[Geoserver-users] WMS Transparent Background
Hello,
I'm requesting geoserver 2.3.3 with transparent=true; format=image/png but the result has black borders where no data is in the dataset.
http://srvgis:20000/geoserver/trimet_portland/wms?service=WMS&version=1.1.0&request=GetMap&layers=trimet_portland:20ft_6in&styles=&bbox=-123.1624280193816,45.26060070985506,-122.32294147052025,45.67139920561071&width=1400&height=900&srs=EPSG:4326&format=image%2Fpng&transparent=true
We tried several programs (MapInfo Professional, TatukGIS Viewer, FME Universal Viewer, IE, Firefox, .) all are showing the black borders.
Any ideas? Must I configure something in geoserver for transparent support?
Yours Rüdiger
What type of dataset (raster, vector) … also what is the fully qualified domain of your server? All we have is srvgis, which doesn’t do us much good.
On Thu, Aug 8, 2013 at 9:16 AM, Gubler, Ruediger <rgubler@anonymised.com> wrote:
Hello,
I’m requesting geoserver 2.3.3 with transparent=true; format=image/png but the result has black borders where no data is in the dataset.
Yours Rüdiger
Get 100% visibility into Java/.NET code with AppDynamics Lite!
It’s a free troubleshooting tool designed for production.
Get down to code-level detail for bottlenecks, with <2% overhead.
Download for free and get started troubleshooting in minutes.
http://pubads.g.doubleclick.net/gampad/clk?id=48897031&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Dear Rudiger,
what kind of dataset is this one? If we are talking about raster there
are a few options to exercise to make the no data transparent.
Anyway, we need to know more about what you are doing.
Simone Giannecchini
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Thu, Aug 8, 2013 at 3:28 PM, Mike Grogan <d.michael.grogan@anonymised.com> wrote:
What type of dataset (raster, vector) ... also what is the fully qualified
domain of your server? All we have is srvgis, which doesn't do us much
good.
Hello,
support?
Yours Rüdiger
It's a free troubleshooting tool designed for production.
Hello,
we are using GeoTiff files with the Image Mosaik plugin.
Do you need further information?
Yours Rüdiger
Von: simboss1@anonymised.com [mailto:simboss1@anonymised.com] Im Auftrag von Simone Giannecchini
Gesendet: Freitag, 9. August 2013 01:04
An: Mike Grogan
Cc: Gubler, Ruediger; geoserver-users@lists.sourceforge.net
Betreff: Re: [Geoserver-users] WMS Transparent Background
Dear Rudiger,
what kind of dataset is this one? If we are talking about raster there are a few options to exercise to make the no data transparent.
Simone Giannecchini
@simogeo
Founder/Director
qualified domain of your server? All we have is srvgis, which doesn't
do us much good.
Hello,
t=true
support?
Yours Rüdiger
--------- Get 100% visibility into Java/.NET code with AppDynamics
Lite!
clktrk _______________________________________________
Lite!
Hello,
I found the trick:
Yesterday I set the OutputTransparentColor to 000000 but there was no change visible.
As I had a look this morning on this parameter it was empty!?
Changing the parameter and clicking the store button on the same tab does nothing.
I must click the store button on the last tab of the layer setting to get the parameter stored.
Is this a bug or a wrong translation of the german geoserver?
Yours Rüdiger
Von: Gubler, Ruediger
Gesendet: Freitag, 9. August 2013 07:50
An: geoserver-users@lists.sourceforge.net
Hello,
Yours Rüdiger
An: Mike Grogan
Dear Rudiger,
Simone Giannecchini
@simogeo
Founder/Director
do us much good.
Hello,
t=true
support?
Yours Rüdiger
Lite!
Lite!
Ciao Rudiger,
not sure about the german translation but everytime you make a change
to the layer definition you should save it to persist it using the
button at the bottom
of the page which is there regardless of the tab you are looking at.
That said, you can play with the input and output transparent color
setting to decide which color to make transparent on the input tiles
or on the output mosaic.
Take also into account the BackgroundValues setting that allows you to
set the value for the void areas.
Simone Giannecchini
more information.
@simogeo
Founder/Director
On Fri, Aug 9, 2013 at 8:06 AM, Gubler, Ruediger <rgubler@anonymised.com> wrote:
Hello,
I found the trick:
Yours Rüdiger
Hello,
Yours Rüdiger
An: Mike Grogan
Dear Rudiger,
Simone Giannecchini
@simogeo
Founder/Director
do us much good.
Hello,
t=true
support?
Yours Rüdiger
Lite!
Lite!
Hello,
I found the trick:
change visible.
nothing.
You might be expiriencing this one, althought I have not seen it happen
with the layer page:
http://jira.codehaus.org/browse/GEOS-5754
It was fixed in 2.3.3, which version are you using?
information.
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Hello,
we are using version 2.3.3 of the geoserver.
Saving changes on the WMS view does also not work.
We are using IE 9 on Windows 7.
Yours Rüdiger
Von: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] Im Auftrag von Andrea Aime
Gesendet: Freitag, 9. August 2013 10:07
An: Gubler, Ruediger
Cc: geoserver-users@anonymised.comt
Hello,
I found the trick:
You might be expiriencing this one, althought I have not seen it happen with the layer page:
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Aug 9, 2013 at 10:37 AM, Gubler, Ruediger <rgubler@anonymised.com>wrote:
Hello,****
we are using version 2.3.3 of the geoserver.****
Saving changes on the WMS view does also not work.****
I can't help there, only have Linux machines and a XP virtual machine that
can
only do up to IE8
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Hello,
I tried with firefox – no problems.
I’ll make an entry in our wiki to use FF to configure geoserver.
Thank you
Rüdiger
Gesendet: Freitag, 9. August 2013 10:42
On Fri, Aug 9, 2013 at 10:37 AM, Gubler, Ruediger <rgubler@anonymised.com> wrote:
Hello,
I can’t help there, only have Linux machines and a XP virtual machine that can
only do up to IE8
Ing. Andrea Aime
@geowolf
Technical Lead
