Hope that clears it up.
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 26 September 2013 18:29, David McKinney <geomatney@anonymised.com> wrote:
Yes,
Mine is essentially the same. What I no see is WTMS listed as a server under the main menu on the Admin page.
See attached.
David
On Thu, Sep 26, 2013 at 12:57 PM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Yes. Mine (2.3.5) looks like:
![Inline images 1]()
That’s just a regular GeoServer install using the WAR file on Windows. I’ve not done anything specific to GeoWebCache.
Jonathan
On 26 September 2013 17:51, David McKinney <geomatney@anonymised.com> wrote:
Jonathan,
So, Are you saying that with a normal instance of the integrated version of GeoServer and GWC I should see WMTS listed under services on the Admin page?
David
On Thu, Sep 26, 2013 at 12:23 PM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Hi David,
The purpose of the URL was to test to see if your WMTS is working. If you can see the XML, then it is.
What you need to do next depends entirely on what you want to do. If you want an external application to use WMTS, then you use that URL (minus the ?request… bit).
If you want to configure the WMTS - that can be done with the settings pages under the “tile caching” section of GeoServer.
Although it is odd that you don’t have a link to the WMTS GetCapabilities on your GeoServer Admin page.
Jonathan
On 26 September 2013 17:04, David McKinney <geomatney@anonymised.com> wrote:
Jonathan,
Thanks for responding. I have view the URL you provided (substituting my IP, as appropriate). I see the capabilities as XML, but I don’t know what else to do with it. I’m new to this whole thing.
Do I need to do something to start the WMTS part of the GeoServer?
Do I need to point the GeoServer to the WMTS Capabilities document, or vice versa?
How do I “try” it?
Pardon my ignorance. What’s the next step?
David
On Thu, Sep 26, 2013 at 4:44 AM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Hi David,
That URL I provided was for the GeoServer WMTS - have you tried it?
There should be a link to it on the GeoServer Admin page - that’s where I got that link from. I’ve never installed GWC as a separate install myself - it just comes with GeoServer and simply works for me.
Jonathan
On 25 September 2013 16:26, David McKinney <geomatney@anonymised.com> wrote:
I do see “WMTS 1.0.0 GetCapabilities document” on the geowebcache home page. I have not done anything to manually change the document. All I have done, so far, is to install the integrated version of the GeoServer and GeoWebCache.
Should I see WMTS listed as a service on the Admin page of GeoServer?
How do I test that I have WMTS capabilities?
On Wed, Sep 25, 2013 at 10:12 AM, Jonathan Moules <jonathanmoules@…4942…> wrote:
Hi David,
You should see the WMTS getCapabilities even if you’ve disabled the integrated GeoWebCache.
The URL will be something like this if you want to test it.
http://localhost:8080/geoserver/gwc/service/wmts?REQUEST=GetCapabilities
What version of GeoServer are you using?
Testing it now, the only way to get rid of WMTS GetCapabilities from the menu seems to be to disable it on the “Caching Defaults” menu:
“Enable WMTS Service” - make sure that’s ticked.
Jonathan
On 25 September 2013 15:01, David McKinney <geomatney@anonymised.com> wrote:
My apologies…my ignorance is showing.
I am using the itegrated version of GeoServer and GeoWebCache on the Linux platform. One of the capabilities of GeoWebCache is WMTS. Yet, I do not see WMTS listed as one of the services on the GeoServer Admin page. Additionally, I do not see the .xml for the WMTS in the /geoserver/data/ folder. I do see WCS, WFS, and WMS .xml files.
Can someone please tell me if the integrated version of GeoServer and GeoWebCache can functin as a WMTS and, if so, why do I not see WMTS in the Admin menu of GeoServer.
The end goal is to be able to server tiles to a web client, with full scale, style, etc. capabilities.
Thanks, in advance.
Geomatney
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60133471&iu=/4140/ostg.clktrk
Geoserver-users mailing list
