[Geoserver-users] WMS Time Support using ImageMosiac Plug-in
I did as you said and i can not see my image at all, ever when i do give TIME parameter in the request.
Any other ideas
Kuba
On Aug 27, 2010, at 12:21 AM, radovan hilbert wrote:
i think, i had the same problem, and resoult was very easy …
just after all the procedure with imagemosaic, change created .prj with your own .prj - according to your system, of course with the same name :slight_smile:
then it will work - in my case works :slight_smile:
all the best
d.
2010/8/27 Jakub Rojek <kuba.rojek@anonymised.com>
I am trying to make use of some image time series using ImageMosaic Plug-In. The files are called as follows
MOD13Q1.200601.tif
MOD13Q1.200602.tif
MOD13Q1.200603.tif
and this is the request, which I send to the geoserver:
http://localhost:8080/geoserver/wms?service=WMS&version=1.1.0&request=GetMap&layers=rio:time&styles=&bbox=-45.0,-23.402,-40.898,-20.7&width=512&height=337&srs=EPSG:4326&format=application/openlayers&TIME=200601
The problem is that I can see only black square instead of the image. When I remove TIME=200601 the image is rendered as it should be.
I have made this following the this blog:
http://geo-solutions.blogspot.com/2009/12/adding-time-support-to-geoserver-and.html
Do you know where is the problem. If you know any tutorials to WMS Time Support I would highly appreciate.
Thanks in advance
Kuba
Sell apps to millions through the Intel(R) Atomβ„’ Developer Program
Be part of this innovative community and reach millions of netbook users
worldwide. Take advantage of special opportunities to increase revenue and
speed time-to-market. Join now, and jumpstart your future.
http://p.sf.net/sfu/intel-atom-d2d
Geoserver-users mailing list
