[Geoserver-users] wms.xml, wfs.xml, wcs.xml wps.xml files get cleared of content making services unavailable
Issue:
We have an issue where the wms.xml, wfs.xml, wcs.xml and wps.xml files in GeoServer from time to time get cleared of content, thus resulting in no services being available.
Environment:
We have 2 environments. Both exhibit the issue.
  1. Environment 1
a. GeoServer version 2.1.x
b. Running on RHEL 5.7
c. JBoss 5.1
d. Clustered configuration
i. 4 GeoServer Instances clustered sharing global file external data directory
ii. F5 Load balancer in front of the GeoServers.
  1. Environment 2
c. JBoss 5.1
i. 2 GeoServers Clustered, sharing global file external data directory
Theory:
We ‘think’ this may be triggered by a rest reload command.
We do a reset reload command because we use the rest interface to create new layers. The call is made via one of the clustered GeoServers, and a reload of the other GeoServers in the cluster is required in order for them to become aware of the newly created layers.
It has been our observation that a back-to-back reload command often precedes the issue occurring.
Request:
I attempted to see if this issue has been reported as bug in the Jira system, but did not find a report that I thought was a match.
Has anyone else experienced this issue?
Is there an existing bug report for this issue?
Has this issue be addressing in a newer release?
Any ideas?
Thanks in advance.
Respectfully,
Chris Moreau
Hello,
I met the same problem after I reload a store by using the geoserver rest
service.
My geoserver version is 2.2.5
Any idea's to solve this ?
Thank you in advance.
View this message in context: http://osgeo-org.1560.x6.nabble.com/wms-xml-wfs-xml-wcs-xml-wps-xml-files-get-cleared-of-content-making-services-unavailable-tp4936741p5084222.html
Ciao Geobru,
I have never experience this problem or talked to anyone seeing this
problem. We would need more info in order to reproduce and fix it.
Mind you, you are working of a relatively old and unsupported (by the
community version) hence solving this would be no easy task.
I would recommend testing a newer version of GeoServer and try to make
the issue reproducible.
Simone Giannecchini
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Thu, Oct 17, 2013 at 5:36 PM, geobru <vbr@anonymised.com> wrote:
Hello,
service.
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60135031&iu=/4140/ostg.clktrk
Geoserver-users mailing list
