lonnie.matsuno@anonymised.com> wrote:
Hello users,
Thanks.
Lonnie
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
Geoserver-users@anonymised.com.382…sourceforge.net
Jason Newmoyer
Newmoyer Geospatial Solutions
843.606.0424
jason@anonymised.com
This is what we did with all our imagery received. We wrote a process to transform everything into 4326 as a standard base. If someone needs the imagery in another projection, that is the one off that we let GeoServer transform on the fly.
If you have a need to supply as rule multiple projections, then you can pre-run the transformations and expose through different workspaces/datastore/layer etc. that is specific to the required projection. This of course causes storage requirements to swell dramatically.
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, A Polaris Alpha Company
Description: Description: Description: cid:image001.png@...5633...
Jason Newmoyer
843.606.0424
jason@…7364…
On Thu, Sep 21, 2017 at 12:34 PM, Lonnie Matsuno <lonnie.matsuno@…2549…> wrote:
Hello users,
Thanks.
Lonnie
