[Geoserver-users] WorldImage Files
As far as I know with png the world file is one of .pnw or .pngw
-Justin
On 3/9/10 3:33 PM, Patel, Ronak Avinash (US SSA) wrote:
Hi Daniele,
Thanks for your prompt reply.
I was wondering if worldfiles allow me to use a png image. If so, what
extension would the world image metadata file have to be?
Ronak Patel
*From:* dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com] *On
Behalf Of *Daniele Romagnoli
*Sent:* Tuesday, March 09, 2010 9:19 AM
*To:* Patel, Ronak Avinash (US SSA)
*Cc:* geoserver-users@lists.sourceforge.net; Froumis, James A (US SSA);
Morgan, Michael L (GXP) (US SSA)
*Subject:* Re: [Geoserver-users] WorldImage Files
Hi Patel,
I suppose you already have 2 files, a first one for the data and a
second one for the worldfile definition. (As an instance, sampledata.tif
and sampledata.tfw, in case you are working with tif world images)
You need to add a sampledata.prj file beside the other two, containing
the WKT definition of the CRS for the georeferencing.
Then you are ready to add the sample data within geoserver. The world
image plugin will look for a .prj file to find the proper Coordinate
Reference System definition.
In case you need to send your sample data via REST, zip the three files
within a single zip archive and send it with a Put request like this one:
http://localhost:8080/geoserver/rest/workspaces/topp/coveragestores/sample/file.worldimage
(make sure to specify application/zip as Content Type)
Hope this helps.
Daniele
On Tue, Mar 9, 2010 at 1:35 AM, Patel, Ronak Avinash (US SSA)
<ronak.patel@anonymised.com <mailto:ronak.patel@anonymised.com>> wrote:
Hello,
I am interested in uploading World Image Files to Geoserver using the
ESRI standard:
http://en.wikipedia.org/wiki/World_file
I was wondering as the World Image standard does not define a coordinate
system, how does one go about setting the coordinate system of a World
Image data store through the REST Configuration interface?
Thanks!
Ronak Patel
Senior Software Engineer
BAE Systems NS
San Diego, CA
Download Intel&#174; Parallel Studio Eval
Try the new software tools for yourself. Speed compiling, find bugs
proactively, and fine-tune applications for parallel performance.
See why Intel Parallel Studio got high marks during beta.
http://p.sf.net/sfu/intel-sw-dev
Geoserver-users mailing list
<mailto:Geoserver-users@lists.sourceforge.net>
Eng. Daniele Romagnoli
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
Justin Deoliveira
OpenGeo - http://opengeo.org
OOps, i screwed that up. The extensions are "pgw" and "pngw".
-Justin
Hi Daniele,
Ronak Patel
Hi Patel,
Hope this helps.
Daniele
<ronak.patel@anonymised.com<mailto:ronak.patel@anonymised.com>> wrote:
Hello,
ESRI standard:
Thanks!
Ronak Patel
BAE Systems NS
San Diego, CA
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
I guess the world image reader also supports the following convention:
  1. take the first and the last char of the extension of the file containing data. (as an instance: TIF —> TF; JPEG —> JG; PNG —> PG)
  2. Then append a “w” char after the 2 chars obtained from step 1. (Then, as an instance: TF+W —> TFW; JG+W —> JGW; PG+W —> PGW).
References to that convention are also contained in the third paragraph of the World File section at this page: 1.
Daniele
On Wed, Mar 10, 2010 at 3:00 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
-Justin
Hi Daniele,
Ronak Patel
From: dany.geotools@anonymised.com… [mailto:dany.geotools@anonymised.com4…] *On
Sent: Tuesday, March 09, 2010 9:19 AM
To: Patel, Ronak Avinash (US SSA)
Cc: geoserver-users@lists.sourceforge.net; Froumis, James A (US SSA);
Subject: Re: [Geoserver-users] WorldImage Files
Hi Patel,
Hope this helps.
Daniele
<ronak.patel@anonymised.com mailto:[ronak.patel@anonymised.com](mailto:ronak.patel@anonymised.com493...)> wrote:
Hello,
ESRI standard:
Thanks!
Ronak Patel
BAE Systems NS
San Diego, CA
Download Intel® Parallel Studio Eval
mailto:[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@anonymised.comet)
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Oops.
Justin I have received your email with the TYPO fix only after I have sent mine :slight_smile:
Daniele.
On Wed, Mar 10, 2010 at 3:25 PM, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Daniele
-Justin
Hi Daniele,
Ronak Patel
From: dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com] *On
Hi Patel,
Hope this helps.
Daniele
<ronak.patel@anonymised.com mailto:[ronak.patel@anonymised.com](mailto:ronak.patel@anonymised.com)> wrote:
Hello,
ESRI standard:
Thanks!
Ronak Patel
BAE Systems NS
San Diego, CA
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Justin Deoliveira
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
