[Geoserver-users] wms update
If I load new data into an SDE feature class, should geoserver serve the new data automatically or should I restart geoserver? I’m using the ArcSDE connector but my newly loaded point features do not show up. Or do I have a fundamental misunderstanding of WMS and is intended to serve static data only?
David A. Hollema
GIS Analyst
United Power, Inc.
Hi David,
No you are correct, GeoServer should serve the data automatically, no update required. I guess one thing to make sure is that there is no caching going on. A couple of questions?
How are you viewing the data? What client?
Do the points actually show up after a restart?
Does the style on the layer in question contain any conditional filters that might be prohibiting the points being added?
-Justin
David A. Hollema
GIS Analyst
United Power, Inc.
This SF.net email is sponsored by:
High Quality Requirements in a Collaborative Environment.
Download a free trial of Rational Requirements Composer Now!
http://p.sf.net/sfu/www-ibm-com
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
I'm using OpenLayers as my client. I restarted geoserver, restarted
SDE, and compressed the database. Still can't see my points. They are
certainly in SDE as ArcGIS can see them in SDE.DEFAULT. Could this be a
versioning issue? Does geoserver look at SDE.DEFAULT? Also, the
feature class is not registered as versioned in ArcCatalog. I can't
have it versioned because I need to routinely load data into this
feature class with some ArcToolbox stuff. Can geoserver handle
non-versioned feature classes?
No filters on the style.
Dave
David A. Hollema
GIS Analyst
United Power, Inc.
-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: Friday, April 10, 2009 4:50 PM
To: David Hollema
Subject: Re: [Geoserver-users] wms update
Hi David,
-Justin
the
new data automatically or should I restart geoserver? I'm using the
Or
serve
static data only?
David A. Hollema
GIS Analyst
United Power, Inc.
Justin Deoliveira
Hi David,
that's strange. Yes, GeoServer works upon non versioned featureclasses and upon SDE.DEFAULT in case the featureclass is versioned
Also, the
mind, if you send a WFS GetFeature request for your feature type do you get the points in gml?
Gabriel
Dave
David A. Hollema
GIS Analyst
United Power, Inc.
From: Justin Deoliveira [mailto:jdeolive@anonymised.com] Sent: Friday, April 10, 2009 4:50 PM
To: David Hollema
Hi David,
-Justin
the
new data automatically or should I restart geoserver? I'm using the ArcSDE connector but my newly loaded point features do not show up.
Or
serve
static data only?
David A. Hollema
GIS Analyst
United Power, Inc.
Gabriel Roldan
Yes, my WFS request does return the points in GML. No problem there.
David A. Hollema
GIS Analyst
United Power, Inc.
From: Gabriel Roldan [mailto:groldan@anonymised.com]
Sent: Monday, April 13, 2009 11:31 AM
To: David Hollema
Cc: Justin Deoliveira; geoserver-users@lists.sourceforge.net
Hi David,
are
a
Also, the
Gabriel
Dave
David A. Hollema
GIS Analyst
United Power, Inc.
To: David Hollema
Hi David,
filters
-Justin
the
Or
serve
static data only?
David A. Hollema
GIS Analyst
United Power, Inc.
Gabriel Roldan
ok, so, how does the style you're applying to the layer look like? did you try a different one? it is the default "point" style shipped with geoserver?
Gabriel
David A. Hollema
GIS Analyst
United Power, Inc.
From: Gabriel Roldan [mailto:groldan@anonymised.com] Sent: Monday, April 13, 2009 11:31 AM
To: David Hollema
Hi David,
are
a
Also, the
Gabriel
Dave
David A. Hollema
GIS Analyst
United Power, Inc.
To: David Hollema
Hi David,
filters
-Justin
the
Or
serve
static data only?
David A. Hollema
GIS Analyst
United Power, Inc.
Gabriel Roldan
Here's the sld. I tried viewing either WMS or WFS with uDig as a test.
Neither of them show all the points on the map but I can see all the
features in the uDig "table" tab for the WFS feature. uDig display only
a portion of the points. If I select a record, it gets highlighted in
yellow in the map but there's no symbol on the map.
Dave
Sent: Monday, April 13, 2009 11:54 AM
To: David Hollema
geoserver?
Gabriel
David A. Hollema
GIS Analyst
United Power, Inc.
To: David Hollema
Hi David,
are
be
a
Also, the
you
Gabriel
Dave
David A. Hollema
GIS Analyst
United Power, Inc.
To: David Hollema
Hi David,
filters
-Justin
the
Or
serve
static data only?
David A. Hollema
GIS Analyst
United Power, Inc.
Gabriel Roldan
jointuse_photos.sld (3.85 KB)
That's tipically the case of udig adding a useless bbox filter around
your data, a bbox filter that it grabbed from the capabilities in
intersection with the viewing area. This is dumb, it should just use
the viewing bbox instead. I reported it as a bug, looks like it
has been fixed on trunk and will be released as part of uDig
1.2 (when that reaches a stable version, that is):
http://jira.codehaus.org/browse/UDIG-1219
Make sure the capabilities reports at least the bbox of your data as is,
but make it also larger to accomodate for data growth.
I don't understand. Is this a problem with the extents defined in the
geoserver feature type or a problem with the SLD or something else? I
already made my extents in geoserver for this feature type plenty large
enough for these data and future data...
David A. Hollema
GIS Analyst
United Power, Inc.
Direct: 303-637-1366
Fax: 303-637-1366
www.unitedpower.com
Physical Address
500 Cooperative Way
Brighton, CO 80603
Mailing Address
P.O. Box 929
Brighton, CO 80601
Sent: Monday, April 13, 2009 12:21 PM
To: David Hollema
Cc: Gabriel Roldan; geoserver-users@lists.sourceforge.net
test.
only
Please understand I'm just guessing based on your reports, and I may be
way off. It's hard to tell what the issue actually is without looking
at a log with all the requests and the like.
