Here's what my current request looks like (I shortened the base64 encoding):
<wps:Execute service="WPS" version="1.0.0" xmlns:wps="http://www.opengis.net/wps/1.0.0" xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsExecute_request.xsd">
<ows:Identifier>gs:Import</ows:Identifier>
<wps:DataInputs>
<wps:Input>
<ows:Identifier>features</ows:Identifier>
<wps:Data>
<wps:ComplexData mimeType="application/zip" encoding="Base64"><![CDATA[UEsDBBQAAA...AAA==]]></wps:ComplexData>
</wps:Data>
</wps:Input>
<wps:Input>
<ows:Identifier>workspace</ows:Identifier>
<wps:Data>
<wps:LiteralData>upload</wps:LiteralData>
</wps:Data>
</wps:Input>
<wps:Input>
<ows:Identifier>store</ows:Identifier>
<wps:Data>
<wps:LiteralData>test</wps:LiteralData>
</wps:Data>
</wps:Input>
</wps:DataInputs>
<wps:ResponseForm>
<wps:ResponseDocument>
<wps:Output>
<ows:Identifier>layerName</ows:Identifier>
</wps:Output>
</wps:ResponseDocument>
</wps:ResponseForm>
</wps:Execute>
The result I see is:
<ows:ExceptionReport version="1.1.0"
xsi:schemaLocation="http://www.opengis.net/ows/1.1 http://localhost:8081/geoserver/schemas/ows/1.1.0/owsAll.xsd"
xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>Process returned with an exception
Could not convert (encoded data block) to target type org.geotools.data.simple.SimpleFeatureCollection</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
The request does work when I take the file that created the base64 encoding and reference it like so:
<wps:DataInputs>
<wps:Input>
<wps:Reference xlink:href="///path/to/my/file/testShapes.zip" mimeType="application/zip"/>
</wps:Input>
<wps:Input>
<wps:Data>
</wps:Data>
</wps:Input>
<wps:Input>
<wps:Data>
</wps:Data>
</wps:Input>
</wps:DataInputs>
<wps:ResponseForm>
<wps:Output>
</wps:Output>
</wps:ResponseForm>
</wps:Execute>
Ivan Suftin - Applications Developer - isuftin@anonymised.com
Center for Integrated Data Analytics (CIDA)
U.S. Geological Survey
8505 Research Way, Middleton, WI 53562
Office: (608) 821-3825 - Cell : (608) 345-8963
